Old Sep 01, 2012, 01:04 PM
tazmoe is offline
Find More Posts by tazmoe
Joined Aug 2012
Post Away
Originally Posted by w2hef View Post
Thanks guys for your help in this... I will no longer post here. I don't want to take up to much of your time. I will take this up with support.
If this forum isn't for help than what is it for to stroke the egos of those that don't need any? The people with more experience should also practice more patience and help idiots like myself so I donít make a new system look bad.
Robert
tazmoe is offline Find More Posts by tazmoe
Old Sep 01, 2012, 02:00 PM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Originally Posted by tazmoe View Post
Iím asking because in my setup the weight of cord of the IMU is causing it to lean at a slight angle I tried supporting it but it is still being effected. So would I be better off just mounting it to the frame without the pad so it would remain in the same plane as the frame?
Robert
Hi Robert
No one is using the IMU anti-vibration pad. You must use double sided tape. I don't know why they supply it, but it has been mentioned a number of times that this not be used as it caused vibration problems.
It is also suggested that you locate the IMU alongside or above the Auto Pilot. The IMU must be located at the centre of the system
Rob
robone is offline Find More Posts by robone
Old Sep 01, 2012, 02:20 PM
tazmoe is offline
Joined Aug 2012
I'll try that
Originally Posted by robone View Post
Hi Robert
Rob
Because of space restrictions of the X650 frame I placed the IMU as pictured below (it is sitting on the first layer of the frame inside the center hole) with the Auto Pilot actually sitting above it on the next layer. I thought it might be better to have the IMU closer to the center of the craft. Would I be better off swapping their positions?
Robert
Old Sep 01, 2012, 02:30 PM
robone is offline
Joined Sep 2010
Robert
Hi Robert
I am using a similar frame and initially I placed the IMU below the AP. I then change it to above the AP and the performace was a lot better.
Someone I know also placed the AP above the IMU and he had endless problems with stability and vibration and then opened up the system and found that there is a lot of EMI from the underside of the AP which could be causing interference with the IMU. He has changed his system so that the IMU now is above the AP. I am still waiting for feedback from him on the results. As soon as I get the feedback, I will let you know.
Rob
Old Sep 01, 2012, 02:43 PM
w2hef is offline
Find More Posts by w2hef
All who wander are not lost
w2hef's Avatar
United States, NY, Buffalo
Joined May 2011
There's no one here in Buffalo that knows anything about these quads... just basic RC stores that are amazed when i come in with one.
However, I was able to take my older Futaba PCM1024 T8UAF with channel 58 modules and hook it up. No problem... Instant channel alignment.
now working on vertical and horz and final steps.
Originally Posted by Andre6553 View Post
We are all here to help like rob say get someone near you and went through the stages to set up correct.
My iphone also say arming as off,
I wish the iphone software can been sorted out about the map tools that does not show up when connected.
w2hef is offline Find More Posts by w2hef
Old Sep 01, 2012, 02:45 PM
tazmoe is offline
Joined Aug 2012
I'll try that as well
Hi Robert
Rob
Hi Rob,
I've tried to create an EMI shield by exopying Scotch Electrical Shielding tape to the underside of the plywood (photo below) but I can't think of a way to actual test how well it works.
Robert
Old Sep 01, 2012, 03:04 PM
tazmoe is offline
Joined Aug 2012
Kool, sounds like you'll be flying in no time
I'm using a HiTec Aurora 9 Tx/Rx and if I know now what I didn't know then I would have bought a Futaba. It sounds like there is going to be a lot of addition information to be gained from the Futaba Sbus. Nothing against the Aurora itself it just sounds like I'll be missing out because of no Sbus feature.
Robert
Old Sep 01, 2012, 03:37 PM
Andre6553 is offline
Find More Posts by Andre6553
Vulcan skyhook multirotor
Andre6553's Avatar
South Africa, GP, Pretoria
Joined Feb 2011
Robert
Fatuba has a unit that you can convert a regular rx into s-bus.
