Old Sep 23, 2012, 10:52 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I am going to buy 100 AMP Castle ESC. ICE or ICE Lite?
In addition, how much headroom is there with these ESC's? I have read that Castle under rates their ESCs. If so, how much?
Prof100 is offline Find More Posts by Prof100
Old Sep 24, 2012, 12:00 AM
sothpaw is offline
Find More Posts by sothpaw
Joined Jun 2012
Originally Posted by efflux RC View Post
The motor will fit the fan and the collet dia (4mm). you may need to shorten the shaft and add a flat.
You will need at least a 75 ESC for 4s. I would put a 100A in there (ICE 100) to be ready for 5s, when you desire more power.
What do you think the thrust would be if I went with Mega 16/35/1 on 5S with the stock fan and ICE 100? Would this be a reliable 5S upgrade setup? Or do I need the next size up Mega (not sure which this is)?
Looking for a good bolt-on setup to upgrade thrust in the Habu.
sothpaw is offline Find More Posts by sothpaw
Old Sep 24, 2012, 01:27 AM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
My guess is about about 5 lbs thrust. Once you start pushing equipment, fly at WOT the whole flight can't be done. that's what the stock (3200kv) motor on 4s is for.
With some throttle management and a heat sink, you should be fine. This is the case for hot setups with any EDF.
The next step up (longer motor) would be the 16/40/1 (3150kv) motor on 6s, or the HET 1W-40 (3300kv)
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Sep 24, 2012, 04:32 AM
shung1 is offline
Find More Posts by shung1
shung1's Avatar
Joined Jan 2011
Originally Posted by fh64_lucky View Post
Sweet!! You might want to move the fan back farther to counter the 6s lipo.My receiver is sitting on wing under 2s lipo all were the foam align block for wing to fuse is also.Keeps battery area tidy without all servo wires strung through.
Ah,its hard to see but it looks like you did same as me...
Have plenty of room in battery tray with the 2600mah lipo
shung1 is offline Find More Posts by shung1
Old Sep 24, 2012, 08:48 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
I posted this on fh64's modification thread but has anybody tried a SAPAC MB1 in their Habu 2? On a 5s they should pull 1800 watts at about 100 amps.
Second question. Where can you buy thrust tube Mylar? I think 5 mils is what I need. Chime in.
Old Sep 24, 2012, 10:38 AM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
Shung, with the 2600 lipo I can know you will have plenty of room,the 3300 6s I am running fits well enough.You may be low on flight times though,a couple of passes and then you will have to land,might be cutting that close.Is there any way you can go at least 3000 size lipos?
fh64_lucky is offline Find More Posts by fh64_lucky
Old Sep 24, 2012, 01:27 PM
sothpaw is offline
Joined Jun 2012
5 lb thrust should be more than adeqate...weight is around 3 lb now but I can't believe the stock motor is putting out more than 2 lb.
What 5S setup would you recommend if I want to fly mostly full throttle the whole time assuming I want reliablity (hundreds of flights) and bolt-on (no grinding the motor shaft to fit...just simple assembly via fasteners)? I've heard you have some good ones!
Old Sep 24, 2012, 01:31 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
You will need a motor and esc made from unobtanium to fly wide open all the time.
Old Sep 24, 2012, 04:21 PM
shung1 is offline
shung1's Avatar
Joined Jan 2011
I opted for a 2600 size as this battery weighs similar to the stock 4s setup. My setup on a 2600 6S is pulling 900+ watts @ 42amps, flight times will be 4-5min with throttle management. Plenty for me.
Old Sep 24, 2012, 04:35 PM
efflux RC's Avatar
Joined Aug 2009
We stock it.
http://www.effluxrc.com/Mylar-Thrust...ial-M24X48.htm
Site Sponsor
Old Sep 24, 2012, 04:55 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
I will shop locally. $13 to ship $7.50 of mylar seems at bit outrageous to me.
Old Sep 24, 2012, 05:50 PM
fh64_lucky's Avatar
Joined May 2005
I think local craft/hobby shop places like Hobbylobby sell the stuff in arts part of store.
Old Sep 24, 2012, 05:51 PM
fh64_lucky's Avatar
Joined May 2005
Shung, at those amps ,yes fight times will be good.I thought you might be pulling 70-80 amps for some reason......
Old Sep 24, 2012, 06:08 PM
efflux RC's Avatar
Joined Aug 2009
If you can find it locally I would.
It ships rolled up in a priority mailing tube. 1-4 days.
I adjusted the dimensions so you should be charged about $7.50 for USPS Priority mail.
Site Sponsor
Old Sep 24, 2012, 07:17 PM
sothpaw is offline
Joined Jun 2012
Well, tonight I flew the following pattern on 4S: take off 100%, 100% on down wind leg, down to 90% next turn, 75-90 through the up wind section, then 100% in the turn and down wind.
I'd love to fly at 50% but the plane looks slow and I'm afraid of stall.
So with 75% throttle some of the time and 100% on the down wind leg, would the 16/35/1 last a long time on 5S with a good ESC and proper cooling? Is the Mega 16/35/1 a bolt on solution or does it need a trim/mods?
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
Discussion New mini summit owner.. any tips? custom t Off-road Cars 16 Jul 05, 2012 10:03 AM
Discussion parkzone micro mods and owners thread flyguy99 Scratchbuilt Indoor and Micro Models 0 Jun 01, 2012 09:02 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Discussion Traxxas Slayer Owners/mod Thread corsair nut Off-road Cars 11 Nov 04, 2009 10:14 PM
