Old Oct 05, 2012, 04:03 AM
Paul-RC is offline
Find More Posts by Paul-RC
Let me Fly please :^)
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Originally Posted by efflux RC View Post
I like playing with dollys.
This one has a steerable nose wheel, and it own rx, bound to the tx, on rudder channel.
That is amazing! good idea for the RX control .
Mine looks very close to it but it was setup as a tail drager with a free wheeling tail wheel.
It did work well but I like your idea much better.
Paul-RC is offline Find More Posts by Paul-RC
Old Oct 06, 2012, 01:13 PM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
Originally Posted by Prof100 View Post
Whalleyboy,
Looks as fast as mine on a 5S. Yes, the weight does add up. I am going to use a Sapac MB1 and fan on 4S and it puts out about 1100 watts. On a 5S about 1800 watts.
I just ordered a 100 amp Hobbywing Platinum Pro which is right at the max amps of the SAPAC MB1 on a 5S.
I have an MB-1 fan/motor sitting around I think I might use if I buy the airframe only version. I dont think the MB-1 comes with the motor mounting tabs attached. Just curious how you were going to mount the motor? Hot glue?
Jetnfast is offline Find More Posts by Jetnfast
Old Oct 06, 2012, 03:36 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I would make the tabs, JBWELD in place and screw it in. I have CF the right thickness. I have done it before.
Prof100 is online now Find More Posts by Prof100
Old Oct 06, 2012, 06:08 PM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
Sound good, I figured it was something along the lines. I just ordered my airframe only version, so I guess I got some reading to do!
Old Oct 06, 2012, 06:34 PM
Prof100's Avatar
Joined Jul 2007
Here is a Sapac fan with tabs added for a Squall installation.
Old Oct 06, 2012, 07:09 PM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
Thanks prof, looks good! That JB weld stuff is pretty strong I guess? I have never used it, but the install pics give me a good idea of what to expect if I go with the MB-1.
The MB-1 is good for around 1100w if I remember correctly? It definitely pushes my Sapac T-45 around with authority, much better than my comparable eflite F-86 which is a dog on takeoff. The stock eflite setup is around 800w, so that should be a nice boost just by using the MB-1.
Old Oct 06, 2012, 07:47 PM
Prof100's Avatar
Joined Jul 2007
KV on the stock Habu and MB1 are the same. The difference is the Sapac Fan.
Old Oct 06, 2012, 08:18 PM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
Sounds good.
Old Oct 06, 2012, 08:24 PM
Prof100's Avatar
Joined Jul 2007
Sounds good.
Let's say the two motor's KV is the same. The two motors are inherently different. The stock is an inrunner and the MB1 is an outrunner.
Consider balancing the fan on your prop balancer. It will make more power and preserve the bearings.
Old Oct 10, 2012, 07:08 PM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Fort Langley
Joined Jul 2011
I finally got my first CS 70mm 10 blade so I stuffed it into my H2 today, mounted and balanced with the edfhobbies 2950kv motor.
I so badly wanted to slip some milar into the exit duct but I couldnt figure out how. The i.d. of the duct is smaller than o.d. of the fan. So basically I couldn't open the rolled milar tube wide enough to tape around the fan. It appears that I would need to bore out the foam that makes up the duct so that the roll can expand enough to fit the fan.
I went without it for now so I could run up some numbers on the fan in the jet.
With the three various pack sizes I had on hand here is my results:
5s 3300mAh 30C
15.59vm
106.9ap
1787wp
3 min fly time
4s 3500mAh 35C
13.11vm
82.96ap
1130wp
2.52 min fly time
Auw
5s 2200 1.6kg / 3lb9oz
5s 3300 1.8kg / 3lb13oz
* 22grams in the tail needed to balance
4s 3500 1.63kg / 3lb9oz
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Oct 10, 2012, 07:11 PM
WhalleyB0Y's Avatar
Joined Jul 2011
Here is what I am looking at when trying to slip in some milar
Description:
I think maybe I can ream a little more foam out so it's tapered to the o.d. of the fan shroud. Maybe even cut slits into the cone to fit over the fan. Then tape it all up?
Old Oct 10, 2012, 07:29 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
A soup can wrapped with sandpaper or a "3M Flap wheel" may help.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Oct 10, 2012, 07:36 PM
WhalleyB0Y's Avatar
Joined Jul 2011
Thanks Gary, I will try that.
Old Oct 10, 2012, 07:58 PM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
WhalleyBoy - what motor and shroud are you running with that CS fan?
Old Oct 10, 2012, 08:25 PM
WhalleyB0Y's Avatar
Joined Jul 2011
Im using the Edfhobbies 2950kv motor
http://edfhobbies.com/index.php?rout...product_id=176
I paid the extra bucks for them to mount and balance the combo for me so that is was a drop in upgrade without fuss. So it is the Changesun shroud thats being used now.
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
Discussion New mini summit owner.. any tips? custom t Off-road Cars 16 Jul 05, 2012 10:03 AM
Discussion parkzone micro mods and owners thread flyguy99 Scratchbuilt Indoor and Micro Models 0 Jun 01, 2012 09:02 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 11:50 AM
Discussion Traxxas Slayer Owners/mod Thread corsair nut Off-road Cars 11 Nov 04, 2009 10:14 PM
