Old Jul 24, 2012, 03:17 AM
hellokittyhk is offline
Find More Posts by hellokittyhk
Joined Jul 2011
Please advise on kite string
Hello.
I recently purchased a new kite, but need some string for it.
It's the most basic, pure kite, and is really just a triangle with a few spars in it.
The bottom edge is approximately 2m long and it's about one meter tall. Aside from that it has a little bit (200g - 300g) of lights and batteries on it.
I expect to need about 1000m of string, but I don't know what kind to buy and where to buy it.
Please keep suggestions as low-cost as necessary, but solid.
Also it's the kind where you just stuff in two halves of a spar into those little pockets and then put them together, but I'm always afraid of tearing the kite or breaking the rod when I'm putting it in. Tips/suggestions? I believe the rods are fiberglass but I am not sure. The material I think is some sort of nylon.
hellokittyhk is offline Find More Posts by hellokittyhk
Old Jul 25, 2012, 01:55 PM
Joined Jul 2011
I'd like to get this done before summer is over...
Old Jul 29, 2012, 04:47 PM
inventing_man is offline
Find More Posts by inventing_man
Whats a search engine?
inventing_man's Avatar
Missouri
Joined Jun 2006
Im using a braded fishing line like Spider wire 25 pound test on a 2 string stunt kite . (That ='s 50 pound total pull ) of about the same size . works good and cheap . Kites are tuff , dont worry about getting the spars in .
inventing_man is offline Find More Posts by inventing_man
Old Dec 17, 2012, 10:15 AM
Cyberdactyl is offline
Find More Posts by Cyberdactyl
Misfit Multirotor Monkey
Cyberdactyl's Avatar
United States, NC, Garner
Joined Mar 2011
I know this is months later, but the string generally used in kites is called "Spectra". Fishing line has too much stretch. And when flying a 2 or 4 string kite, you want as little stretch as possible to increase control.
Cyberdactyl is offline Find More Posts by Cyberdactyl
Old Feb 12, 2013, 02:30 AM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
In the US it's called spectra in Europe it's called dyneema. Same thing though. It's used because of it's high strength and low friction (you can wrap the lines a dozen times and still be able to control the kite) You have to prestretch it before use otherwise the lines stretch out over time and your lines end up being different lengths. Even if it says that it's prestretched I found that I still needed to stretch it. There is also a polyester/spectra blend that's cheaper but I'd recommend just getting the spectra.
If you cross spectra lines with dacron kite line (usually used on single line kites) the dacron will cut the spectra like a knife. Spectra has a very low melting point and friction between it and anything else will cut it very easily. It's fine when crossed with itself because of it's low friction (which happens a lot when you loop the kite and the lines wrap each other multiple times)
Before I got into RC I was into quadline sport kites. Haven't flown them in years though.
Spectra Sport Solution, one of my favorites. Made back in the early 90's and wasn't very popular so they only did one short production run. (kite in picture isn't mine but I have several just like it in the back of a closet)
Atomic Skull is offline Find More Posts by Atomic Skull
Old Feb 12, 2013, 08:36 AM
Joined Mar 2011
I too did a LOT of flying in the early and mid 90's. I still have a 6ft 'Hawaiian' and also a 6ft parafoil.
Old Feb 12, 2013, 11:01 PM
Joined Dec 2011
I have a stack of 6 Solutions, a Revolution EXP, a Revolution Shockwave, an Alpha+ and a Jeager. The shockwave needs a new center spar and the Alpha needs a new nose assembly. I got the solutions cheap around 1999 when Gone With The Wind Kites got a bunch of them in that had been sitting in a warehouse somewhere for years and sold them for $50 each (they originally retailed for $250)
And wow the Alpha+ is still being made.
EDIT: And wow when did Prism's kites come so far down in price? Prices are way down on stunt kites. (well except for Revs, those are as expensive as ever)
Help! A sensitive plea for help.... David A Ramsey Life, The Universe, and Politics 147 Jun 27, 2012 09:01 AM
Discussion where do I string the antenna wire on the LT 711 flyman065 Coaxial Helicopters 2 May 18, 2012 04:57 PM
Help! Pleas Help! Need info on USA car size quick! fooesboy Slope 9 Aug 04, 2008 01:23 PM
Discussion Thoughts on an Alany MM - and a plea for help? Smi Micro Ready-to-Fly 9 Jul 15, 2007 12:59 PM
Discussion Feasable to replace kite string with prop? ghoti Aerial Photography 4 Feb 12, 2007 08:09 AM
