Old Aug 05, 2012, 11:22 PM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
It was my 1st time flying in over 2 months, I did have the "Shakes" a tad on that
1st flight but I finally settled in....
fh64_lucky is offline Find More Posts by fh64_lucky
Old Aug 05, 2012, 11:49 PM
kevinrc is offline
Find More Posts by kevinrc
Happy Habu Hustler
Joined May 2012
Have people going 6s done so with 2x3s? How did that work?
kevinrc is offline Find More Posts by kevinrc
Old Aug 05, 2012, 11:51 PM
fh64_lucky's Avatar
Joined May 2005
You can use any combo you want of cells, they just have to be same Mah, and C rating.Do not mix different brands of batteries either.
Old Aug 06, 2012, 12:29 AM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Should have joe's on board video tommorrow. technology is fighting tonight, my med's are kicking in! Great pilot, and jet, and Fan! Capt Lee
capt soap is offline Find More Posts by capt soap
Old Aug 06, 2012, 12:42 PM
fh64_lucky's Avatar
Joined May 2005
1 thing I did notice when flying, is that mine wanted to roll right and took some trim on ailerons to get it level. I will check lateral balance tonight, but it seems it might be more then that. Wings and tail look in align so at this point I am not sure what is going on, I did read were another flyer had same problem with his. I will see what I come up with and post results.
Old Aug 07, 2012, 08:33 PM
fh64_lucky's Avatar
Joined May 2005
2nd flight Cockpit video
Capt soap (Lee) let me install his little camera in canopy, its tinted so videos a lil dark, but still looks cool!
Habu 2 cockpit video of 2nd flight (2 min 34 sec)
Until this video, I had NO idea water was on other side of that tree line! The guys told me there was water there, but you can not see it from field.
Old Aug 07, 2012, 10:52 PM
capt soap's Avatar
dallas tx
Joined Jun 2003
chhttp://www.youtube.com/watch?v=56H2y_hWtGo&feature=g-upleck out the camara in the wings section on the striker q.
Old Aug 15, 2012, 11:34 PM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Surrey
Joined Jul 2011
Hey guys, I was just wondering if the included fixed landing gear can be used with the eflite retracts? I have a set from another donor but I have already chopped up and bent the eflite struts and don't want to buy another set. Maybe the fixed gear can be cut and used as retract struts.
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Aug 15, 2012, 11:43 PM
fh64_lucky's Avatar
Joined May 2005
I will check mine when I get home tonight, see if Diameter is same and what is needed to make them work.
Old Aug 16, 2012, 02:28 PM
WhalleyB0Y's Avatar
Canada, BC, Surrey
Joined Jul 2011
The original mains fixed struts can be cut down right at the elbow, flat spots filed and will work perfectly in the retracts. The lengths are good and they have a tension coil too. The nose strut is just too short to be used. The aoe would be horrendous so I had another nose strut with a coil that was longer that I ended up using in its place. I think the eflite struts that come with the tricycle kit are just too rigid and the coils too hard to be effective. When I assembled mine I had wing mounts, servos, and brackets that all came loose or didn't have enough glue on them. I used a white silicone and put everything together.
Old Aug 16, 2012, 03:26 PM
fh64_lucky's Avatar
Joined May 2005
Yup, thats what I came up with....the nose would be way low using stock gear in retracts. I like Eflights gear, but then agian mine is heavier then stock.....
Old Aug 16, 2012, 04:48 PM
Boro is offline
Find More Posts by Boro
Joined May 2012
Great thread and some awesome videos. My stock Habu2 is built and waiting for its maiden. Being relatively new to rc planes, I'm anxious about taking it up and have a few questions.
Can it land dead stick? What kind of flight times can I expect completely stock using a 4s 3200mah? And lastly, should I think about adding flaps for easier flight?
Boro is offline Find More Posts by Boro
Old Aug 16, 2012, 05:52 PM
fh64_lucky's Avatar
Joined May 2005
Thanks Boro, I only started this thread as other has about 10 pages of the talk before it was out....Mine gets right to it.
As long as you setup good, deadstick(motor off glides) are easy.Stock I would say you do not need flaps,I dont have them and mines heavy but lands fine.I did over shoot my 1st landing but that was a get to know it flight. I can now land it anywere, no flaps.
Flight times I cannot answer... I never tried stock.
Old Aug 16, 2012, 06:04 PM
Boro is offline
Joined May 2012
Thanks. What camera did you use and how did it fit in the canopy. I'm thinking about fitting my gopro somewhere.
Boro is offline
Joined May 2012
PS. Does this thing fly anything like the Phoenix RC model in the sim?
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 05:32 AM
Discussion New mini summit owner.. any tips? custom t Off-road Cars 16 Jul 05, 2012 11:03 AM
Discussion parkzone micro mods and owners thread flyguy99 Scratchbuilt Indoor and Micro Models 0 Jun 01, 2012 10:02 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 12:50 PM
Discussion Traxxas Slayer Owners/mod Thread corsair nut Off-road Cars 11 Nov 04, 2009 11:14 PM
