Old Feb 10, 2013, 08:44 AM
apache74 is offline
Find More Posts by apache74
apache74's Avatar
France, RA, Bossey
Joined May 2011
Originally Posted by maximus-rc View Post
Nouvel an chinois, nos amis font la fête !!!
A+
Maximus
Oui je sais, leur nouvel an a commencé aujourd'hui.
C'était juste un rappel de mon post du 4 fev.en même temps que je l'ai fait
sur un autre fil ici.
Et toi tu n'aurais pas un début de solution?
Je t'avais mis un MP mais je n'ai pas eu de réponse.
Bon Dimanche
apache74 is offline Find More Posts by apache74
Old Feb 10, 2013, 09:09 AM
maximus-rc is offline
Find More Posts by maximus-rc
RTF copters maker
maximus-rc's Avatar
South France
Bon Dimanche
Je ne suis pas sur que le ppm soit déjà supporté...
Tu as le dernier firmware ?
maximus-rc is offline Find More Posts by maximus-rc
Old Feb 10, 2013, 10:52 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
I just did a translation for the others.
I'm not sure the ppm is already supported ...
You have the latest firmware?
I agree, I know that the new Quick start manual has the PPM port defined, but, whether it is in the latest FW or not I do not know.
robone is offline Find More Posts by robone
Old Feb 10, 2013, 01:38 PM
wessiercgroups is offline
Find More Posts by wessiercgroups
Joined Apr 2011
I didnt see any reply nor comments to my above post.
Nobody had a similar/same issue?
I am still stucked with this problem.
Any idea/solution? Help please!
@ ZeroUAV
Did you read this post Mr Zero UAV? Why don't you reply?
Can't you help?
Hi apache74 - It's the Chinese new year and I don't think anyone at Zero UAV is currently monitoring this thread. I'm sure they will reply when they get back on the 20th of Feb. Unfortunately I've never used the PPM function so I cannot help.
wessiercgroups is offline Find More Posts by wessiercgroups
Old Feb 10, 2013, 01:44 PM
Joined Apr 2011
Somersault
Bit of an incident today. Yesterday I was testing my hex after upgrading to the 16 way-point firmware. Everything checked out fine – except for the way-point upload issue – and I decided to stiffen up the values on Pitch and Roll sensitivity. Roll was on 80 and Pitch on 100 – I normally get the hex to hover in position hold and alt, then give it a light tap from underneath on one of the legs to see how quick it recovers. With the settings above it still had a slight wobble. I changed the setting to 100 for Roll and 120 for pitch. This time I just jerked the elevator and aileron stick on the Tx and the recovery was almost instant without any wobbling. I did a couple of circuits and the retired the hex for the day.
Today I went out to the field to do some high altitude photography. Everything went as planned and the hex stability drew some attention from the rest of the guys out flying. I demonstrated the RTL capability and auto land. Then proceeded to hover full auto about 2 meters off the ground. Did the usual – pulling the hex off position to demonstrate how it actual returns to its original position. I then decided to give it the usual tap under the right rear landing strut – I taped it and it countered the tap but then shot forward doing just about a complete somersault, hitting the ground. It seemed to me that it over corrected itself – when in to the “over 45deg tilt” and shut the motors down. All this happened in a split second. Could I have over adjusted the stability settings? The manual says that if you set them to high you will experience oscillation. The hex suffered two bent booms and two broken carbon fiber props.
Old Feb 10, 2013, 02:16 PM
robone is offline
Joined Sep 2010
Hi Wessie
Sorry to hear about your mishap.
When I had a chat to support about what settings to adjust to get better recovery and to get rid of wobbles in Position Hold mode they told me:
1. First adjust the Overload control from soft to hard
2. Then adjust motion compensation higher in increments of 10
Which seemed to work for me.
Not sure how adjusting the Pitch and Roll sensitivity will work. As far as I understood it, it was to adjust your Tx response. But I am learning all the time.