Andre6553 is offline Find More Posts by Andre6553
Old Sep 01, 2012, 03:40 PM
Andre6553's Avatar
Joined Feb 2011
Here is the unit
http://www.rcgroups.com/forums/showa...3&d=1345133817
Its the fatuba SBE-1 unit
Manual
http://www.rcgroups.com/forums/showa...mentid=5086749
Old Sep 01, 2012, 03:48 PM
Andre6553's Avatar
Joined Feb 2011
My quad is very stable but i paying the price in weight 2.8kg with gimbal and gopro.
The results are i only get about 4min flight time on a nanotech 3s 4000mah bat
I want to build a hex or a octo to be able to lift the weight much more savely and i will swich over to 4s batt
Old Sep 01, 2012, 04:07 PM
Mr_westie is offline
Find More Posts by Mr_westie
Down under under
New Zealand, Auckland
Joined Nov 2007
I don’t know about anyone else but I’m having a hard time deciphering from the manual the correct setup/init procedures to insure that I have covered all the bases setting up the YS-X6 properly. As an example the compass calibration took me a while to figure out so that is why I wrote up a procedure.
Maybe we could post an editable version of the manual somewhere and those who wanted could put in the various procedures for performing certain functions and how to know when it is done properly?
Such as
1) When do I use the Zero Gyro function? How do I know it was successful?
2) Same with the Neutral Position
3) What is the Overload Control for?
4) How do I determine the proper Steering Gear Frequency?
Robert
That's a great idea.
A wiki
The information is now spread across 4 threads, 2000+ post.
I read them all over a week and made some notes applicable to myself.
It really should be maintained by ZeroUAV but I guess that the price we pay, or don't pay, for a lower cost system.
I will see what is available.
Hi Rob,
Robert
That's a tough one to test without the right equipment.
Shielding needs to be grounded to be effective.
Electrically connect it to the ground of the device you are trying to shield.
Although the whole system shares a common ground.
Easy test would be get a small fm radio.
Tune to the weakest station you can.
Put it near the offending device and see if the signal goes scratchy.
Turn the device off, any difference?
Attach the shield, any difference?
Not the most scientific test but it would show some effect.
I’m asking because in my setup the weight of cord of the IMU is causing it to lean at a slight angle I tried supporting it but it is still being effected. So would I be better off just mounting it to the frame without the pad so it would remain in the same plane as the frame?
Robert
I originally used the pad too.
But after sorting out major vibration issues with my frame I could hard mount it.
w2hef and other with RX problems.
This might be your solution
http://www.amainhobbies.com/product_...us-PWM-Adapter
PWM > SBus adaptor.
I was looking into this option so I can get more data out of the system.
Using SBus allow you to input motor RPM data into the spare PWM in channels.
edit: darn, I can't find where I read this.
Mr_westie is offline Find More Posts by Mr_westie
Old Sep 01, 2012, 07:57 PM
tazmoe is offline
Joined Aug 2012
A wiki sounds like great idea
A wiki
You saw it in the manual under the "Power Management module & Speed sensor" section. Thats when I started kicking myself in the rear for not buying a Futabu. I'll have to educate myself about the sbus since I no nothing about it.
I'll try your (great) FM radio idea I think that would at least give me an idea if it is working or not.
Robert
Old Sep 01, 2012, 08:03 PM
tazmoe is offline
Joined Aug 2012
Thanks for the heads up
I'll have to look into this.
Robert
Old Sep 01, 2012, 10:46 PM
batfire is offline
Find More Posts by batfire
Connecticut Quad Hacker
batfire's Avatar
Joined Dec 2009
Robert
Hey Robert,
Your really starting to get the hang of it!. For the shields for emi I use copper foil tape you can get on ebay for 7-8 for a 50ft roll say11/2 wide. Also local music shops that sell guitars should have it. All my ships have it to isolate the electronics as much as possible.
batfire is offline Find More Posts by batfire
Old Sep 02, 2012, 02:01 AM
robone is offline
Joined Sep 2010
Hi Rob,
Robert
Why don't you leave the AP located on the plate and relocate the IMU to sit on top of the AP. We all know that that works well. Will take about 2 minutes to do, and there will be no worries then about any interference. I believe that the underside of the IMU is so well protected against any interference. Comments made by this person was it is the best made system around. Timecop also made similar comments when he stripped each module.
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20274 May 20, 2016 12:54 PM
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2428 Mar 23, 2016 02:52 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 04:35 AM
