here's what I have right now: http://zippkits.com/~zippkits/index....roducts_id=405 there are two spots on the bag for lines but one is plugged. I was able to yank the plastic twisty pieces off the carb that control the mix and there are two screws that can move quite a bit. don't know which is which though.
nearly done with a mount for the engine. don't know how much glass I should use to hold it down but I don't think six layers (3 on top three on bottm) of heavy glass will break off. might enlarge the mounting holes and put a little silicon in the wholes to absorb some vibration.
I also tested how the boat would float with the engine and it is good. got the engine going but it doesn't now and it'll only stay going for about a minut. what's a good starting place for the 2 screws? |
Kalamazoo, MI
Joined Apr 2004
Don't worry about the air bubble in the primer as it isn't going to hurt anything. All that's doing anyway is helping to draw fuel up to the carb. On the carbs witohut primers, we just crank them over with a finger or thumb over it. No chokes, no primers.
Watch silicones around electronics as if it has an ammonia-like odor, don't use it as it can eat up your circuit boards. I use Corrosion X which is around $15.00 for an aerosol can. A can will last you forever and you'd throw away WD-40 after using this stuff! I've used it on frozen car door locks, hinges or anywhere you'd use WD-40 but better. NASA uses it, it's that good. Brass tubing usually works better for wrapping aorund things like the cylinder head. Heat it up first, over a gas stove or propane torch does the job. Get it glowing orange, let it air cool then it becomes really easy to work with. |
Kalamazoo, MI
Joined Apr 2004
I've got the spray can but I don't think that they make it in a way where it can be dipped. You can shoot servo's, RX's and switches with it without fear. I've also got some Aero-Plate which unfortunately not being made anymore that does the same thing. There is one more that's hard to find yet may still be available from some hobby shops called The Stuph that comes in a squirt bottle.
Don't use Plasti-Dip as I've tried it. |
alright cool! I'll look for some.
what is a good way to connect the motor to the prop seeing as the flex shaft that has a threaded end is round and won't mount into the square hole in the engine. I haven't found any 1/4" couplers. I have one that I machined but it has to be re drilled so that it isn't 1/8" to 1/4" and it needs to be re taped to fit 4 set screws |
| Thread Tools | |
| Build Log first big boat/first working (hopfully) boat | builder bob | Dock Talk | 3 | Jul 24, 2012 06:29 PM |
| Discussion first 'big' HK order, EMS to USA. | nemoskull | HobbyKing | 8 | Jul 12, 2012 08:35 AM |
| Cool My son's first "Big Boat" | scorpion1 | Racing Boats - Electric | 11 | Apr 12, 2012 09:14 PM |
| Discussion New DIY Octocopter - First hop / flight. | Efliernz | Hoverfly Technologies | 29 | Apr 10, 2012 02:47 AM |
