South Africa, GP, Johannesburg
Joined Sep 2010
I think they had a blackout in China a few weeks ago as they were not allowed to fly then due to some reason or other. Cheers Rob |
Joined Nov 2011
I bought it here in Malaysia and I know the firmware are regional versions but the regions are quit broad. eg there is a Europe, Americas and Asia version with a few branch offs from this in some areas. . Although from what I see the applications aren't regional specific and neither are Google maps. May be the list changes quite often so I will check this week when I am in Indonesia and next week when I am in Singapore again if its works now or not. I can try it out again on my android mobile phone which has the latest Google maps and the tablet with the older version to compare.
Joined Nov 2011
The easiest way I found was to use an office chair, I have an old one I took the back rest off which I use for a work table that easy to roll round and I just put the copter on this as level as I can, then turn on the horizontal calibration and then turn it around a few times in both direction. Then I strap the copter to the back of my swivel office chair and rotate it vertical like that. This method I got as near perfect red and blue circles you could possible get.
New Zealand, Auckland
Joined Nov 2007
Had a bit of trouble getting my new Wifi module going.
Using a IP-Serial driver gave me direct serial access to the port for testing. Sticking a loopback on it worked. Much testing and head scratching later I decided to trace the lines. It was wired up wrong ![]() ![]() Delivered configuration RS232 TX > Pin 14 DOUT1 RS232 RX > Pin 13 RIN1 What it should be http://www.best-microcontroller-proj...s232-work.html RS232 TX > Pin 13 RIN1 RS232 RX > Pin 14 DOUT1 Swapping those connections around fixed it. ![]() A less technical person would have given up after the 3rd hour and sent it back. Another 1.5 weeks of waiting. Still need some more work on the QC Zero ![]() So if your v2 wifi unit is not working, there is a small chance it could be this. Will maiden after the rain stops and report back. Hope my run of bad luck has ended. :s |
Joined Feb 2008
Good Luck! West
Joined Nov 2012
3DR Radio system
Hi all,
If anyone is interested in using the 3DR data radio system with the Zero YS X6 i have it working with the GCS in all configurations. YS ---> 3DR AIR ----------> 3DR RX Ground---> Com PortPC OR YS ---> 3DR AIR ----------> 3DR RX Ground---> Wifi Module ----> Android/Iphone APP I am also currently mapping the serial protocol and have got GPS, Voltage, Current etc.. I plan to use this info information for later use with a generic/custom GCS. I will keep you posted..... |
Joined Nov 2007
I have already mapped most of the protocol
![]() http://www.rcgroups.com/forums/showthread.php?t=1725887 Although it looks like they may have revised it in the newer firmware. |
Joined Sep 2010
Thanks Rob |
Joined Nov 2007
Once the YS makes me happy again I could put something together
Joined Nov 2011
Rob Just for interest sake I can now confirm the list is not accurate. As we speak I am in Jakarta Indonesia and on my mobile phone the latest Google maps wont allow saving of off line maps. Where as my Tablet with the previous version will. This is the same as with Singapore
| Thread Tools | |
| New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** | DJI INNOVATIONS | Multirotor Electronics | 18005 | Yesterday 09:37 AM |
| Discussion Zero UAV YS-X6 Owners Thread and Discussion | fajar | Multirotor Electronics | 2209 | May 14, 2013 01:06 PM |
| New Product Test video of YS-X6 Autopilot system | pzhang | Multirotor Talk | 141 | Jun 07, 2012 06:50 AM |
| Discussion Groupbuy for YS-X6 system | fajar | Australia | 14 | May 15, 2012 04:35 AM |
