Old Dec 05, 2012, 12:37 AM
SkippyTBK is offline
Find More Posts by SkippyTBK
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Nov 2011
Yes I think this is whats happening, though strange I can still receive the live data from the copter on both PC and phone at the same time, just I cant download the PIDs.
Anyway the first comment on that post you sent solved this and its pretty much what I had in mind to try out.
Quote,
"This is great tutorial but there is a way to connect multiple UART receiving/transmitting devices on the same bus.
Master’s transmit line connects to all receivers rx line as usual.
Each Slaves' transmit line connects to a reverse diode -diode’s negative pin to slaves tx- and positive end of the diode to bus"
Unquote.
It has a link to a schematic diagram for it as well.
Originally Posted by Mr_westie View Post
It's a hardware thing.
1 TX can connect to 2 RX's.
But 2 TXs can not connect to 1 RX without some modification.
Will find and post.
edit:
Found it
http://www.sparkfun.com/tutorials/224
SkippyTBK is offline Find More Posts by SkippyTBK
Old Dec 05, 2012, 01:32 PM
Tuomas P. is offline
Find More Posts by Tuomas P.
Finland
Joined Apr 2007
YS altitude control aggressive
Just tested the YS-X4 on an X-8. The setup pretty much out of the box. It seems that once the altitude hold is on while flying in altitude hold mode or GPS mode, the motors start to oscillate. Its restless. Actually my YS-X6 does the same. Tried to put the values down, but its still restless. On the manual mode its much better (video from 0:28) Any ideas? Here´s the video:
YSX4 test (0 min 53 sec)
Rgds,
Tuomas
Tuomas P. is offline Find More Posts by Tuomas P.
Old Dec 05, 2012, 02:18 PM
maximus-rc is offline
Find More Posts by maximus-rc
RTF copters maker
maximus-rc's Avatar
South France
Rgds,
Tuomas
Hello Tuomas,
Which kind of ESCs do you use ???
Maybe they aren't "fast" enough ???
Cheers
Maximus
maximus-rc is offline Find More Posts by maximus-rc
Old Dec 05, 2012, 02:55 PM
Finland
Joined Apr 2007
In my YS-X6 driven X8 I have Simonk flashed Blueseries 40A. On this one my friend has 40A Turnigy, not flashed yet. On both the ESC setup is normal 400Hz in the YS end.
TP.
Old Dec 06, 2012, 07:31 AM
archet is offline
Find More Posts by archet
Mozambique, Maputo City, Maputo
Joined Sep 2012
Originally Posted by zerouav View Post
Dear archet,
Have you downloaded and read the Quick Start Guide? There is clear Warning addressed inside. The problems and cautions can be found in the User Manual or Quick Start Guide, so if you have problems or douts you can refer to it. Or emial to our technical support: support_zerouav@yeah.net
Hi Zerouav
I have read the quick start guide and it says to power the servo through one ESC's BEC.
About the interference between image tx an IMU it obviously says to put them far. I am using an hexa with a quite large gimbal, so I put the video tx at the bottom of one of the gimbal's leg. It is not possible to put it farther than that.
What kind of problems can interference cause? does it affect stability only? Can it cause the FC to suddenly move in a direction or drastically reduce power on one motor causing it to tilt and eventually crash?
archet is offline Find More Posts by archet
Old Dec 06, 2012, 07:37 AM
Dreidekker is offline
Find More Posts by Dreidekker
Joined Dec 2012
Hello everybody,
I'm new in this and with the YS-X6 system. I got trouble when i upgrade my firmware and now when I'm trying to upgrade again I got this message:
45 53 43 5B 4A OA OD 59 53 2D 58 36 20 69 73 20 6E EF 77 20 62 6F etc... and that I have to restart the upgrade program. Maybe I allready have the newest firmware? The LED on the wifi is lit, so I think it is ok, because I could get information yesterday on the Ground software on the PC, but not anymore. I will try a Android cellar to( I have Iphone that I not can jailbreak yet) see if I got it right. Any suggest what to do?
And why does the LED flash red, red, red, green. It should be red, red, red... What's wrong. I can't see that I have set it up wrong. ESC?
Any suggest?
Dreidekker is offline Find More Posts by Dreidekker
Old Dec 06, 2012, 04:03 PM
Salocin is offline
Find More Posts by Salocin
Salocin's Avatar
Joined Aug 2012
TP.
