Old Jul 24, 2012, 06:33 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Dynam T-28 main retracts will no opertate
Received my Dynam T-28 on Friday. Started building it today (Sat). The nose gear retract works find but the main gear do not function at all. Tried different locations on the receiver. Again nose gear worked but the mains did not. Please help. need a replacement set. Need it fixed for an up coming trip I'm going on next week. Got a ticket ANR-227-49630 so far nothing.
Bob Ruff
bruff is offline Find More Posts by bruff
Old Jul 25, 2012, 02:49 AM
winggunner46 is offline
Find More Posts by winggunner46
Joined Dec 2010
Quick Fix
I keep on hand a lot of connectors of diffent length and all that other crap. You have a spot on your receiver that works for your nose gear, right? Get two short Y's. Plug one into where you have the nose gear working. Plug the other into one side of the first one. use that one for your main gear and run your nose to the other. Should work! Or sometime you might hear from NP
Good Luck
winggunner46 is offline Find More Posts by winggunner46
Old Jul 25, 2012, 12:35 PM
RaidenCharlie is offline
Find More Posts by RaidenCharlie
HobbypartZ Support
Joined Jul 2011
Check to see if the y-harness is connected securely, sometimes the factory don't plug them in all the way. Or it could be just a bad y-harness. If you have another harness use that to test the retracts.
-Charlie
RaidenCharlie is offline Find More Posts by RaidenCharlie
Old Jul 25, 2012, 02:30 PM
bruff is offline
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
-Charlie
This was without "Y" harness. Straight to the retract same channel nosed worked but the mains did not. Tried them one at a time.
Bob
Old Jul 26, 2012, 02:16 AM
Joined Dec 2010
I have the same plane
:But, without retractors. I would guess that 90% of all problems of this nature are electrical and 90% of that is the wiring. Try a direct wire hookup.Receiver to retractor WITH ANOTHER SET OF WIRES. Hey I am no electrical wheeze. None of the planes I have retractors, but I am lusting for one. I will probably be in your spot with first one I get.
Good luck.
That ia a good plane to fly. Or so I am told. I have yet to fly mine.
When the Dr. releases me to play it will be the first I will TRY to fly.
Old Jul 26, 2012, 12:42 PM
HobbypartZ Support
Joined Jul 2011
I'm going to have another set of retracts sent out to you, when it ships we'll email you the tracking number for the package.
-Charlie
Old Jul 26, 2012, 09:03 PM
bruff is offline
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Thanks!
bob
Old Jul 27, 2012, 11:02 PM
Joined Dec 2010
You are lucky
My sky trainer (large) problem has yet to be resolved. Even after I sent them the parts and full 8 x 10 B&W glossy photos. I am happy for you, but their lack of interest in my problem will result in my not buying another of their planes. Good planes, but in my case (I can not speak for others) their customer service sucks.
When I buy a plane I expect that some point in time I will nose it in or hit a tree. That is my fault, but when following Jeff's video, and they are good, for doing the flaps and the flap is glued/taped on so tight that it is impossible to get one side loose that it breaks. The answer I got was " we are not responsible for customer breakerage. I bought at the same time a spare set of left and right wings and two each of of rudders and elevators. I would include a copy of the invoice, BUT THEY DO NOT include an invoice. They don't even email you one. These are not GOOD business pratices.
Old Jul 30, 2012, 05:08 PM
HobbypartZ Support
Joined Jul 2011
What is your order number for the plane?
-Charlie
Old Jul 30, 2012, 10:26 PM
Joined Dec 2010
Dig
I will have to dig for that one as the box was tossed long. I do believe I did make a copy.
Old Aug 07, 2012, 10:39 PM
bruff is offline
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Got the retracts.
Bob
Sold Don Smith T-50 Bobcat kit by PCK, Robart Mains, Dynamic Balsa Cockpit Kit, REDUCED ir3 Aircraft - Fuel - Airplanes (FS/W) 0 Jul 15, 2012 09:37 AM
Question Dynam t-28 parts srt8madness Nitro Planes 2 Jun 15, 2012 01:48 PM
Sold ** Dynam T-28 RxR w/Retracts & Flaps LPU Central Ohio ** Sammy70 Aircraft - Electric - Airplanes (FS/W) 7 Jun 02, 2012 01:58 AM
Discussion New Red Dynam 1200mm T-28 Trojan w/ Retracts Overview hobbypartz Product Announcements 1 Aug 20, 2011 03:18 AM
Discussion Dynam 2.4Ghz 5 Channel Trainer T-28 Trojan 1270mm RTF w/brushless motor+esc w/Retract RaidenTech Electric Plane Talk 3 Aug 16, 2011 04:59 PM
