Old Jul 24, 2012, 07:28 PM
mindenrc is offline
Find More Posts by mindenrc
Joined Jan 2011
nano receiver will not bind
I have a 6 channel nano receiver that goes into reset everytime I power it up wether I have a binding plug installed or not. Always the same flashing slow flash then the light goes out
mindenrc is offline Find More Posts by mindenrc
Old Jul 24, 2012, 09:14 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
powering up with binding plug already connected puts it into "connect to a computer mode".
for binding, turn the receiver on first without the binding plug, then add the binding plug until the LED changes state, then remove... now you're in binding mode.
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Jul 25, 2012, 12:23 AM
GBR2 is offline
Find More Posts by GBR2
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
Also see the sticky Binding your Xtremelink System
GBR2 is offline Find More Posts by GBR2
Old Jul 25, 2012, 11:32 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Is this with nothing connected to the B port at all? Sometimes a BEC plugged into the B port will cause this. If this is the case, remove the signal wire from the BEC.
JimDrew is offline Find More Posts by JimDrew
Help! Fs-t4a transmitter and hk-tr6a receiver not binding rcta15 Radios 1 Apr 15, 2012 02:50 AM
Discussion Proto Max will not bind?? discostu9 Micro Helis 13 Mar 04, 2012 01:04 AM
Discussion DX6i Will Not Bind johnorama Radios 0 Mar 01, 2009 08:43 PM
Help! DX7 will NOT bind magee8578 Radios 2 Oct 18, 2007 09:23 AM
Discussion DX6 will not Bind What the HECK? Madguns Radios 0 Aug 04, 2007 10:47 AM
