Old Oct 15, 2012, 07:38 PM
SkippyTBK is offline
Find More Posts by SkippyTBK
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Nov 2011
Originally Posted by robone View Post
Hi
I have a page of tips that I have loaded on my website. http://multirotor.co.za/?page_id=964 you will see it under tips.
One of the tips is not to use that soft sponge. You have to hard mount it.
Cheers
Rob
Thanks guys @Rod, Andre. Yes though as much, just wasn't sure how sensitive this IMU is.
Just a few other questions before I power it up. My throttle lever is on the right so to arm I hold it in normal V configuration or inverted V?
Is there any issue to mount the IMU directly on top of the MC Box? ( see photos of setup http://diydrones.com/photo/photo/lis...=30c2pkju7afae)
"Enable Insurance" What is that? Fail safe?
When I click "Init setup" what is happening? I don't see anything? (using PC GCS)
How can I see if the RC is properly calibrated?
How can I stop the default location going to YSs test field in Beijing?
With the "new" USB cable, Can I plug this directly into one of the data modules to connect it to the GCS software? If I can this means I can use internet live while using the GCS and flying. (No Wifi needed for connection then)
Is it ok to leave all the red wire connected to all the ESC sockets going to the MC unit? I see on the Alishanmao's YouTube tutorial he briefly mentions to disconnect all except one. But there isn't anything in the manual on this so assume this isn't necessary?
Are we able to connect any other sensors such as sonar or optic sensors?
SkippyTBK is offline Find More Posts by SkippyTBK
Old Oct 15, 2012, 09:14 PM
Mr_westie is offline
Find More Posts by Mr_westie
Down under under
New Zealand, Auckland
Joined Nov 2007
Throttle and rudder on right?
Should be ok there
used for auto take off. Don't touch for now
Used for throttle calibration. You have to be in manual mode for it to have any effect. GCS should show "Init setup". Do not fly in this condition.
Move the sticks. Manual servo position/R/A/E should not exceed +-40. Throttle, < 90
You can't
I don't have a modem but I don't see why not. You do not need a live connection to use the map. You do have to cache the area you are flyinf and not close the PC GCS down.
Disconnect all the red wires from ECS. Some ECS can fry. Power to RX is supplied from the FC
Current sensor. RPM. It holds pretty well without sonar
Mr_westie is offline Find More Posts by Mr_westie
Old Oct 16, 2012, 12:16 AM
KariY is offline
Find More Posts by KariY
Finland, Uusimaa, HKI
Joined Jan 2012
Originally Posted by maximus-rc View Post
Yswifi.exe file is in var/stash/Applications.nGPD7P folder with all other xxx.app folders (including Cydia.app !!!)
Not any "app" on var/mobile/Applications folder...
That should be right path. If you go root folded and /applictions/ it goes to same folder. But you should not have yswifi.exe there as it is windows software, you should find yswifi.app.
KariY is offline Find More Posts by KariY
Old Oct 16, 2012, 12:17 AM
maximus-rc is offline
Find More Posts by maximus-rc
RTF copters maker
maximus-rc's Avatar
South France
Originally Posted by Mr_westie View Post
I don't have an iOS device so am now guessing.
Do they have microSD cards installed?
No sd card installed on the Ipad...
On Android, either the sd card is in or not, I can found the hj folder....
maximus-rc is offline Find More Posts by maximus-rc
Old Oct 16, 2012, 12:44 AM
Joined Nov 2011
Should be ok there
You can't
Thanks Westie. yes correct throttle and yaw on the right. I persisted with it on the left for ages but found I have much better control with this configuration having it on the right side.
I think its because i find for multirotor copters the altitude adjustment using the throttle and heading using yaw are quite critical and need quite accurate controls compared to flying a fixed wing which is where the throttle and rudder on the left comes from.
Old Oct 16, 2012, 01:12 AM
Down under under
Joined Nov 2007
In that case you arming will be
\ / instead of / \
Old Oct 16, 2012, 03:49 AM
RTF copters maker
maximus-rc's Avatar
South France
Hi all,
which jailbreak software do you use ?
Maybe my folders problem comes from bad jailbreak...(I use absinthe-win-2.0.4 on Ipad and redsnow on Iphone)
Maximus
Old Oct 16, 2012, 07:12 AM
laverre is offline
Find More Posts by laverre
Multirotoriste
France, IdF, Montesson
Joined Aug 2012
Hello
Just one stupid question.
How works the RTH? The point home initializes during the connection of the battery, or it is necessary to validate a function in the gcs? and witch fonction?
cordially for your help.
Cédric
laverre is offline Find More Posts by laverre
Old Oct 16, 2012, 09:59 AM
fajar is offline
Find More Posts by fajar
fajar's Avatar
Indonesia, Special Capital Region of Jakarta, Jakarta
Joined Jan 2011
Originally Posted by laverre View Post
Hello
Cédric
the system will automatically capture home position when enough satellites are locked, the process takes a bit of time after you connect the battery. You can also override the home position by clicking on the home position button in the GCS, the system will then record the updated position as the new home position.
fajar is offline Find More Posts by fajar
Old Oct 16, 2012, 10:00 AM
fajar is offline
fajar's Avatar
Joined Jan 2011
Hi all,
Maximus
maximus, try to update your GCS to the latest version. The older version had a bug that caused the ipad not to store HJ files.
Old Oct 16, 2012, 10:13 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Has anyone used a Samsung Galaxy with android 4.0.4 on it to fly waypoints?
robone is offline Find More Posts by robone
Old Oct 16, 2012, 12:55 PM
Andre6553 is offline
Find More Posts by Andre6553
Vulcan skyhook multirotor
Andre6553's Avatar
South Africa, GP, Pretoria
Joined Feb 2011
I have samsung andriod 4.0.4 but im unable to edit waypoints then program quits. Dont know whats wrong other people do have sucsess with it.
Andre6553 is offline Find More Posts by Andre6553
Old Oct 16, 2012, 01:24 PM
robone is offline
Joined Sep 2010
Thats why I am trying to find out who is using that software because I know of 1 other person that is having problems and it might be linked to the fact that they are using the Galaxy Note.
Old Oct 16, 2012, 02:50 PM
RTF copters maker
maximus-rc's Avatar
South France
Damned !!!
ps: I remember yesterday I was online with ZHANG and update with latest version and it was the same bad result
"but" if I put the app on var/mobile/Applications/ folder, program doesn't work (no other app file in this folder) and if I put in /var/stash/applications.Gnd7n (or something like that) where all the app are, GCS works perfectly...but no Hj folder or file....
The "extention" of Applications folder makes me thinking that something is wrong....
Old Oct 16, 2012, 03:50 PM
RTF copters maker
maximus-rc's Avatar
South France
Originally Posted by KariY View Post
Right cell-number set in parameters?
I think that problem should come from batteries...
I sold original 6000mAh 35C KYPOM to my client and after a ten of flights (one pair in parallel for each flight), 3 packs on 8 became completely dead (one cell at 0volt on each pack) and 2 others are very unbalanced.
I saw a cell dropping at 1.2V on the QUANUM (at the end of flight) while other was at 3.55V.
I can presume that during the "last" flight, on cell died suddenly and make the FC go on "fast" auto-crash...
Client has few "alerts" before he crashed.
And big problem happened after a full power one minute climbing...
Total flight from take off to crash-landing was only 113sec...
Fortunately he could open parachute....only 3 arms broken.... and the 1500€ stabilised zoom lens !!!!
And cherry on the cake, no hj file !!!
Maximus
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20279 Aug 21, 2016 06:18 AM
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2428 Mar 23, 2016 02:52 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 04:35 AM
