New Zealand, Auckland
Joined Nov 2007
I looked at the DJI iOSD again.
I though it was a ground based osd. Nothing special that any other can already do. It is nice they have av switcher. And integration into the WKM. Fail on no current sensor though. I am still undecided on weather I will use an OSD or just use a Ground station overlaying on a video. Since I am more interested in the mission and not fun FPV flying, the GCS screen is more useful for me. http://code.google.com/p/arducopter/wiki/AC2_MPGCS A video can be shown in the green blue background of the artificial horizon window. |
Joined Nov 2011
Just the point is I was hoping not to have to rely on the Android GCS because Ill be flying my other rigs at the same time when I go fly the YS, and these are all run from my small laptop GCS setup and I do rpefer to just use the Rx and not bother switching from one to the other. As you advised I did manage to get the setup and calibration working using the Android setup. It was all simply a mistake earlier that I didn't realise I had to do the whole calibration process all within the 5 second time frame. Now I have done this it works doing the calibration on the PC GCS as well. My setup is on the link I sent earlier and yes I did remove that soft sponge mount since these photos were taken. http://www.diydrones.com/forum/topic...age=7#comments I appreciate you help very much. Thanks mate. |
Joined Jan 2012
If you do it correctly, your ESCs will be calibrated all at once. That's it! Please note that this calibration is for setting the throttle range of the ESCs to comply with the YS-X6' range. Even if you've calibrated the throttle range of your ESCs individually that doesn't matter because you still need to run ESC calibration from the GCS. Also note that you still need to run typical ESCs calibration for each of the ESCs e.g. setting battery type to NiMH not lipo etc before you calibrate the ESCs all at once through the GCS. |
no worries. Please redo the channel and compass calibration as well as check the settings: magnetic declination, aircraft type, lipo cell number etc. Also check the "radio" and "real servo" values in the GCS as well as paying attention to altitude value and velx, vely and veld numbers. Make sure "real servo" value correspond correctly to tx input. Your multi should fly well. |
| Thread Tools | |
| New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** | DJI INNOVATIONS | Multirotor Electronics | 18052 | Today 09:16 PM |
| Discussion Zero UAV YS-X6 Owners Thread and Discussion | fajar | Multirotor Electronics | 2209 | May 14, 2013 01:06 PM |
| New Product Test video of YS-X6 Autopilot system | pzhang | Multirotor Talk | 141 | Jun 07, 2012 06:50 AM |
| Discussion Groupbuy for YS-X6 system | fajar | Australia | 14 | May 15, 2012 04:35 AM |
