Old Aug 21, 2012, 11:38 PM
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Hi guys, This is a Flight Power 6cell 50c 2600mAh battery in the nose and there is still room
super kupfer is offline Find More Posts by super kupfer
Old Aug 21, 2012, 11:59 PM
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
jcdfrd is offline Find More Posts by jcdfrd
Old Aug 22, 2012, 12:01 AM
Joined Jan 2010
Originally Posted by Double E View Post
I could almost imagine a Wemo 70 with intake lip mounted directly above the cheater hole and then clean it up with a custom hatch cover.
So basically turn the cheater hole into a hatch, correct?
Do you think that the fuse being empty as it is would be sufficient enough to work as a duct? It is not sealed as a duct would be (sorry not much experiance with this type of config)
a TJ70 with a 6cell would be sweet in this thing
Old Aug 22, 2012, 12:25 AM
Joined Jan 2010
This woud be sick in it (4.1Lbs of thrust)
http://www.tamjets.com/original/prod...roducts_id=686
BTW, I just tried to go with a bigger battery and a 6cell 3300mAh just made it in (just).
Old Aug 22, 2012, 02:00 PM
Beep...Beep...beep
imyohero's Avatar
waterdown,ontario
Joined Mar 2007
I think full ducting would be great, the inlets are around 100% fsa (hyperflow) maybe a little smaller with a good radius say 90%ish.
Again as with the evader to go to a bigger fan the tailcone is the real issue, to get the exit dia to the desired size will require some work maybe even as far as cutting off the cone completely or just a bit to open it up.
Lets toss a few more ideas out there for power systems
I would love to find a motor to push the hyperflow closer to 60k (currently 54-55,000) with full ducting!
Or a hayoe 64mm cut to fit an alfa 60mm housing.
maybe just the full hayoe 64mm or het 6404 with a dons or bigger motor dang it i just dont know! lol
Anyway as you can see by the pics super k posted this is a really well made kit, with lots of room for batts and with the wing being delta and the servos out of the fuse there is so much room for whatever direction you want to go!
imyohero is offline Find More Posts by imyohero
Old Aug 22, 2012, 02:23 PM
Joined Jan 2010
Not worried about the tailcone at all, If I go with the 70mm unit I intend to just remove the pre installed cone for the hyperflow and shorten the tailcone out to what is needed and just go with a mylar tailcone inside.
Old Aug 22, 2012, 02:43 PM
STANG KILLA SS's Avatar
Killeen TX
Joined Dec 2006
what is the ideal tail cone size for a 6904 etc?
STANG KILLA SS is offline Find More Posts by STANG KILLA SS
Old Aug 22, 2012, 05:44 PM
Joined Jan 2010
Personally I like Double E's idea on post #59 &60 but can someone else give me there 2cents on it?
Old Aug 22, 2012, 05:46 PM
Beep...Beep...beep
imyohero's Avatar
waterdown,ontario
Joined Mar 2007
around 55mm, the best youll get without shortening the outside tailcone is 49mm, might work tho sum one is gonna have to try it
Old Aug 22, 2012, 05:47 PM
Joined Jan 2010
Personally I like Double E's idea on post #59 & 60, but would it work without ducting?
Old Aug 22, 2012, 06:09 PM
Beep...Beep...beep
imyohero's Avatar
waterdown,ontario
Joined Mar 2007
I think it would, and you can always open the hatch back up if need be.
For me ducting is a fun project, I have nothing against the cheater hole and will probably fly it before installing ducting but i want to nail down what size fan to install so i can start a mould.
I really like the hot 64mm idea! I need a big outrunner, knife liddle style!
I wonder what a js1400 pulls in a 64mm on 4s and 5s
Old Aug 22, 2012, 06:38 PM
Joined Jan 2010
I wish I can say the same about the ducting but I have never tried making them.
Old Aug 22, 2012, 07:04 PM
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
I'm thinking a cs70/10 blade cut down to 65mm in a delta v-480 housing with a bl32 motor on 6s
65c 3300 nano .......whoooah!!!!
Old Aug 22, 2012, 07:20 PM
Atlanta, GA
Joined Mar 2009
I need another project like a hole in the head but I might have to go pick one of these up and see what I can do to work out a hotter setup.
Double E is offline Find More Posts by Double E
Old Aug 22, 2012, 07:22 PM
Joined Jan 2010
That all sounds good guys but why just not go with a 70mm unit?
Come on .........just cut the back.
Wanted Great Planes SU-31 E-Performance Series 3D EP ARF platnuim1 Aircraft - Electric - Airplanes (FS/W) 0 Jul 16, 2012 08:31 AM
Sold Great Planes Matt Chapman Eagle 580 GP/EP ARF 53" geebros Aircraft - Electric - Airplanes (FS/W) 1 Jun 25, 2012 09:50 PM
Sold or Trade Great Planes Revolver Sport Aerobatic GP/EP ARF 70" LPU donho1 Aircraft - Fuel - Airplanes (FS/W) 2 Apr 20, 2012 09:38 AM
Sold or Trade Great Planes Revolver Sport Aerobatic GP/EP ARF 70" LPU donho1 Aircraft - Electric - Airplanes (FS/W) 0 Apr 17, 2012 01:54 PM
For Sale RC Plane Great Planes Escapade Sport GP/EP (Plug-N-Play) $175 Diverrcpilot Aircraft - Electric - Airplanes (FS/W) 0 Mar 24, 2012 02:50 PM
