but nothing happens, i dont see any app |
Joined Mar 2012
Hello, my problem is this.
I can't get the gcs android app to change max speed. It used to do it, but now I can't get it to go past 3.6m/s I change the value, hit send, and its right back to 3.6m/s I hit get, and it is the same 3.6m/s Appreciate a solution please attached video of the problem.
Roberto Vigo (Spain) |
try to change another parameters , and check it can to change or not , maybe the communation is break , pls use the lasted GCS , (if the communation is break , the gcs will have a show ) maybe you can use the usb to the serial card with the pc GCS , connect it to the com3 of MC , and use the pc gcs , test change the value of speed , any result , pls let me know . peter |
Philippines, Central Luzon, Marilao
Joined Jun 2008
New Zealand, Auckland
Joined Nov 2007
http://www.himodel.com/electric/D16_...e_Cores_2.html I would go with better wiring layout than adding more weight. Confirm, remove red , +5v wire from esc connector. |
Joined Jun 2008
Joined Nov 2007
In a crude way.
Take props off. Connect to GCS. Do this outside so you get a good sat lock. With motors off but everything powered on pick up the craft and move it around. Now power up the motors to 1/2 throttle. Do the exact same movement. Turn motors and do the exact same movement for the 3rd time. Review the logs on PC GCS. If there is interference you will see the imu/gps values jump around for the second run. |
| Thread Tools | |
| Discussion Zero UAV YS-X6 Owners Thread and Discussion | fajar | Multirotor Electronics | 2233 | Today 03:54 AM |
| New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** | DJI INNOVATIONS | Multirotor Electronics | 18179 | Yesterday 06:09 PM |
| New Product Test video of YS-X6 Autopilot system | pzhang | Multirotor Talk | 141 | Jun 07, 2012 06:50 AM |
| Discussion Groupbuy for YS-X6 system | fajar | Australia | 14 | May 15, 2012 04:35 AM |