I had the same issue, both on my X8 and my hexa. How did I fix it? I recalibrated the end points of the ESC's. Its got to be done with no props for safety, but when you hear the correct beeps, you will know its done. So, power off the ESC's, but not the FC and Rx, and then in setup guide, skip to the ESC calibration part, then put throttle to maximum (100% stick), power on the ESC's until you hear the tones that its in settings mode, then throttle off (0% stick). You'll hear a confirmation beep. Like mentioned before, make sure the ESC's are set up correctly on their own also.
When I redid the end points, the oscillation stopped (like you was more prevalent in GPS auto hover mode). Hope that works.
Salocin is offline Find More Posts by Salocin
Old Dec 06, 2012, 07:04 PM
Mr_westie is offline
Find More Posts by Mr_westie
Down under under
New Zealand, Auckland
Joined Nov 2007
Worst case crash, best case intermittent control lockout.
Once I get mine airborn again I will continue work on an early warning system for issues.
Most are preventable if you know what to look for.
Mr_westie is offline Find More Posts by Mr_westie
Old Dec 07, 2012, 08:56 AM
archet is offline
Joined Sep 2012
Motor speed increasing after flip over
I had other two bad landings and flips over while continuing testing my hexa and YS-X6. What put me angry was the fact that when the hexa was capsizing the motor speed was increasing while the throttle was at zero ad even when it was completely capsized on the ground it continued for few seconds to keep motors running.
This caused propellers to break and other problems to the motors and to the shaft.
I thought that when the attitude angle is bigger than a certain value the YS should cut the throttle automatically but instead, notwithstanding the throttle being to zero it keeps motor running for a while.
During one of the first flight I had a flip over because after landed I decided to stop the motors with the arming method (I use it with DJI FC) but the motors accelerated and the hexa capsized, so I do not use it anymore.
Old Dec 07, 2012, 10:08 AM
Finland
Joined Apr 2007
I have done the esc calibration properly. But I'll do it again. I will also try to locate the image tx and wifi and the gps farther from the imu. My MC is now located above the imu, maybe they should be also reversed.
TP.
QUOTE=Salocin;23459487]I had the same issue, both on my X8 and my hexa. How did I fix it? I recalibrated the end points of the ESC's. Its got to be done with no props for safety, but when you hear the correct beeps, you will know its done. So, power off the ESC's, but not the FC and Rx, and then in setup guide, skip to the ESC calibration part, then put throttle to maximum (100% stick), power on the ESC's until you hear the tones that its in settings mode, then throttle off (0% stick). You'll hear a confirmation beep. Like mentioned before, make sure the ESC's are set up correctly on their own also.
When I redid the end points, the oscillation stopped (like you was more prevalent in GPS auto hover mode). Hope that works.[/QUOTE]
Old Dec 07, 2012, 10:11 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
I am not saying it wont work, but a number of people I know who did that, had problems with interference. It is a better policy to locate the IMU above the MC
Cheers
Rob
robone is offline Find More Posts by robone
Old Dec 07, 2012, 10:20 AM
Finland
Joined Apr 2007
Thanks, will do.
TP.
Old Dec 07, 2012, 06:27 PM
Down under under
Joined Nov 2007
They have now changed the firmware from instant cutoff on error condition to a 1 minute delay.
While good if vibration is your problem, not so good if over angle is the error.
I wonder if the auto cut off is only applicable in auto mode?
Back landing, navigation, auto hover.
One of the side of interference is control lockout.
So even if your throttle is at zero, the FC might be using an older higher value.
Old Dec 09, 2012, 12:19 AM
CheChe156 is offline
Find More Posts by CheChe156
Bermuda
Joined Feb 2002
YS-X4 Won't Arm.
Hello all,
I am seting up a YS-X4 and it wont arm. I am not sure about the "Parameter Define" as
they are all '0'.
can someone help with this?
CheChe156 is offline Find More Posts by CheChe156
Last edited by CheChe156; Dec 09, 2012 at 12:49 AM. Reason: Got it working Thanks.
Old Dec 09, 2012, 02:36 AM
RTF copters maker
maximus-rc's Avatar
South France
My last Octo
YS X6 COAXIAL OCTO FLIGHT TIME TEST (1 min 1 sec)
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20278 Jul 17, 2016 12:38 AM
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2428 Mar 23, 2016 02:52 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 04:35 AM
