Old Nov 23, 2012, 05:53 PM
archet is offline
Find More Posts by archet
Mozambique, Maputo City, Maputo
Joined Sep 2012
Craft flip over during first fly test
Originally Posted by richkphoto View Post
to me it sounds like you had a prop/motor runing backwards
I am sure that I installed props/motors properly, clockwise and counter clockwise alternatively. Anyway I will double check it again.
I have got FlyFun-40A-V4 ESC's (Switching BEC) and I don't know if I have to disconnect the red wire when connecting it to the YS-X6 FC.
I see that the FC is already powered directly from the battery, so I don't know if power from the ESC's can create a problem to it.
What is recommend to do?
archet is offline Find More Posts by archet
Old Nov 23, 2012, 09:44 PM
richkphoto is offline
Find More Posts by richkphoto
United States, MN, St Cloud
Joined Jan 2012
Where the fc already has it's own power have power also coming in from bec's could only cause problems , but that's just my 2 cents
richkphoto is offline Find More Posts by richkphoto
Old Nov 24, 2012, 10:12 AM
mlebret is offline
Find More Posts by mlebret
mlebret's Avatar
France, Bretagne, Combrit
Joined Mar 2005
YS-X6-C'hwil,
My ZeroUav flying machine.
At least, I fly my Hexa (HomeMade frame) with YS-X6.
I had to change the 25A Turnigy TY-P1 ESCs to 25A Flyduino SimonK Firmware ESCs in order to have it calibrated and flying.
Next time I will try to fly waypoints if I put all the telemetry gear in the car before going to the field...
mlebret is offline Find More Posts by mlebret
Old Nov 24, 2012, 02:39 PM
mnetto is offline
Find More Posts by mnetto
Joined Nov 2012
I'm setting the Autopilot YS-X6, I connected the cables as the manual, but when I turn on the battery, the system does not work, the ESC enter configuration mode. what am I doing wrong? please help me.
Best regards,
mnetto is offline Find More Posts by mnetto
Old Nov 24, 2012, 05:08 PM
Mr_westie is offline
Find More Posts by Mr_westie
Down under under
New Zealand, Auckland
Joined Nov 2007
Hi mnetto, can you post a picture of your setup and video.
Mr_westie is offline Find More Posts by Mr_westie
Old Nov 24, 2012, 05:40 PM
Reginak is offline
Find More Posts by Reginak
Reginak's Avatar
Joined Jul 2011
Guys, where can I see a changelog for the firmware? I've updated mine a some time ago and I want see what changed up the latest release.
Reginak is offline Find More Posts by Reginak
Old Nov 24, 2012, 06:45 PM
Down under under
Joined Nov 2007
First post of this thread
"YS-X6 Release Tracking notes.zip"
Old Nov 25, 2012, 01:10 AM
KariY is offline
Find More Posts by KariY
Finland, Uusimaa, HKI
Joined Jan 2012
Yes pull esc red wires off from connector, otherwise you might burn some components. For me it sounds you either have some prop/motor running backwards, wrong imu direction or wrong multirotor type cofiguration setting.
KariY is offline Find More Posts by KariY
Old Nov 25, 2012, 05:51 AM
mnetto is offline
Joined Nov 2012
the first time I started the AP, I had not cut the red wire of the ESCs, the system will be burned? I'll make a video and send
Old Nov 25, 2012, 06:03 AM
Salocin is offline
Find More Posts by Salocin
Salocin's Avatar
Joined Aug 2012
Doubt you have wrecked/burned your system. Are you getting power to the YS?
Salocin is offline Find More Posts by Salocin
Old Nov 25, 2012, 10:43 AM
SkippyTBK is offline
Find More Posts by SkippyTBK
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Nov 2011
Originally Posted by rukie View Post
Hi guys I just managed to install my gcs on my ipad 2
for those who are in need of installing it heres a link for gothelirc.. (thanks by the way)
http://gothelirc.com/ys/Apple%20Inst...structions.doc
one issue \you might encounter is copying it on the wrong directory. be sure to copy it in application in the root directory. cheers
guys another question though might be stupid to ask but I need to confirm. Do i need an internet connection to use the wifi app? In order to download the map from google?
First off once you are at your location open the GCS and have internet enabled so it loads the maps and caches the maps. Then once you connect to GCS wifi, of course you wont have internet. Its quiet stupid really. but that's how it is. If you live in Asia like I do and some other regions, the new Google maps wont allow you to save the maps for off line use now. Just another stupid thing in this system. The GCS on the laptop is junk and so it the user manual. For a start just look how much trouble you went through to use it on an iPhone/iPad? What ever it is you probably just voided your warranty to hack ti to use this GCS. And with a virtual unusable user manual there will be many more frustrations to come I can assure you.
SkippyTBK is offline Find More Posts by SkippyTBK
Old Nov 25, 2012, 01:44 PM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
I disagree, I think the PC GCS is good and also the Android GCS.
You can check if you can down load maps for offline use here https://support.google.com/gmm/bin/a...answer=2650347
Just for ease, here is the list of countries that allow you to download maps for off line use.
Availability
OS Support: Offline maps is available on Android devices running version 2.2 (Froyo) or higher. Itís available in Google Maps for Android release 6.9 and above, so please go to Google Play to update to the latest version.
