New Zealand, Auckland
Joined Nov 2007
It is working normally.
Meaning of the lights, page 11 in the manual ![]() http://gothelirc.com/ys/YS-X6%20User...ual%20V1.2.doc If the light do not match what you see in the GCS then we have a problem. What failsafe position did you set the switchs to? There was a Spektrum setup procedure posted a few pages back. I will see if I can find it. |
about the gimbal
1.when you want to change the servo frequency , you need click "init setup " first , then click "data" , there is a fly mode , it will be show the "setting " mode . then you can change the servo frequency from 250 to 50 Hz , don't forget click the "send' and "get " , check you change is successed. 2.Step2. About the power supply of servo . a. if your ESC have a BEC 5v out , you can retain only one ESC ‘BEC 5V out ,to supply the power . b. if your ESC have no BEC 5v out , you need supply the power to servo by yourself . you can connect the power to the void port (m1\m2...m8 ) expect the EXT3 port. Note: the middle is positive electrode . the below is Negative electrode. 3: set two switches on RC tx to ch7 and ch8 . ch7 is gimbal pitch input , ch8 is gimbal toll input . EXT1 of AP ia gimbal toll , and EXT2 is gimbal pitch ,, connect the servo according to the instruction . 4 pen the RC tx , power on the ap and servo , use the RC TX ch7 and ch8 ,to adjust the gimbal to desired angle.move the craft manually in forward/back/left/right direction ,observing whether the gimbal angle correction is right. Gimbal sensitivity is used for adjusting gimbal angle correction, if user think the gimbal angle correction is small,you can fill in a bigger value,if not fill in a smaller value(note:gimbal sensitivity can be negative to be reverse). ok , i hope it can help you to solve your problem . maybe you can send a Email to me when you have the problem with the YS-X6, my Email address is : support_zerouav@yeah.net have a nice day to you . peter |
Philippines, Davao Region, Davao City
Joined Dec 2011
Rth fail (crash)
I made a mistake of testing RTH in my village and not on the flying site and this is the result:
When the unit was headed toward the trees I tried to override by switching radio to auto hover - when it did not stop to hover I switched to manual, I could have sworn my throttle was at max but the X650 just went down. Reviewing the hj file the mode changed from auto hover to manual a couple of times. Maybe the trees messed with the signal? Then fail safe engaged and throttle went zero (as I have not properly set fail safe)? this is my assumption... Frame, props, broke. Not sure about motors and esc's. YS-X6 and FPV stuff all good. The CF cover of this frame did its job and protected all the electronics. Now I order parts and wait maybe 3 weeks to fly and post again... meanwhile will lurk... |
Joined Nov 2007
magetpr, esc usually survive.
Looks like the trees broke the fall. There is a delay switching to RTH. 1-2 seconds. I had that the other day when it was heading for trees and I lost orientation. Flicked it to RTH but it didn't stop immediately. Looking at the hj file showed I was at least 15m from the trees when it turned around. One of my first testing flights was in wind. Had the compass set wrong when I tested RTH. It flew away before I could regain control. 3 seconds and 100m later I planted it. Should have kept it airborn as it would have had a soft landing in some bushes. ![]() I always have 50% spares. Too impatient to wait for spares to arrive. |
Joined Dec 2011
Looking back I have to agree about the Delay - I guess I panicked when I did not see it respond and by switching back and forth I must have screwed it up enough to loose power. And yes thanks to the trees! Most of it is intact - one esc lost a wire though... Will order spares along with the parts - waiting does suck! hehehe |
United States, MN, St Cloud
Joined Jan 2012
Thanx for the help the failsafe is now working. Now for the other problem if it is a problem, the led flashes 3 times for a while then it just goes out . If I move sw5 to position 2 it flashes blue and position 3 flashes green ,but then if I go back to position 1 nothing. Any ideas?
Joined Jan 2012
I finally went to a field to try and fly and when I throttle it up one of the motor doen't come on until about 50% and another one stays on at 0%. I did the esc cal (I think I did it right) any ideas? Once it got up in the air it was flying fine
Joined Jan 2012
Thanx. 2 other questions. First I have 2 5000mah 35-70c 3s batteries on my 950mm hex with Avroto2814 motors , I need to get more batteries are these good or should I get 4s's or a higher c rating?
Second is should I threadlock the prop nuts on these motors |
South Africa, GP, Johannesburg
Joined Sep 2010
Check it out on eCalc http://www.ecalc.ch/xcoptercalc_e.htm?ecalc and you can play with different scenarios |
| Thread Tools | |
| New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** | DJI INNOVATIONS | Multirotor Electronics | 18047 | Yesterday 08:07 PM |
| Discussion Zero UAV YS-X6 Owners Thread and Discussion | fajar | Multirotor Electronics | 2209 | May 14, 2013 01:06 PM |
| New Product Test video of YS-X6 Autopilot system | pzhang | Multirotor Talk | 141 | Jun 07, 2012 06:50 AM |
| Discussion Groupbuy for YS-X6 system | fajar | Australia | 14 | May 15, 2012 04:35 AM |
