Old Nov 14, 2012, 03:52 AM
Joined Mar 2012
Firmware update
Hi everyone,
YS-X6 Firmwarre has been updated, please download the newest firmware to update your YS-X6 online. And refer to the "Tracking Note" for added functions and updated details.
Meanwhile, WIFI configuration video is attached (between Router Mode and Point-to-Point Mode).
Please download and watch the video in the first page of this thread.
zerouav is offline Find More Posts by zerouav
Old Nov 14, 2012, 05:52 AM
Philippines, Central Luzon, Marilao
Joined Jun 2008
Originally Posted by zerouav View Post
Hi everyone,
wow nice, will be firing up mine tomorrow better try the new firmware out.
here's my progress
@mr_westie
any comment on my layout? the imu is below the carbon plate under the autopilot?
i will still clean up the wiring. some of the esc wires are near the imu would you think there will be issues?
octo wiring by rukie2, on Flickr
rukie is offline Find More Posts by rukie
Old Nov 14, 2012, 06:14 AM
South Africa, GP, Johannesburg
Joined Sep 2010
here's my progress
@mr_westie
I see you are using a good frame
I would move the wifi module to one of the arms and point the antenna down.
robone is offline Find More Posts by robone
Old Nov 14, 2012, 06:16 AM
Joined Jun 2008
Hi robone, thanks for the suggestion can you shed light as to why?rf?
Old Nov 14, 2012, 12:10 PM
YS-X6 Know why it crashes,blog
New Zealand, Auckland
Joined Nov 2007
14 Nov 2012
* Fix the bug: when auto taking off, if switched to Back Landing craft will fly circling around in horizon.
* Blackbox function added, Autopilot will auto save the flying data (the data of one minute before powered off )
for playback and analysis.
* Immediately fix unsymmetric al center of gravity of craft when auto-takeoff.
* Flying security is improved. When unexpected careen happens, motors will auto shut down two minutes later
even if it's Auto Mode and throttle is in the bottom position.
Nice, that should address a few of my concerns
The black box function is great.
Too bad if you crash far away and can't make it to the unit to unplug it.
Mr_westie is offline Find More Posts by Mr_westie
Old Nov 14, 2012, 08:57 PM
ise2012's Avatar
Australia, SA, Tarcoola
Joined Jul 2012
function limit
Originally Posted by korvy View Post
I can change any parameter, but not the speed, it's the same from the computer.
hi , my friend ,
pls use the gcs , and click the function limit , and take a pic to me , i will check the speed can change or not ?
ise2012 is offline Find More Posts by ise2012
Old Nov 15, 2012, 03:48 AM
ise2012's Avatar
Joined Jul 2012
try to calibration the compass again
Originally Posted by richkphoto View Post
Can anyone tell me if the blue calibration is good enough ( the z axis is so hard to get right)
sorry , the red and blue Circles large difference , so you need do it again .
Old Nov 15, 2012, 03:52 AM
Joined Jun 2008
HI guys is there a guide for installing the ys x6 gcs app to an ipad2
Old Nov 15, 2012, 09:16 AM
Joined Jun 2008
Hi guys I just managed to install my gcs on my ipad 2
for those who are in need of installing it heres a link for gothelirc.. (thanks by the way)
http://gothelirc.com/ys/Apple%20Inst...structions.doc
one issue \you might encounter is copying it on the wrong directory. be sure to copy it in application in the root directory. cheers
guys another question though might be stupid to ask but I need to confirm. Do i need an internet connection to use the wifi app? In order to download the map from google?
Old Nov 15, 2012, 10:16 AM
Joined Jan 2012
What is this "wifi config" software mentioned in setup video? Where i can find it?
YS-X6 Wifi Configuration Video (3 min 25 sec)
KariY is offline Find More Posts by KariY
Old Nov 15, 2012, 11:24 AM
mlebret's Avatar
France, Bretagne, Combrit
Joined Mar 2005
Hello, my problem is this.
I can't get the gcs android app to change max speed.
It used to do it, but now I can't get it to go past 3.6m/s
I change the value, hit send, and its right back to 3.6m/s
I hit get, and it is the same 3.6m/s
Appreciate a solution please attached video of the problem.
http://youtu.be/0cDUi5KF4G8
Roberto
Vigo (Spain)
Do you" as written in red on your screen", select the init setup option on the settings screen before?
I did it today with my Android (new machine - I had to start from fresh config) and it worked fine.
Marc
mlebret is offline Find More Posts by mlebret
Old Nov 15, 2012, 01:17 PM
Joined Mar 2012
Did not work
korvy is offline Find More Posts by korvy
Old Nov 15, 2012, 01:18 PM
Joined Mar 2012
This is the snapshot
Description:
Old Nov 15, 2012, 08:00 PM
Joined Mar 2012
http://www.youtube.com/watch?v=Mr-wstSz3as
The default working mode of WIFI is "Router Mode", but it can also support "Point-to-Point Mode", so if necessary, you can configurate WIFI between the different modes referring to the video.
Old Nov 15, 2012, 08:16 PM
ise2012's Avatar
Joined Jul 2012
function limit
Attachment 5305364
hi , my friend , from your function limit pic , we can see the "velocity unlimited -Disale " show , the velocity is limited , so you can not change the speed . pls tell me your Serial number. we will Solve it , i am sorry , maybe something is wrong .
peter
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2235 Today 04:13 AM
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 18182 Yesterday 08:35 PM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 04:35 AM
