Old Oct 10, 2012, 08:33 PM
sothpaw is offline
Find More Posts by sothpaw
Joined Jun 2012
Originally Posted by WhalleyB0Y View Post
I finally got my first CS 70mm 10 blade so I stuffed it into my H2 today.
I so badly wanted to slip some milar into the exit duct but I couldnt figure out how. The i.d. of the duct is smaller than o.d. of the fan. So basically I couldn't open the rolled milar tube wide enough to tape around the fan. It appears that I would need to bore out the foam that makes up the duct so that the roll can expand enough to fit the fan.
I went without it for now so I could run up some numbers on the fan in the jet.
With the three various pack sizes I had on hand here is my results:
5s 3300mAh 30C
15.59vm
106.9ap
1787wp
3 min fly time
4s 3500mAh 35C
13.11vm
82.96ap
1130wp
2.52 min fly time
Auw
5s 2200 1.6kg / 3lb9oz
5s 3300 1.8kg / 3lb13oz
* 22grams in the tail needed to balance
4s 3500 1.63kg / 3lb9oz
Quick question here: How did you get 3 min flight time with 106 amp draw on 5s but only 2/12 on 4s with 83 amp draw? Was this pure throttle management?
I like the combo, just curious on flight time. That's my only hang up now...would like to see a combo with 70amp draw tops that would be 1200 watts/3.75 lb thrust. The eflite 3200kv motor should do it but it's really not rated for anything like 70amp.
sothpaw is offline Find More Posts by sothpaw
Old Oct 10, 2012, 08:51 PM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Fort Langley
Joined Jul 2011
The 106ap is the burst peak amperage as read from the wattmeter. It would settle at 90-96 amps and I could run it at between 75-100% throttle for 3 mins before soft cutoff. When I actually fly it I will set the timer for 3 mins and probably fly for 4 mins with conservative throttle knowing I am probably only running at 60 amps most of the time.
I also used my infra red temp gun and did not see the temps rise beyond 76* F
The 4s provided similar flights times with similar throttle use. I believe the reason is because one of the 2 brands of pack's labeled capacity is actually inaccurate.
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Oct 10, 2012, 09:18 PM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
When do you think you will fly the 5s setup? I am curious to see how it flies, it will give me something to compare mine to.My numbers are close to yours, allthough I am on 6s and have quite a few more watts.I still need to try a thrust tube on mine but not in any hurry as its no lacking in thrust.
fh64_lucky is offline Find More Posts by fh64_lucky
Old Oct 10, 2012, 09:29 PM
WhalleyB0Y's Avatar
Joined Jul 2011
ooh we got some nasty weather coming our way. Might be awhile before I get a shot at it. This combo has some crazy thrust too and I can hardly wait.
Old Oct 10, 2012, 09:49 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
A smaller outlet will improve top speed.
Prof100 is offline Find More Posts by Prof100
Old Oct 10, 2012, 10:03 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Bare airframe ESC installation
Fall season is here with shorter, cooler and windy days. So, it is time to start building. the Habu 2. Components are purchased except for Castle BEC. I opted for the less expensive Hobbywing Pro100 amp ESC which should handle the Sapac MB1 and fan. Tonight's task was to install the ESC in the ductwork. I like the idea of putting the ESC in the inlet airflow and moving it further back to help with weight distribution especially when running a 5S. Below are a couple of pictures with the foam cut out and fitted. I was planning on using silicone RTV to install it.
Old Oct 10, 2012, 10:29 PM
WhalleyB0Y's Avatar
Joined Jul 2011
Yea actually you know what? Another guy at the tarmac had just bought a Dynam Meteor and we were doing the old comparison. I really liked its location of the esc more and thought it might be a viable option for the Habu as well.
btw I think you did a great job mounting yours.
Old Oct 10, 2012, 11:04 PM
supercollider is offline
Find More Posts by supercollider
C.E.R.N. field tester
supercollider's Avatar
United States, NE
Joined Sep 2012
Esc looks great. Lots of cooling there.
supercollider is offline Find More Posts by supercollider
Old Oct 10, 2012, 11:18 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
It is not my idea, just an implementation of another person's idea. That's what makes RCgroups so great! You get to see other people's ideas and use them. I just wish I could give proper credit.
It should do the job and move weight rearward. I just did some modifying of the battery area and moved the 5S 3300 pack back 2" from the stock location. See attached picture.
Old Oct 11, 2012, 07:18 AM
MikePS is offline
Find More Posts by MikePS
AMA 983978
United States, FL, Jacksonville
Joined Sep 2011
Got my edfhobbies Velocity 2950kv installed in my H2 last night, WeMoTec Minifan Pro, 6s 3300 40C. At WOT:
85.1a
1850 watts
No flights yet, hoping to get it out after work.
MikePS is offline Find More Posts by MikePS
Old Oct 11, 2012, 09:00 AM
WhalleyB0Y's Avatar
Joined Jul 2011
85.1a
1850 watts
Wow Mike, your H2 is gonna snap your head back. Should be a real screamer! I got the exact same setup in my twin raptor and I am still testing. I got similar numbers to your results. Name: ImageUploadedByTapatalk1349964008.749600.jpg
Description: I did find the heat of the 2950's to be an issue. In one case it melted the mount in the shroud and ruined it. It may have been my bad balancing job or maybe not enough fan clearance but I have since added thermal paste and heat sinks to be safer.
Be sure to take a camera man with ya cause I want to see your H2 go!
Old Oct 11, 2012, 10:17 AM
MikePS is offline
AMA 983978
Joined Sep 2011
I've put the heat sink on the motor with the Artic Silver thermal paste. I plan on making the first few runs at a reduced throttle. This is my first foray into 6S...I'm expecting 3.5min of sheer terror and sweaty palms!
Old Oct 13, 2012, 08:30 AM
fh64_lucky's Avatar
Joined May 2005
That is the cleanest ESC install I seen yet!Man I look forwards to seeing some of these videos....If weathers good I am going to get out there and fly mine,been a few weeks.....
Old Oct 13, 2012, 11:01 AM
WhalleyB0Y's Avatar
Joined Jul 2011
Hey guys when I had my shaker flight with the new CS fan on 5s I had encountered problems that had me puzzled.
* 2950kv motor on 5s 3300 mAh 30C with CS 10 blade fan
parkzone habu 2 5s (6 min 17 sec)
I have now located the problem and turned out to be bad factory soldering on those motor lead extension wires. I have now replaced them with 12awg silicone wire and soldered them directly to the motor this time.
I actually prefer doing it this way but was surprised that this was the condition from factory. I was really lucky to not have had a crash as this is already a replacement plane from HH.
I recommend to everyone to solder the leads directly.
Has anyone tried using dielectric grease on connectors? This product claims to enhance the connection and prevents arcing and damage to battery connections.
Old Oct 13, 2012, 11:18 AM
MikePS is offline
AMA 983978
Joined Sep 2011
Hey Whalley...my first motor arrived DOA, nothing but a humming noise when powered up. I returned to edf hobbies (he replaced with no questions asked!) but later told me he thought the problem was a bad connector...that said, your suggestion may be the best preventative fix
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
Discussion New mini summit owner.. any tips? custom t Off-road Cars 16 Jul 05, 2012 10:03 AM
Discussion parkzone micro mods and owners thread flyguy99 Scratchbuilt Indoor and Micro Models 0 Jun 01, 2012 09:02 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Discussion Traxxas Slayer Owners/mod Thread corsair nut Off-road Cars 11 Nov 04, 2009 10:14 PM
