Old Aug 16, 2012, 03:15 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Early next week is the best I can do right now.
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Aug 17, 2012, 09:23 AM
STANG KILLA SS is offline
Find More Posts by STANG KILLA SS
STANG KILLA SS's Avatar
Killeen TX
Joined Dec 2006
looks like replacement parts are all available at tower, if one wanted to buy just the airframe....
http://www3.towerhobbies.com/cgi-bin...=GPMA1802&P=PU
STANG KILLA SS is offline Find More Posts by STANG KILLA SS
Old Aug 17, 2012, 10:46 AM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
For about $190 if you add up the basic airframe parts.
alexandermh is offline Find More Posts by alexandermh
Old Aug 17, 2012, 12:39 PM
flygilmore is offline
Find More Posts by flygilmore
Pro Bro #1963
United States, VA, Dublin
Joined Mar 2004
Wow... a bit pricey it seems. I sure do like the looks of this little jet!!
flygilmore is offline Find More Posts by flygilmore
Old Aug 17, 2012, 12:47 PM
Joined Dec 2000
You can buy the complete airframe with fan unit and Brushless motor for $179.00
at Tower.
http://www3.towerhobbies.com/cgi-bin...&I=LXCFVZ&P=ML
Old Aug 17, 2012, 01:10 PM
tulz43 is offline
Find More Posts by tulz43
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
at Tower.
Plus $20 off and free shipping right now. Hard to beat that.
tulz43 is offline Find More Posts by tulz43
Old Aug 17, 2012, 01:16 PM
Killeen TX
Joined Dec 2006
i noticed they give the top speed of this one 10mph slower than there evader with the same power setup. i wonder why?
thicker & larger wing? if you watch the two vids back to back its also imidiatly visiable.
Old Aug 17, 2012, 10:30 PM
imyohero is offline
Find More Posts by imyohero
F-OFF
imyohero's Avatar
Joined Mar 2007
Just picked up a phazer at my lhs, It sure is sweet, glass is perfect and the wing covering is really well done.
Pics to come!
imyohero is offline Find More Posts by imyohero
Old Aug 18, 2012, 03:24 AM View Post
colin269
A moderator felt this post violated the following rule: Cross-posting. Show it to me anyway.
Old Aug 18, 2012, 09:38 AM
imyohero is offline
F-OFF
imyohero's Avatar
Joined Mar 2007
The fuse is thicker and being a delta its got a little reflex(2-3mm up) on the elevons. so thats probably whats up with that
Old Aug 21, 2012, 01:17 PM
NeilRivera is offline
Find More Posts by NeilRivera
United States, FL, Kissimmee
Joined Dec 2008
Got my Phazer yeterday at my LHS. It was very well packaged. I already assembled the fan unit and installed it in the fuselage. Took me a couple of hours. It took some sanding to get the motor housing mount to fit properly and perfectly. Guys take your time on this step and make sure to follow the instructions on fitting and mounting the cone adapter. Any mistakes here after the glue sets and it will take a lot of time to correct it. Right now that's all I've done for the day, this jet can be put together fast ! Just for kicks i have a Wemotek unit laying around and measured it and the fuse, I am pretty sure it might fit but its going to take quite some effort to make it happen.... I'll keep posting on my build....
NeilRivera is offline Find More Posts by NeilRivera
Old Aug 21, 2012, 06:39 PM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
I got my little bird today and it looks siiiiiiiiick
My first impression were BIG as the planes scale is bigger then of the Evader as you can tell by the comparison to the evader, there is at least 10-20% more battery room in the nose, also there are nice touches like the blind nut for the screw that secures the battery tray to the fuse (On the Evader your screwing the battery tray directly to the wood and it wears off after some time), Vertical fin has a spare in it (due to size of vertical fin).
Over all, I like very much
super kupfer is offline Find More Posts by super kupfer
Old Aug 21, 2012, 06:46 PM
Joined Jan 2010
Here are some pictures of the fuses structure inside (very clean and simple with not much to deal with).
This thing is a winner as far as I see it, Bye Bye Evader.....Hello Phazer
Lots of room for ducting.
Old Aug 21, 2012, 10:20 PM
Double E is offline
Find More Posts by Double E
Double E's Avatar
Atlanta, GA
Joined Mar 2009
The inside of the airframe looks pretty clean so if you keep things neat during the build you don't really need ducting. Given the larger size, this would be a good candidate to squeeze in a hot 64 or 70mm setup.
Double E is offline Find More Posts by Double E
Old Aug 21, 2012, 10:33 PM
Double E is offline
Double E's Avatar
Atlanta, GA
Joined Mar 2009
I could almost imagine a Wemo 70 with intake lip mounted directly above the cheater hole and then clean it up with a custom hatch cover.
Wanted Great Planes SU-31 E-Performance Series 3D EP ARF platnuim1 Aircraft - Electric - Airplanes (FS/W) 0 Jul 16, 2012 08:31 AM
Sold Great Planes Matt Chapman Eagle 580 GP/EP ARF 53" geebros Aircraft - Electric - Airplanes (FS/W) 1 Jun 25, 2012 09:50 PM
Sold or Trade Great Planes Revolver Sport Aerobatic GP/EP ARF 70" LPU donho1 Aircraft - Fuel - Airplanes (FS/W) 2 Apr 20, 2012 09:38 AM
Sold or Trade Great Planes Revolver Sport Aerobatic GP/EP ARF 70" LPU donho1 Aircraft - Electric - Airplanes (FS/W) 0 Apr 17, 2012 01:54 PM
For Sale RC Plane Great Planes Escapade Sport GP/EP (Plug-N-Play) $175 Diverrcpilot Aircraft - Electric - Airplanes (FS/W) 0 Mar 24, 2012 02:50 PM
