Old Jul 24, 2012, 03:12 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
5.8 GHz SpiroNET Antenna Set (RHCP)
Found these @ ReadyMadeRC . Anyone try these yet? I couldn't find a thread here about them. Thoughts? I like that they offer SOME protection and I am considering trying them.
Retail Price: $39.99
New SpiroNET 5.8GHz circular polarized antenna from ImmersionRC and FatShark.
Set includes Skew and Clover.
Right-hand circular polarization.
Unique design, not seen before in the FPV world. Far from the run of the mill 'basement production' seen to date.
Precision manufactured with very tight tolerances and 100% tested on a professional antenna tester (Rhode & Schwartz) to ensure maximum range and performance.
Antenna uses a high quality semi-rigid cable, that can be bent to any angle and maintain its shape in any orientation.
Extra long cable on the Skew antenna to clear your head (which blocks 5.8GHz emissions) for goggle installation.
The custom radome is RF-transparent, and protects the antenna from the occasional crash, or that oops moment when flying.
SMA connector compatible with all FatShark/ImmersionRC 5.8GHz products sold to date.
MCrites is offline Find More Posts by MCrites
Old Jul 24, 2012, 04:17 PM
IBCrazy is online now
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
They're the same as the Blubeams, actually. Nothing new. Just in an enclosure.
You will see something new at their store in about a month. Those on FPVLAB have had a first row seat in the development.
-Alex
IBCrazy is online now Find More Posts by IBCrazy
Old Jul 24, 2012, 04:24 PM
MCrites is offline
Joined Jan 2012
Thanks Alex, not sure if I could have asked for a better first answer!
Care to share info about the new item or shall I head to the google?
Old Jul 24, 2012, 08:36 PM
fatshark is offline
Find More Posts by fatshark
fatshark's Avatar
Shenzhen, China
Joined May 2007
I regularly fly out 2km with just a headset and 600mW TX with our CP antenna and don't get any breakup.
The average user will be very satisfied with the performance of these antenna and can be assured when they purchase that they are getting a tested antenna with low VSWR that will deliver great performance.
Fat Shark
fatshark is offline Find More Posts by fatshark
Old Jul 24, 2012, 08:52 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I'll announce it when the time is right. besides, Fat Shark and Immersion are copying me now. I need to do the best I can to make sure I have something better When the time comes, you'll know.
-Alex
Old Jul 24, 2012, 09:34 PM
bingo17 is offline
Find More Posts by bingo17
bingo17's Avatar
Auckland, NZ
Joined Sep 2009
very nice, practical and fair price.
bingo17 is offline Find More Posts by bingo17
Old Jul 25, 2012, 12:28 AM
Sad Sack is offline
Find More Posts by Sad Sack
What's a servo?
Australia, QLD, Brisbane
Joined Nov 2008
Reakon you can get into the enclosure for any repairs necessary?
I have found with the bluebeam type CP's is that long term high frequency vibrations can snap the centre conducter inside the coaxial dialectric right at the solder joint. You need to use hot glue or some other potting compound to dampen the vibrations.
Some antennas that are purchased from suppliers are already potted, some aren't.
Lets hope the soldering inside the enclosure is suitably potted.
Sad Sack is offline Find More Posts by Sad Sack
Old Jul 25, 2012, 07:12 AM
ImmersionRC is offline
Find More Posts by ImmersionRC
Joined Mar 2009
Easy to get into the radome, they are constructed from a two-piece 5G8-transparent plastic which with a squeeze in the appropriate place popps the top off.
In almost 1 year of development and testing with these we have never had the center conductor snap, so this shouldn't be a problem.
Initially we were concerned with the ability for the semi-rigid coax to handle being bent multiple times, but this has proven to be very robust, even during several minutes of intentional abuse they hold together nicely.
ImmersionRC is offline Find More Posts by ImmersionRC
Old Jul 25, 2012, 03:19 PM
MoFlyer is offline
Find More Posts by MoFlyer
United States, PA
Joined May 2011
Where can I find the technical specs on this antenna? RMRC is selling them without mention of any specs at all.
MoFlyer is offline Find More Posts by MoFlyer
Old Jul 25, 2012, 04:52 PM
KondorFPV is offline
Find More Posts by KondorFPV
home of the best antennas
United States, FL, Boca Raton
Joined Nov 2011
What about VSWR changes while bending the coax?
I use RG405 for fatshark mounted helicals, and VSWR does change when bent in different directions.
KondorFPV is offline Find More Posts by KondorFPV
Old Jul 26, 2012, 03:34 AM
Joined Mar 2009
VSWR will change, but not by anything significant at all. Its easy to get concerned about a 0.1 change in VSWR, but the effect on range is really insignificant.
When hooked up to a network analyzer the effect on VSWR of the relative positioning of the antenna element to the ground plane generated by the analyzer seems to have more effect than the mechanical changes in the semi-rigid cable itself.
Old Jul 26, 2012, 05:01 AM
Highflydotbe is offline
Find More Posts by Highflydotbe
Joined Nov 2011
Spironet + fatshark dominator
@ ImmersionRC Do you need an extra SMA 90 Angle connector (Male/female) to use this antenna on a fatshark dominator with the 5,8Ghz RX module?
Highflydotbe is offline Find More Posts by Highflydotbe
Old Jul 26, 2012, 07:48 AM
Joined Nov 2011
I am actually measuring 0.2-0.3 VSWR changes (and still the effect on range is rather minimal), but like you said it may well be the vicinity of the analyzer.
I would still not bend the semi-rigid coax more than 15-20 times (that's what I am telling people who get the rg405 option), the outer shield gets brittle and impedance characteristics could change in the long run, but I can't confirm that.
It's definitely not made to be constantly bent. I like your radome! nice design!
Old Jul 26, 2012, 02:37 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That's an understatement. Heck, 3:1 is still 80% efficient. 1.5:1 is 96%.
-Alex
Old Jul 26, 2012, 03:02 PM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
....dahumm Alex,
they copied you?.....
thats' not fair bud:-(
LexusFPV is offline Find More Posts by LexusFPV
Discussion A Better 5.8 Ghz off the shelf antenna? heinduplessis FPV Talk 16 Jun 23, 2012 06:22 AM
Sold 5.8 GHz Bluebeam Whip Antenna Set (RHCP) kevindl30 FPV Equipment (FS/W) 0 Jun 10, 2012 01:10 PM
Sold 5.8 GHz Bluebeam Antenna Set (RHCP) nybeechpilot FPV Equipment (FS/W) 2 May 29, 2012 03:16 AM
Sold 5.8 GHz Bluebeam Whip Antenna Set (RHCP) imagebuff FPV Equipment (FS/W) 1 May 16, 2012 12:10 AM
Sold IBCrazy 5.8 GHz Bluebeam Cloverleaf/Skew-Planar Wheel Antenna Set (RHCP) marzvt FPV Equipment (FS/W) 3 Sep 15, 2011 08:08 AM
