Old Dec 09, 2012, 04:05 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Originally Posted by CheChe156 View Post
Hello all,
I am seting up a YS-X4 and it wont arm. I am not sure about the "Parameter Define" as
they are all '0'.
can someone help with this?
I am not sure if you are talking about Customzed Paramters for your motor mix or the Parameter setup.
The Customized parameters is only used if you are setting up your own motor mix. Leave this alone and set the Aircraft type only in Parameter Setup.
If you look at Parameter setup, and all the numbers are 0 then you must press the "Get" tab to get the parameters from the YS-X4. Once you have changed them you have to send them back to the YS-X4.
If you used the Install Guide to setup your system?
Edit: I see you have got it working
robone is offline Find More Posts by robone
Last edited by robone; Dec 09, 2012 at 04:07 AM. Reason: Info not required anymore
Old Dec 09, 2012, 11:43 AM
CheChe156 is offline
Find More Posts by CheChe156
Bermuda
Joined Feb 2002
Thanks Robone'. My throttle calibration was not done correctly, so it wouldn't arm.
CheChe156 is offline Find More Posts by CheChe156
Old Dec 09, 2012, 12:06 PM
Dreidekker is offline
Find More Posts by Dreidekker
Joined Dec 2012
Hello again.
I hope somebody can help me. I have problem with the Wifi unit. I have a D-Link router and it is something wrong between my android pad and the YS-X6 Wifi unit. The GCS says communication Disconnected and I donīt understand why. I bougt a new router, a new pad and a get the same information, communication Disconneted.
I got it work together a short time with my PC and the GCS program, but not anymore. I'm lost. Please give me a hint to solve what I have done wrong.
Best regards
Lars Dahlstrom
Dreidekker is offline Find More Posts by Dreidekker
Old Dec 09, 2012, 12:54 PM
robone is offline
Joined Sep 2010
Have you all seen the the ZeroUAV promotion for Christmas and New Year. http://www.zerouav.net/newsmore.aspx?id=110
There are some good offers there.
Old Dec 09, 2012, 01:08 PM
robone is offline
Joined Sep 2010
Originally Posted by Dreidekker View Post
Hello again.
Best regards
Lars Dahlstrom
Have you tried setting up the router as a hotspot and connecting directly to the wifi module?
Sometimes I have found certain routers just do not work. don't ask me why. I think it is someway that they set up the security on the router. That is why I always use the TP-Link router which always seems to work.
Old Dec 09, 2012, 05:08 PM
Joined Dec 2012
Hello,
No, I haven't. Something is suspect here, because I got it working for a while, but then it didn't. The blue LED is on.
Hotspot... I have to find out how it works. Maybe I will buy me another router tomorrow, a TP-link. I donīt know. I don't think it is any fault on my D-Link router. Any more suggest?
Old Dec 10, 2012, 08:58 AM
Tuomas P. is offline
Find More Posts by Tuomas P.
Finland
Joined Apr 2007
I relocated the IMU into the top of the MC and it seems to fly much better now. Great! Now...my PC GCS will not show me the map eventhough I have internet access. How can I get the map?
TP.
Originally Posted by robone View Post
I am not saying it wont work, but a number of people I know who did that, had problems with interference. It is a better policy to locate the IMU above the MC
Cheers
Rob
Tuomas P. is offline Find More Posts by Tuomas P.
Old Dec 10, 2012, 11:03 AM
KariY is offline
Find More Posts by KariY
Finland, Uusimaa, HKI
Joined Jan 2012
TP.
Try this one:https://dl.dropbox.com/u/2380926/YSwifi20121115.rar
KariY is offline Find More Posts by KariY
Old Dec 11, 2012, 08:24 AM
mlebret is offline
Find More Posts by mlebret
mlebret's Avatar
France, Bretagne, Combrit
Joined Mar 2005
Nice goodies, but can you give us some clarification: I try to get a 10 waypoints upgrade for my YS-X6 unit but got a message from Vivien saying I needed to also have an YS-X4 to be eligible?
It's like I read "OR" when ZeroUav is reading "AND".
2. YS-X6 & ZERO-Steadi470 Owners if buy YS-X4 WIFI Version, can upgrade
to Navigator Version for FREE of charge. Meanwhile, can get FREE 10
waypoints activation on its owned YS-X6 & ZERO-Steadi470 by providing
serial number and related information.
7. All buyers if buy YS-X6 Basic (4 waypoints version), can get 10 waypoints
activition for FREE of charge
Thanks for your help,
Marc
mlebret is offline Find More Posts by mlebret
Old Dec 11, 2012, 08:31 AM
robone is offline
Joined Sep 2010
Marc
When did you buy your YS-X6, because that will determine if you can get the upgrade under item 7. If it was after 6 dec then you should be able to get it. Under item 2, you can only get that upgrade if you buy a YS-X4 wifi version
Old Dec 11, 2012, 08:37 AM
Joined Dec 2012
Hi,
I bought a TP-link and now it works fine. Just trying to learn about the system.
Old Dec 11, 2012, 10:39 AM
mlebret is offline
mlebret's Avatar
Joined Mar 2005
No free upgrade for me, if the free upgrade is only for items purchased from dec 6 to january 5. I have a second hand YS-X6 (may 2012), and understood that promo was for YS-X6 owners without date of purchase restriction but only date of request limit (Christmas gift for happy old users...).
Marc
Old Dec 11, 2012, 11:02 AM
Joined Dec 2012
Hi,
Things starts up to work step by step, but I can't get the Google earth running in the GCS properly. I have some problems both with my PC and with my android pad. I think I have the latest version on both devices.
On the pad it reads "loading map" but it is not loading. What am I doing wrong? On the PC it gets stuck when I click on "locate airplane"
Old Dec 11, 2012, 03:00 PM
robone is offline
Joined Sep 2010
Originally Posted by amtech View Post
Here are the 3DR (ground) to wifi module diagrams...
Hi Amtech
If you do not want to use the wifi module, can you just connect the USB connection to the PC?
I now have all the parts and will begin wiring up over the next few days. I am thinking for the Ground side, I will 1st test using the usb connection and then wire up the wifi module.
Cheers
Rob
Old Dec 12, 2012, 12:47 AM
Zero UAV is offline
Find More Posts by Zero UAV
Joined May 2012
About PC GCS Map
TP.
Hi,
Have a try referring to the instruction, maybe it helps.
Zero UAV is offline Find More Posts by Zero UAV
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20278 Jul 17, 2016 12:38 AM
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2428 Mar 23, 2016 02:52 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 04:35 AM