Rob
Old Feb 10, 2013, 07:01 PM
apache74 is offline
apache74's Avatar
France, RA, Bossey
Joined May 2011
Non juste celui d'avant. Je vais installer le dernier en date et voir.
No, just the one before last one. Will install the latest one and see.
Old Feb 10, 2013, 07:11 PM
apache74 is offline
apache74's Avatar
France, RA, Bossey
Joined May 2011
tks Robone for yr translation.
No, I did not install the latest FW yet. I saw already in the previous Quick start guide that PPM was supported.
In the Android GSC this option is in the choices as well.
I therefore was convinced that PPM should work.
However will install now the latest FW, and hope it works this time.
Will keep you posted guys. I think this info should be of great interest for a lot of people.
Old Feb 10, 2013, 07:23 PM
apache74 is offline
apache74's Avatar
France, RA, Bossey
Joined May 2011
Tks for yr reply and infos.
I knew that its Chinese New Year. It was just a reminder of my previous post
However as already written to Maximus and Robone I will try in the meantime with the lastest FW and hope it will work.Keeping you posted anyway.
PPM is an interesting option for me.
I used to use it on my Hex under Flyduino and I must say i found it very convenient, particularly for Hexa's and Octos.
One wire instead of 6 or 8 avoids cable salad and allows RX to be put at the optimal place without having to extend 6 or 8 wires from RX to AP.
Old Feb 11, 2013, 11:55 AM
bobo82 is offline
Find More Posts by bobo82
Poland, Kuyavian-Pomeranian Voivodeship, Torun
Joined Feb 2013
Hello.
I woudl like to know YS-X4 is OK? Is somebody from Poland?
bobo82 is offline Find More Posts by bobo82
Old Feb 13, 2013, 07:04 PM
Reginak is offline
Find More Posts by Reginak
Reginak's Avatar
Joined Jul 2011
Is anybody flying a big octo? If yes, could you share your PIDs?
Reginak is offline Find More Posts by Reginak
Old Feb 14, 2013, 12:21 AM
rwijnhov is online now
Find More Posts by rwijnhov
Netherlands
Joined Feb 2009
Yes ys-x4 is ok.
rwijnhov is online now Find More Posts by rwijnhov
Old Feb 14, 2013, 08:59 AM
Reginak is offline
Reginak's Avatar
Joined Jul 2011
Well, I'm ready for my maiden flight with my octo + ys-x6. But I have a question, I've already calibrated my throttle inside the GCS, no problem here. I'm using SimonK ESCs.
The problem is that my front motor (OCTO +) is starting with a delay, all the other 7 motors starts at the same time, but I have to push the throttle a little more to start the front motor.
Is there a way to correct this? The calibration is ok, but the motor still delayed. I've swapped ports 1 and 2 in YS-X6 to test if the problem was from ESC/MOTOR and found that the motor 1 still has a delay in relation all others so the problem seems to come from either the motor or the ESC...
Is there a way to solve this?
Old Feb 14, 2013, 10:32 AM
holco is offline
Find More Posts by holco
holco's Avatar
The Netherlands
Joined Mar 2007
Can someone help me out please?
Calibrated the ESC's with trottle direct on the rx, all fine, but the ESC's need a positive puls for full trottle and can't be reversed, the YS-X6 needs a negative puls for full trottle and as far as I can see can't also be reversed, result is that non of the motors wil run.
Tried also to calibrate the ESC's direct on the YS-X6 but can't get a max trottle puls that is needed to get the ESC's in trottle calibration mode, I am lost
And yes I have RTFM
Btw, I have nothing that can run Android software, only windows laptops and a Imac/Ipad.
holco is offline Find More Posts by holco
Old Feb 14, 2013, 11:02 AM
dasrustler is offline
Find More Posts by dasrustler
dasrustler's Avatar
Joined Nov 2011
What radio are you using?
dasrustler is offline Find More Posts by dasrustler
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20274 May 20, 2016 12:54 PM
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2428 Mar 23, 2016 02:52 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 04:35 AM
