This thread is privately moderated by jpm1, who may elect to delete unwanted replies.
Old Jul 24, 2012, 05:40 PM
jpm1 is offline
Find More Posts by jpm1
jpm1's Avatar
Melbourne, Australia
Joined Sep 2010
supermarine S6B T. Nijhuis design
For those that are interested I thought I would start this and see what happens. I have almost finished building my first scratch build RC plane. Its not the first plane I have started but it will be the first one I finish.
The plans call for a 46 glow engine, but I have decided to go electric. I have an OS 750kv motor with a 12x8 prop and a 12x10, (see which is better) running off 4S 3600mah battery. AUW will be around 3kg.
I have custom made the floats from fibreglass (plans show balsa construction) and the fuselage is balsa and glass.
At this stage its 90% complete, with 90% still to go!
The day came and it was time to get it in the air. Have a look and read my first flight review and some more pics.
Video now up in the blog.
Well all good things must come to an end. Flight #2 everything ready to go, throttle up and off she goes along the grass. Lift off, nose up, severe roll to the right, over correct, roll to the left, over correct, roll to the right, stall and nose straight into the ground from about 30 feet up..
Damage report: pretty much a complete right off, engine and electronics salvageable as with the wing. One float OK. The rest hmmmmmmm.
To make the rebuild easier I'm now forming a plug for the fuse so I can make it out of Fibreglass.
Finally got around to checking to see if the motor and electronics were OK. Good news all OK. Prop shaft is straight and no vibration, just broke the prop. One good thing about having long floats sticking out the front I guess.
jpm1 is offline Find More Posts by jpm1
Old Jul 24, 2012, 06:29 PM
rudeboy579 is offline
Find More Posts by rudeboy579
" EMBRACE THE DARK SIDE '
rudeboy579's Avatar
Joined Nov 2011
looking good j.p.was guna stop after schoool but was over my day yesterday,so went home.great idea to start a blog
rudeboy579 is offline Find More Posts by rudeboy579
Old Jul 24, 2012, 08:34 PM
FastEddie65 is offline
Find More Posts by FastEddie65
PP Local Becoming a RC Loco
FastEddie65's Avatar
Australia, VIC, Dandenong North
Joined Jul 2011
Yes
Thanks Jp for taking the time to do the blog.
Love the photos and the build; hope to talk to you about it one day.
Fast Eddie
FastEddie65 is offline Find More Posts by FastEddie65
Old Aug 07, 2012, 02:22 AM
jpm1 is offline
jpm1's Avatar
Joined Sep 2010
some more photos of the build
Old Aug 08, 2012, 04:33 AM
rudeboy579's Avatar
Joined Nov 2011
the coming days are calling for that plane jp you might need to use it to get to work
Old Aug 19, 2012, 01:38 AM
jpm1 is offline
jpm1's Avatar
Joined Sep 2010
Well the day finally came, not quite ready but good enough to have a go any way. After some taxiing trials on the very wet grass and submerged cricket pitch and a little high speed hop (that proved flight was possible) And the thought that its got to fly some time.
I had spent most of yesterday finishing and fitting the ailerons and servos, getting the battery sort of secured and balancing the plane. I know I could keep fluffing around forever finishing stuff, but I woke up today to some overcast sky and a slight breeze. Off to PP first thing to find a few of the regulars that have been following my progress with this project. After a few words the taxiing trial, I thought it was time to give it a crack.
There are over 200 hrs in building this thing, as its the first scratch build I have done and mostly finished, and several hundred dollars in materials and components. I was nervous to say the least. Time had come, no turning back now. Plenty of people standing around offering encouragement with their cameras at the ready for the before and after shots.
Throttle up and away she goes, take off was pretty messy to say the least, (don't think I'll post the video) but it was up and flying. several clicks of down trim as the nose kept wanting to go up, even with the CG almost all the way forward 73mm. Did quite a few circuts and some quick stall tests, no really bad vises. In a stall it just dropped the nose. The hard thing was getting used to having 30% of the weight of the plane hanging under the wing and also creating a ton of drag. The floats add quite a pendulum effect, so turns need to be smooth and flat. I found it was very easy to get the plane porpoising, also need to add some expo into the controls.
