Old Feb 23, 2013, 05:34 AM
SkippyTBK is offline
Find More Posts by SkippyTBK
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Nov 2011
Anyone have this problem loading the firmware. Is there a new upgrade tool? If there is where do I download it from?
Originally Posted by SkippyTBK View Post
For some reason the new firmware isnt loading or it doesn't seem to be. Once I turn on to reset I just get this 4 lines with the last one saying YS-X6 is now booting.
SkippyTBK is offline Find More Posts by SkippyTBK
Old Feb 23, 2013, 06:03 AM
mlebret is offline
Find More Posts by mlebret
mlebret's Avatar
France, Bretagne, Combrit
Joined Mar 2005
Originally Posted by robone View Post
Just check that your battery is set to 3S because at the moment it looks like it is set to 4S
I will have a look before next flight. Latest check showed 3S.
Marc
mlebret is offline Find More Posts by mlebret
Old Feb 23, 2013, 06:33 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Yes there is a new upgrade tool and it can be downloaded from the 1st post in this thread
robone is offline Find More Posts by robone
Old Feb 23, 2013, 11:41 AM
mlebret is offline
mlebret's Avatar
Joined Mar 2005
Hi Rob,
I had a flight today (no sun, 4C outside with 11 kts wind) and here is the log.
I also checked the number of cells in the setting: I confirm 3 cells.
According to my today's log, I will have to check the symmetry (verticality) of my motors: autopilot is always applying right rudder.
Enjoy austral summer,
Marc
Old Feb 23, 2013, 04:03 PM
whizz101 is offline
Find More Posts by whizz101
Joined Aug 2012
what's in the latest firmware???
whizz101 is offline Find More Posts by whizz101
Old Feb 23, 2013, 09:08 PM
Joined Nov 2011
I have been away for a few months so trying to catch up on the updates etc.
I assume now with the new Wifi setup the wireless data modules are no longer needed? Just connect the Wifi direct to the FC? If that the case what range does the WiFi have? I would have assumed the data modules have a further range?
I have installed the android phone aps update but now it constantly reads out the altitude. Any way to turn this off?
Also the new update tool I downloaded from this thread has no text on the buttons and only ????? for the text. As well the upgrade tool is not available on the Zerouav web site. ( Poor service for an expensive product!!)
Can you advise why my PC GCS reads "Locked Radius 20m" when I have the professional 50WP version upgrade? Also only shows 1/5WPs
And lastly the user manual is getting even worse with all the messy updates to it. There is no intuitive flow from start to finish and its all over the place. Isn't it due time to do a full rewrite of this manual and clean up and also fix the bad English?
Old Feb 23, 2013, 09:11 PM
Joined Nov 2011
YS-X4-20130101-Enc.arm
Old Feb 23, 2013, 11:16 PM
Joined Nov 2011
I still cannot load the new firmware and I have even tried the new upgrade tool. IGNORE this post, I was trying to install wrong firmware.
Old Feb 24, 2013, 12:01 AM
richkphoto is offline
Find More Posts by richkphoto
United States, MN, St Cloud
Joined Jan 2012
I think that firmware is for the x4 not the x6
richkphoto is offline Find More Posts by richkphoto
Old Feb 24, 2013, 12:47 AM
Joined Nov 2011
dito!! so obvious once you pointed it out..its been a long week/month.
Old Feb 24, 2013, 02:27 AM
mlebret is offline
mlebret's Avatar
Joined Mar 2005
On first page:
http://www.rcgroups.com/forums/showa...6&d=1361329311
YS-X6-20130205
�� YS-X6 Firmware (YS-X6-20130205)
* The rate of copter climb and decline is increased to 4m/s, Max. 5m/s.
* The stability of takeoff and flying is greatly improved, waypoints flying is more
accurate.
* Channel7 can be used for setting up the pitch and roll of gimbal, so that
Channel8 is available for user-define.
Old Feb 24, 2013, 05:29 AM
Joined Nov 2011
the upgrade tool doesn't have any text on the buttons , only ???? and same on the info line
Originally Posted by mlebret View Post
On first page:
YS-X6-20130205
accurate.
Old Feb 24, 2013, 07:59 AM
Joined Jan 2012
I haven't loaded the new one yet ,but there was a button < I think in the top right corner for english
Old Feb 25, 2013, 01:13 AM
mlebret is offline
mlebret's Avatar
Joined Mar 2005
Hi Rob,
Marc
While checking the number of cells, I also discovered that my Hexa was configured as a QuadX (type1) instead of HexaX (type3).
May be an error while reading the chart (mental viscosity) or a return to defaults settings while upgrading firmware or pressing a button on the CGS.
Is there a way to check this setting in the flight log?
Strange but sure: it was flying like that, maybe due to the design of my craft.
Marc
Old Feb 26, 2013, 02:47 AM
ise2012 is offline
Find More Posts by ise2012
ZeroUAV
ise2012's Avatar
Australia, SA, Tarcoola
Joined Jul 2012
you can use the pc gcs to analysis the hj file
Originally Posted by DVE View Post
I'm wondering, why Zero UAV cannot share any log visualization tool (sure thay have it, and using for development process), it may be useful for testing problems like this. I asked them by email, and didn't got an answer.
hi ,my friend ,
you can use the pc gcs to analysis the hj files , we use the same software , only the Language is not different ,
ise2012 is offline Find More Posts by ise2012
Site Sponsor
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20279 Aug 21, 2016 06:18 AM
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2428 Mar 23, 2016 02:52 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 04:35 AM
