Old Dec 27, 2012, 01:51 AM
South Africa, GP, Johannesburg
Joined Sep 2010
Originally Posted by Willie View Post
The follwing I found on my friends website www.multirotor.com. I hope this will answer your second question.
I think he means www.multirotor.co.za
robone is offline Find More Posts by robone
Old Dec 27, 2012, 01:57 AM
Netherland
Joined Mar 2003
Sorry yes
Willie is offline Find More Posts by Willie
Old Dec 27, 2012, 11:30 AM
teryn1's Avatar
Tucson, AZ
Joined Aug 2004
Willie, thanks....now I am getting a situation where the wifi light flashes solid, then 3 blinks, then solid, then 3 blinks…continuously (?) GCS still can't see the wifi signal
teryn1 is offline Find More Posts by teryn1
Old Dec 27, 2012, 12:15 PM
Netherland
Joined Mar 2003
Hi Teryn
Is this from your PC or Note II?
Regards
Willie
Old Dec 27, 2012, 12:17 PM
teryn1's Avatar
Tucson, AZ
Joined Aug 2004
From PC.....not even close to getting the Note phone to work yet
Old Dec 27, 2012, 12:23 PM
Netherland
Joined Mar 2003
Ok Which router are you using and what is your router IP address set to?
Old Dec 27, 2012, 12:34 PM
teryn1's Avatar
Tucson, AZ
Joined Aug 2004
d-link 150, 192.168.1.1
Old Dec 27, 2012, 12:40 PM
Netherland
Joined Mar 2003
3 Questions
1. The flashing lights on the wifi unit on your YS-X6, is it flashing red or blue?
2. What is the SSID of your Router?
3. What is your secrity code?
Old Dec 27, 2012, 12:45 PM
teryn1's Avatar
Tucson, AZ
Joined Aug 2004
1) blue
2) YS-X6-<serialnumber>
3) 82890430
Old Dec 27, 2012, 01:12 PM
Netherland
Joined Mar 2003
I have read somewhere that the D-Link router is not working but as I use a TP link I can not confirm this. It might be worth it do do a search on that.
On my YS-X6 the blue light goes solled afer about three seconds after swiched on. If I switch the router off the Blue light will start flashing till i switch the router on and it will connect again after a few seconds.
I have also configured my Blackberry phone to act as a wifi router and it will connect to it after a few seconds and i can get the data on the PC through the router or BB.
you can try to connect directly to your YS-X6 directly by plugging the PC cable into the com 3 on your YS-X6 (unplug your wifi unit), configure your comport in the GCS software under options to 115200 baud 8 n 1 and the connect in the files tab to the commport to see if you have dataflow.
Regards
Willie
Old Dec 27, 2012, 01:35 PM
Joined Sep 2010
If you have a look at the post here http://www.rcgroups.com/forums/showp...postcount=1006 you will see that ZeroUAV say the D-Link router does not work because of the IP addresses.
All I know is that the TP-Link routers work and the Linksys router works. They are quite cheap and saves you getting a headache. Maybe worth while getting one
Old Dec 27, 2012, 02:17 PM
teryn1's Avatar
Tucson, AZ
Joined Aug 2004
ok, thank you guys for the input... I will try another router
Old Dec 27, 2012, 02:56 PM
Joined Jan 2012
Buffalo routers seems to work fine too.
KariY is offline Find More Posts by KariY
Old Dec 28, 2012, 05:40 PM
Joined Dec 2012
I am curious to know two things:
1. Will the WiFi on the YS-X6, operating at 2.4GHz interfere with my Spektrum radio also at 2.4GHz?
2. When will the extenders for the WiFi be available to take the default range from the advertised 300m to ~5000m?
Thank you.
kalsc is offline Find More Posts by kalsc
Old Dec 28, 2012, 11:43 PM
Netherland
Joined Mar 2003
Thank you.
It does not interfere with any of the other 2.4GHz radios so I m sure it will work just fine. I suggest you do a range check.
I am not sure which WiFi exstenders you talking about but I bought mine here http://multirotor.co.za/?wpsc-produc...-uav-data-link . With this you move away for 2.4GHz if you are worried about interference.
Regards
Willie
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 18056 Yesterday 07:12 PM
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2209 May 14, 2013 01:06 PM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 04:35 AM
