Old Aug 01, 2012, 01:00 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
So with the latest firmware we all have four waypoints now?
Am I understanding this correctly?
Steve
saabguyspg is offline Find More Posts by saabguyspg
Site Sponsor
Old Aug 01, 2012, 01:55 PM
xrotor_rg686 is offline
Find More Posts by xrotor_rg686
Joined Mar 2012
Steve
I believed the base version always had 4 waypoints at least that's what I have
xrotor_rg686 is offline Find More Posts by xrotor_rg686
Old Aug 01, 2012, 11:58 PM
Frank.T is offline
Find More Posts by Frank.T
Frank.T's Avatar
Netherlands, ZH, Rotterdam
Joined Jul 2010
Me too, 4
Frank.T is offline Find More Posts by Frank.T
Old Aug 02, 2012, 01:06 AM
caterpillar is offline
Find More Posts by caterpillar
Joined Aug 2012
Steve
Yes, 4.
caterpillar is offline Find More Posts by caterpillar
Reply With Quote  (Disabled)
Old Aug 02, 2012, 01:15 AM
jeanclaude is offline
Find More Posts by jeanclaude
jeanclaude's Avatar
Valencia-Spain
Joined May 2009
Hi I am very happy with my controller YS-X6, I have some vibration when I fly in GPS that I have to solve.
Here I put a video, "follow me" funccion
Follow Me test with my hexacopter Zero Tech YS-X6 (4 min 58 sec)
jeanclaude is offline Find More Posts by jeanclaude
Old Aug 02, 2012, 01:27 AM
FlyingMcCoy is offline
Find More Posts by FlyingMcCoy
Joined Mar 2010
http://www.youtube.com/watch?v=YgH-joTNPIs
What happened at 3:30 ?
FlyingMcCoy is offline Find More Posts by FlyingMcCoy
Old Aug 02, 2012, 05:15 AM
Zero UAV is offline
Find More Posts by Zero UAV
Joined May 2012
Steve
Originally Posted by Frank.T View Post
Me too, 4
Hey guys, yeah, YS-X6 is always with 4waypoints as basic version. It can be upgraded to 16waypoints/50waypoints/128waypoints too.
FlyingMcCoy, how we hope you were staying here at post#66 of Activity Thread: http://www.rcgroups.com/forums/showthread.php?t=1703032
Haha, but another chance is coming close to you there, go there and check, you may also get a chance to stay on#126....
Zero UAV is offline Find More Posts by Zero UAV
Old Aug 02, 2012, 05:20 AM
Vivien Y is offline
Find More Posts by Vivien Y
Joined Jul 2012
Hi jeanclaude, try to post your video here: http://www.rcgroups.com/forums/showthread.php?t=1703032
You may get a chance to win a reward, hurry action
Vivien Y is offline Find More Posts by Vivien Y
Site Sponsor
Old Aug 02, 2012, 10:18 AM
jeanclaude's Avatar
Valencia-Spain
Joined May 2009
This is normal The hexacopter automatically rotates the front, looking for mobile gps signal . The first time I scared
Thanks, I've put
Sorry for my english!
Old Aug 03, 2012, 06:49 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Can someone tell me why was the competition moved to here http://www.rcgroups.com/forums/showthread.php?t=1703032 ? That is where all the videos are being posted.
Who ever moved it, it is in the wrong place
Rob
robone is offline Find More Posts by robone
Old Aug 03, 2012, 07:05 AM
jab is offline
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
Probably because ZeroUAV isn't a RCG sponsor.
jab is offline Find More Posts by jab
Old Aug 03, 2012, 07:22 AM
KariY is offline
Find More Posts by KariY
Finland, Uusimaa, HKI
Joined Jan 2012
Hi guys,
Is there really anyone using YS successfully in heavy lift setup? I have tested now around 100 flights and i'm having two constant problems. First i cannot get rid of small vibration which is only noticeable in video watched in full screen afterwards. I have tried with 6 different well balanced props, rebalanced motors couple of times, all balanced and balanced again with large variety of different parameters and it's always there. With WKM i don't get any vibration at all so it has to be related to YS somehow. It's kind of very small roll direction oscillation which is most noticeable in corners in video.
My P/R sensitivity values are now around 70-80, if i go higher it oscillates and lower it's too sensitive. Atti is now 25, if go higher it oscillates even in 70/P/R, low end i don't know it's already very low. How low it is safe to go with atti values? Motion compensation i have tried in range from 40 to 190 but not much difference, oscillates when very high but same small vibration is there when it's very low.
Other thing is i get sudden yaw drifts, i've got them from the beginning almost in every flight. Recalibrated compass many many times and really don't know why it drifts, even in dead calm. I have rechecked motors are straight few times with laser spirit and i only can tell they are very straight. Also tried to tilt the motors to help yaw 3 degrees but it didn't help. Possibly might be related low ATTI value i need to use?
Is there really anyone flying YS successfully in bigger (over 5kg) setups? Do i need to go back to WKM and put YS back to smaller frame or is it possible to get this setup flying without vibrations? In every other ways i really like the YS system much over WKM and i really like to use it but looks like i just can't get it right there. I really appreciate all suggestions that might be helpful.
Here is video showing yaw drift and also vibration:
yaw drift (0 min 13 sec)
KariY is offline Find More Posts by KariY
Old Aug 03, 2012, 09:36 AM
Frank.T is offline
Frank.T's Avatar
Joined Jul 2010
I do. 5Kg and 14Kg with prof. camera.
I even use the standard settings and they work for me.
Did you use only double-sided tape under the IMU (i did).
Did you place your antenna(s) and receiver/transmitter far away from the IMU
//Frank
Old Aug 03, 2012, 09:39 AM
Frank.T is offline
Frank.T's Avatar
Joined Jul 2010
Rob
Maybe finding it is a part of the competition
I don't mind, you?
//Frank
Old Aug 03, 2012, 10:37 AM
KariY is offline
Joined Jan 2012
Well, i don't know whats far enough to avoid emi from Tx/Rx. Here is pictures of my imu mounting, IMU is placed under battery tray and PDB is quite close 22mm under IMU. Imu is mounted on 6mm vibration absorbing gel sheet.
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20279 Aug 21, 2016 06:18 AM
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2428 Mar 23, 2016 02:52 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 04:35 AM
