Old Sep 19, 2012, 06:59 AM
richkphoto is offline
Find More Posts by richkphoto
United States, MN, St Cloud
Joined Jan 2012
Originally Posted by Mr_westie View Post
richkphoto, looks like your gains could do with some more adjusting down.
Which gains do yo think I should adjust?
richkphoto is offline Find More Posts by richkphoto
Old Sep 19, 2012, 02:19 PM
Mr_westie is offline
Find More Posts by Mr_westie
Down under under
New Zealand, Auckland
Joined Nov 2007
Roll/Pitch Sensitivity.
Default is 60.
Mr_westie is offline Find More Posts by Mr_westie
Old Sep 19, 2012, 04:01 PM
KariY is offline
Find More Posts by KariY
Finland, Uusimaa, HKI
Joined Jan 2012
I also had to lower atti gains to around 20. Especially if you're using simonk flashed esc:s.
KariY is offline Find More Posts by KariY
Old Sep 19, 2012, 07:46 PM
Joined Jan 2012
I'm just using regular RCtimer ESCs
Old Sep 20, 2012, 09:33 AM
magetpr is offline
Find More Posts by magetpr
RC Aircraft Noob Since 01-2012
Philippines, Davao Region, Davao City
Joined Dec 2011
Default is 60.
I ended up at 38
magetpr is offline Find More Posts by magetpr
Old Sep 20, 2012, 10:09 AM
Andre6553 is offline
Find More Posts by Andre6553
Vulcan skyhook multirotor
Andre6553's Avatar
South Africa, GP, Pretoria
Joined Feb 2011
What batt do you use? 3 s or 4s
Andre6553 is offline Find More Posts by Andre6553
Old Sep 20, 2012, 10:30 AM
koleos is offline
Find More Posts by koleos
koleos's Avatar
Italy, Apulia, FG
Joined Dec 2011
Originally Posted by Andre6553 View Post
Hello Andre. I have a Hitec Aurora 9 radio and receiver Optima9, can I use SBE-1 Adapter S.Bus PWM.? and compatible with all receivers? thanks regards
koleos is offline Find More Posts by koleos
Old Sep 20, 2012, 03:03 PM
Andre6553's Avatar
Joined Feb 2011
I'm sure you can they. Say it can work with any radio
Old Sep 20, 2012, 03:57 PM
Joined Jan 2012
I know I've seen it somewhere, how can I view the data file that is on my tablet?
Old Sep 20, 2012, 04:36 PM
Down under under
Joined Nov 2007
I think you can only play back the hj file on the PC.
The files should be on the SD card.
Old Sep 20, 2012, 10:27 PM
ovnilab is offline
Find More Posts by ovnilab
Joined Aug 2012
Hi,
Can you share what batteries your using, motors, prop brand and size and total flight times your getting as as result?
Thanks!
Originally Posted by Salocin View Post
I'm loving the YS-X6 so much now. Its rock-steady. People ask me if I think its better than WKM, and I reply "Never used WKM, why would I bother when I get such good results with the YS-X6.
http://www.youtube.com/watch?v=aDsviqYYvyE
ovnilab is offline Find More Posts by ovnilab
Old Sep 21, 2012, 01:56 AM
zerouav is offline
Find More Posts by zerouav
Joined Mar 2012
ZERO Steadycam Gimbal Video
Scenic Spots Film (untreated)
http://v.youku.com/v_show/id_XNDUyNDkwMzYw.html
zerouav is offline Find More Posts by zerouav
Old Sep 21, 2012, 06:42 AM
magetpr is offline
Joined Dec 2011
very nice!
Old Sep 21, 2012, 12:04 PM
Salocin is offline
Find More Posts by Salocin
Salocin's Avatar
Joined Aug 2012
Is there a non-rooting way to simply connect my Galaxy to the WiFi module (the ground one) to bypass having a router? Surely these devices have the technology in them to configure wifi to connect to the WiFi link. Then I can just use wifi only for short range phone to data link bridging...
Why don't they just introduce a blue tooth link. I get 3G coverage on my phone, so can load maps from Google in the field. Any suggestions?
Salocin is offline Find More Posts by Salocin
Old Sep 24, 2012, 12:58 AM
Frank.T is offline
Find More Posts by Frank.T
Frank.T's Avatar
Netherlands, ZH, Rotterdam
Joined Jul 2010
Yes there is, just change the IP range on the WiFi unit.
First be sure that you have connection to the WiFi-link,
easiest to use a router and your PC.
Than type in the browser 192.168.1.254
this wil show you the login screen of the wifi link.
username and password are the same "admin"
Change on the top to English
Go to setup and change the Iocal ip to your desired IP address and press SAVE (for the TAB2/S3: 192.168.43.254 )
Re-power the unit and you can connect via your Samsung or any other device that use the same IP range x.x.43.x
//Frank
Frank.T is offline Find More Posts by Frank.T
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20279 Aug 21, 2016 06:18 AM
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2428 Mar 23, 2016 02:52 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 04:35 AM