That was all good, now time to land. Coming in on approach a bit high, luckly, as the wind had done a 180 on me. Go around again. Throttle back but she just wants to keep going, hmmmmmmmm. Go around again, throttle back and push the nose down. Contact and back on the ground with a couple of little bumps and hops. Still in one piece and a very relieved pilot
There is still a bit of tweaking to go, tidying up the lead on the front of the floats, painting the floats, etc, etc.... Then the challenge, real water instead of water logged grass and puddles.
Thanks to all those that have helped and given advice.
Old Aug 19, 2012, 02:00 AM
aerophilia is offline
Find More Posts by aerophilia
building building building!
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Awesome work mate. Looks incredible!!
aerophilia is offline Find More Posts by aerophilia
Old Aug 19, 2012, 02:36 AM
rudeboy579's Avatar
Joined Nov 2011
still f mad i missed it looks great j.p you did a great job mate.you should be proud of youself!you've put heaps of hours realising that project and seeing it up must have been very satisfying!good job mate!
Old Aug 24, 2012, 07:55 AM
MerlinV is offline
Find More Posts by MerlinV
Joined Mar 2009
Wow... I have been working on this for ages.
Great Job!
Adrian Whiter, treasurer of our club (Yarra Valley Aeromodellers) built this years ago. His finished model weighed 9 Lb or thereabouts. The maiden was a disaster. Write off.
He rebuilt it and it now hangs in a mates garage.
I have been lightening mine where I can. Going to I/C power it.
Where abouts are you JPM1?
Cheers,
Hugh
MerlinV is offline Find More Posts by MerlinV
Old Aug 24, 2012, 08:08 PM
jpm1 is offline
jpm1's Avatar
Joined Sep 2010
Great Job!
Cheers,
Hugh
Hi Hugh,
Thanks for looking me up again. I fly at the Police Paddocks off Stud Rd. Mine ended up at an AUW of 3200gms. Not sure what that is in the old measurement.
I took some of your example with the wing construction and ended up covering the wing in flim rather than compltely in balsa. It flys well but I still need to trim it properly. The floats do add quite a pendulum effect. I also need to dial down the elevator and ailerons as I had no expo and was flying straigt off the sticks. I tried to contact Tony Nijhuis, as I have bought some of his other designs. I haven't heard back from him yet. I would like to know what he suggests for all the control measurements etc....
I look forward to seeing yours finished and to compare notes.
JP
Old Aug 29, 2012, 04:45 PM
jpm1 is offline
jpm1's Avatar
Joined Sep 2010
J.P's S6b Maiden at PP 18/08/12 (1 min 52 sec)
video thanks to Dale. The first part was taxiing around to get a feel for it. The take off was pretty messy, but once up in the air it flew quite well. Landing not much better than the take off, but it's still in one piece!
Old May 08, 2013, 02:14 AM
jpm1 is offline
jpm1's Avatar
Joined Sep 2010
its not in one piece anymore
Build Log Supermarine Spitfire XIV - Brian Taylor plans - 69" wingspan Design75 Fuel Warbirds 21 Apr 14, 2014 10:58 PM
Build Log Supermarine S6B Dumas kit Ascolta Scale Kit/Scratch Built 140 Mar 28, 2014 02:30 PM
Discussion Tony Nijhuis Supermarine S6B Schnieder Racer. MerlinV Scale Kit/Scratch Built 10 Jul 10, 2012 11:32 AM
Discussion 2012 - Tony Nijhuis 72" Avro Lancaster Build TheHawklord Electric Warbirds 12 May 03, 2012 04:56 PM
Help! F-15 all balsa model designed by Tony Nijhuis Paul Bonati Pusher Prop Jet Models 13 Feb 14, 2009 07:43 PM
