This thread is privately moderated by davidterrell80, who may elect to delete unwanted replies.
Old Jul 24, 2012, 05:11 PM
davidterrell80 is offline
Find More Posts by davidterrell80
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
United States, VA, Round Hill
Joined Apr 2012
Polaris Seaplane
I've completed my first scratch build, the Polaris Seaplane
http://www.rcgroups.com/forums/showthread.php?t=922465
I had first flight last weekend and found I needed to re-check the down thrust. All else was good... very good.
David
davidterrell80 is offline Find More Posts by davidterrell80
Latest blog entry: General Aircraft Skyfarer
Old Aug 14, 2012, 07:41 PM
Joined Apr 2012
I've recycled my Polaris.
I've flown it exclusively off land and discovered that the lower-aft fuselage was prone to fail in tension when the fin would strike the ground. After three repairs, i'd had enough.
I do plan to make another and, when I do, I plan to make a few changes.
  1. Build the plane out of 10mm foam so I can forgo most/all internal bulkheads.
  2. Create an equipment bay in the vicinity of the CG that will contain all systems & servos.
  3. Run the rudder and elevator controls from the centrally located servos to the surfaces via Golden rods.
  4. Move the fin forward and add an additional thickness to the fin, making a stronger tie-in to the fuselage.
  5. Deepen the hull below the wing, slightly, without changing the fin; and, adding a skeg to the "transom" area to absorb land loads.
  6. Build the 125% scaled version.
Build Log Polaris Seaplane Parkflyer jetset44 Foamies (Scratchbuilt) 27467 Today 04:25 AM
Video Polaris rc seaplane on a lake dayg Electric Plane Talk 1 May 29, 2012 03:55 PM
Wanted Electric Seaplane (Polaris, Icon, Others?) StickHack Aircraft - Electric - Airplanes (FS/W) 5 Apr 24, 2012 03:57 PM
Discussion Model Aero Polaris Seaplane Auction Model Aero Hot Online Deals 1 Mar 11, 2012 11:28 AM
Discussion The Polaris Seaplane Parkflyer jetset44 Waterplanes 17 May 03, 2009 03:07 PM
