This thread is privately moderated by dawjr, who may elect to delete unwanted replies.
Old Jul 24, 2012, 02:05 PM
dawjr is offline
Find More Posts by dawjr
Trader Rating: 38
Jerk of all trades
dawjr's Avatar
United States, FL, Ocala
Joined May 2010
Trader Rating: 38
Sold
Trainer Cord - Futaba PCM/FM
Hey, Guys
I have this trainer cord from back in the day, here's a bit of info about it,
This is a Trainer Cord for Futaba old PCM & FM & J-Series Radios with the / round plug style (not the 2002 square plug -- FUTM4415). / / This trainer cord is designed to go between two transmitters for training / student fliers how to fly R/C aircraft. The trainer cord plugs into the / ""teacher"" transmitter first and then into a trainer compatible ""student"" / transmitter. The trainer switch on the teacher transmitter is used / or disable or activate the student radio. / / INCLUDES: One Black 10ft FM Trainer Cord
$10.00 shipped conus, pp
All the best, Don
dawjr is offline Find More Posts by dawjr
Old Jul 29, 2012, 03:11 PM
jheresz is offline
Find More Posts by jheresz
Trader Rating: 2
jheresz
United States, IN, Hobart
Joined Oct 2010
Trader Rating: 2
Hi Don, I have several hirec radios, the center dis. on the hites plug pins is about .275 inch
or 7 mm does that plug measure the same ? if it is how do I send funds ?
regards, john
jheresz is offline Find More Posts by jheresz
Old Jul 29, 2012, 06:51 PM
dawjr is offline
Trader Rating: 38
Jerk of all trades
dawjr's Avatar
Joined May 2010
Trader Rating: 38
Hey,Buddy. These pins are about an 1/8" center to center between any two pins and over the outside of the metal barrel its about .518 or so. Paypal works for funds. Let me know if you think it will work and send me a PM and I'll give you the PP info.
Old Jul 29, 2012, 10:15 PM
jheresz is offline
Trader Rating: 2
jheresz
Joined Oct 2010
Trader Rating: 2
Don the pin c/l dis. and plug dia. look ok send me the pp info.
regards john !
Old Jul 29, 2012, 10:22 PM
4*60 is offline
Find More Posts by 4*60
Trader Rating: 19
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
Trader Rating: 19
Whoah guys. I think you can smoke Hitec Eclipse etc radios with a Futaba trainer cord. I believe Hitec had a master and slave end and called it a one way cord. Do a search. I will try to find reference myself. We smoked one at our club.
http://www3.towerhobbies.com/cgi-bin...P?I=LXN740&P=8
4*60 is offline Find More Posts by 4*60
Old Jul 29, 2012, 10:32 PM
4*60 is offline
Trader Rating: 19
most exalted one
Joined Aug 2002
Trader Rating: 19
http://users.belgacom.net/TX2TX/tx2t...h/tx2txgb3.htm
Is one site with warning. And......
Note from Hitec found on their site http://www.hitecrcd.com/Radios/RadioHome.htm
Important Information Regarding Trainer cord compatibility
To our valued customers,
While Hitec radios are known to be trainer compatible with other Hitec and Futaba systems, Hitec has determined that the two-way Futaba cord is not 100% compatible with our systems and strongly suggests it not be used at any time. Our tests show that when the Futaba trainer cord is used with a Hitec radio the slave transmitter will emit an RF signal, thus creating a potentially dangerous interference situation, and in some cases will burn up components in the slave and or master radio. Hitec suggests that only the one-way Hitec trainer cord (#58310) be used with Hitec radio systems for training. Failing to do so will void the customers warranty and could create a potentially dangerous situation. Hitec apologizes for any inconvenience this may cause, but the safety of our customers is our utmost concern.
Old Jul 29, 2012, 11:06 PM
jheresz is offline
Trader Rating: 2
jheresz
Joined Oct 2010
Trader Rating: 2
My hitec radio's are flash 4/5 the ref. you gave to tower was for a dif. radio,
the cord probably will not be used for" trainer" but will be used to convert to
2.4, rather than soldering , plugs to be used .
john
Found Futaba trainer cord Bugman Jeff Aircraft - General - Radio Equipment (FS/W) 2 Jul 21, 2012 12:59 AM
Wanted Trainer cord for futaba. moe money Aircraft - General - Radio Equipment (FS/W) 2 Jun 25, 2012 08:56 PM
Sold Futaba Radio Trainer Combo T6EXAP PCM With T4YF And Trainer Cord rarner Aircraft - General - Radio Equipment (FS/W) 3 Aug 20, 2009 12:38 AM
Sold Trainer cord for FM Futaba Square (micro) to Round (DIN) hauntfreaks Aircraft - General - Radio Equipment (FS/W) 0 Aug 12, 2005 07:24 PM
For Sale Futaba 7AUP radio (PCM), 2 PCM rxs, trainer cord and 4ch pcm tx dr.E Aircraft - General - Radio Equipment (FS/W) 0 Jul 31, 2005 09:52 PM