Streets and maps data: Your downloaded map area includes streets and maps data. Zoom in to see a detailed view of your offline map. Certain features such as satellite, terrain, indoor maps, and 3D buildings will not be available offline.
Features that require a network connection: Features that require a network connection Ė such as directions and Navigation Ė arenít available offline.
Maps for the following countries and regions can be downloaded:
Afghanistan
Albania
Algeria
American Samoa
Angola
Anguilla
Antarctica
Antigua and Barbuda
Armenia
Aruba
Australia
Austria
Azerbaijan
Bahamas
Bahrain
Bangladesh
Barbados
Belarus
Belgium
Belize
Benin
Bermuda
Bhutan
Bolivia
Botswana
Bouvet Island
British Indian Ocean Territory
British Virgin Islands
Brunei
Burkina Faso
Burundi
Cambodia
Cameroon
Canada
Cape Verde
Cayman Islands
Central African Republic
Chad
China
Christmas Island
Cocos (Keeling) Islands
Comoros
Congo
Cook Islands
Costa Rica
Cote d'Ivoire
Croatia
Cuba
Cyprus
Czech Republic
Democratic Republic of the Congo
Denmark
Djibouti
Dominica
Dominican Republic
Ecuador
Egypt
El Salvador
Equatorial Guinea
Eritrea
Ethiopia
Falkland Islands (Islas Malvinas)
Faroe Islands
Fiji
Finland
France
French Guiana
French Polynesia
French Southern and Antarctic Lands
Gabon
Gambia
Georgia
Germany
Ghana
Greece
Greenland
Grenada
Guadeloupe
Guam
Guatemala
Guinea-Bissau
Guinea
Guyana
Haiti
Heard Island and McDonald Islands
Honduras
Hong Kong
Iceland
India
Iran
Iraq
Ireland
Italy
Jamaica
Kazakhstan
Kenya
Kiribati
Kosovo
Kuwait
Kyrgyzstan
Laos
Lesotho
Liberia
Libya
Luxembourg
Macao
Macedonia (FYROM)
Madagascar
Malawi
Maldives
Mali
Malta
Marshall Islands
Martinique
Mauritania
Mauritius
Mayotte
Mexico
Micronesia, Federated States of
Moldova
Monaco
Mongolia
Montenegro
Montserrat
Morocco
Mozambique
Myanmar (Burma)
Namibia
Nauru
Nepal
Netherlands Antilles
Netherlands
New Caledonia
New Zealand
Nicaragua
Niger
Nigeria
Niue
Norfolk Island
Northern Ireland
Northern Mariana Islands
Norway
Pakistan
Palau
Panama
Papua New Guinea
Paraguay
Peru
Philippines
Pitcairn Islands
Poland
Portugal
Puerto Rico
Qatar
Reunion
Romania
Rwanda
Saint Helena
Saint Kitts and Nevis
Saint Lucia
Saint Pierre and Miquelon
Saint Vincent and the Grenadines
Samoa
San Marino
Sao Tome and Principe
Saudi Arabia
Senegal
Serbia
Seychelles
Sierra Leone
Singapore
Solomon Islands
Somalia
South Africa
South Georgia and the South Sandwich Islands
Sri Lanka
Sudan
Suriname
Svalbard and Jan Mayen
Swaziland
Sweden
Switzerland
Syria
Tajikistan
Tanzania
Timor-Leste
Togo
Tokelau
Tonga
Tunisia
Turkmenistan
Turks and Caicos Islands
Tuvalu
U.S. Minor Outlying Territories
U.S. Virgin Islands
Uganda
UK
Ukraine
United Arab Emirates
United States
Uruguay
Uzbekistan
Vanuatu
Vatican City
Venezuela
Vietnam
Wallis and Futuna
Western Sahara
Yemen
Zambia
Zimbabwe
robone is offline Find More Posts by robone
Old Nov 25, 2012, 04:04 PM
Lars Dahlstrom is offline
Find More Posts by Lars Dahlstrom
Joined Apr 2012
Originally Posted by xrotor_rg686 View Post
Does anyone know if YS-X6 supports autoland feature when the battery voltage level gets to low like the DJI -NAZA?
yes it does.
Lars Dahlstrom is offline Find More Posts by Lars Dahlstrom
Old Nov 25, 2012, 05:51 PM
Down under under
Joined Nov 2007
Originally Posted by Lars Dahlstrom View Post
yes it does.
Really?
Can you point to where that is listed
Old Nov 25, 2012, 05:56 PM
jdreitman is offline
Find More Posts by jdreitman
Joined Feb 2010
Not sure why I should have to go out and buy new ESCs at all? The copter was flying just fine for the first month or two using the DJI ESCs... I can't imagine anything has changed other than the firmware on the FC which now makes it incompatible with the DJI ESCs.
Originally Posted by KariY View Post
Why not buy cheap hk F-30A or F-40A esc:s and flash them. You'll get much better results than with crappy dji esc:s.
jdreitman is offline Find More Posts by jdreitman
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20278 Jul 17, 2016 12:38 AM
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2428 Mar 23, 2016 02:52 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 04:35 AM
