Old Nov 18, 2012, 11:03 PM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
On the subject of retracts, I am thinking about trying these out...
http://www.hobbyking.com/hobbyking/s...dproduct=12883
with these struts:
http://www.hobbyking.com/hobbyking/s...dproduct=11300
Anyone try that combo or something similar? I still need to figure out what to do for the nose retract, since I am not sure if the ones above have a steering mech...
Jetnfast is offline Find More Posts by Jetnfast
Old Nov 19, 2012, 02:03 PM
erikc641 is offline
Find More Posts by erikc641
United States, NM, Las Cruces
Joined Jul 2012
Finally finished my 5 cell Habu 2 setup yesterday with the help of Gary over at effluxrc:
Velocity 2860 3700kv motor with heatsink
Skyworld Aluminum housing
WeMoTec Mini Fan Pro rotor
all dynamically balanced and ready to go with a CC Phoenix Ice 100, CC BEC, and a turnigy 5s 4000 40c pack. Should be a big difference from stock.
I will def order from him again
erikc641 is offline Find More Posts by erikc641
Old Nov 21, 2012, 02:22 PM
erikc641 is offline
Joined Jul 2012
with the setup above, I got:
85 amps
1648 watts
from a Turnigy 5s 40C at only 19.3v. I just got the motor in and couldn't wait for a full charge. Can't wait to see what a full charge will do. Throttle management will definitely be key.
Old Nov 22, 2012, 08:51 AM
erikc641 is offline
Joined Jul 2012
Fully Charged:
2089 watts
110A Peak
I think it will fly
Old Nov 25, 2012, 08:03 PM
supercollider is offline
Find More Posts by supercollider
C.E.R.N. field tester
supercollider's Avatar
United States, NE
Joined Sep 2012
Originally Posted by erikc641 View Post
fully charged:
2089 watts
110a peak
i think it will fly
vto?
supercollider is offline Find More Posts by supercollider
Old Nov 25, 2012, 09:17 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I must report the Styrospray 1000 (liquid sheeting) failed on the wing and horizontal stab. I think it was due to the pot life being exceeded. It seems to work on the fuselage and vertical stab, but it wasted a lot of time prepping the surface and priming. The wing and horizontal stab just peeled off. Anyway, the vertical stab has a fresh coat of Acrylic Enamel Duplicolor white (not shown). The fuselage is ready for some more spot puttying (not shown).
CF reinforcement and hinging the surfaces
Meanwhile, the wing and horizontal stab were a bit to flexible to my liking so I added some 3 mm carbon fiber tube. All hinges were reworked by using 3M Extreme tape on the bottom and 3M storage tape (3650 series) on top.
The 3M storage tape is good enough for use on 160 mph RITEWINGS. Below are some pictures.
Prof100 is offline Find More Posts by Prof100
Old Nov 25, 2012, 09:36 PM
Foambird is offline
Find More Posts by Foambird
St. Louis
Foambird's Avatar
USA, MO, Ballwin
Joined Mar 2010
The Habu 2s at our field fly well right out of the box for the past month or so.
Foambird is offline Find More Posts by Foambird
Old Nov 25, 2012, 09:40 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
They should and they do. I am going to fly with double the power output in my Habu 2 so I want the flex to be less.
Old Nov 25, 2012, 09:48 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Proffessor, do you think your habu will do 160 ???? Just kidding.
capt soap is offline Find More Posts by capt soap
Old Nov 25, 2012, 09:57 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Not hardly. With 1600 watts it would do well reaching 110 mph.
Old Nov 26, 2012, 12:30 AM
erikc641 is offline
Joined Jul 2012
Originally Posted by supercollider View Post
vto?
I havent had a chance to rmaiden the new setup yet
Old Nov 26, 2012, 12:46 AM
United States, NE
Joined Sep 2012
Your setup sounds like a party.
Have fun and good luck.
Old Nov 26, 2012, 12:51 AM
erikc641 is offline
Joined Jul 2012
I will post a video
Old Nov 26, 2012, 10:00 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Evercoat for flexible surfaces
I think I found the perfect surfacing agent for foam. It is like lacquer based automotive spotting putty but flexible and it works in a two part mixture like polyester (BONDO). Did I say it's flexible? That's what makes it perfect for coating foam surfaces. It mixes quickly but sets in 4-6 minutes. It sands easily using a DA or block sanding by hand. Great stuff. It comes in a bottle with tube of catalyst. The name is Poly Flex for spot filling and skim coating flexible surfaces. Price is high for quart but not in the world of automotive finishing.
Price is $31.
Old Nov 26, 2012, 10:54 PM
Wind Junkie is offline
Find More Posts by Wind Junkie
NY Slope Dog
Wind Junkie's Avatar
Syracuse, NY
Joined Sep 2003
I've used Evercoat metal glaze for many years on FG fuse prep. It's especially good for smoothing fillets in tight to reach places. Much easier to sand than Bondo.
Wind Junkie is offline Find More Posts by Wind Junkie
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
Discussion New mini summit owner.. any tips? custom t Off-road Cars 16 Jul 05, 2012 10:03 AM
Discussion parkzone micro mods and owners thread flyguy99 Scratchbuilt Indoor and Micro Models 0 Jun 01, 2012 09:02 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Discussion Traxxas Slayer Owners/mod Thread corsair nut Off-road Cars 11 Nov 04, 2009 10:14 PM
