Old Aug 31, 2012, 12:30 AM
Andre6553 is offline
Find More Posts by Andre6553
Vulcan skyhook multirotor
Andre6553's Avatar
South Africa, GP, Pretoria
Joined Feb 2011
Originally Posted by w2hef View Post
yes controls are all corrected and working fine... reversed some channels
can't ARM the quad.... the setting for MOTOR ARMING CAN"T be changed.
i've tried everything.
even online with mr_westbie
It happen to me as well does not matter if you try to arm motors on iphone.
Plug in your serial cable to fc and confirm. Your stick inputs rudder left L40 ruddrer right R40 aleron the same. I spoke to rob on the phone while I was doing it get someone near in your country and call then while you doing it for them to confirm what they see. It stick inputs is not right you can forget to arm motors.
Andre6553 is offline Find More Posts by Andre6553
Old Aug 31, 2012, 01:02 AM
Mr_westie is online now
Find More Posts by Mr_westie
Down under under
New Zealand, Auckland
Joined Nov 2007
When we last spoke we were unable to see the stick movements in the GCS.
We can confirm that the RX was binded and working properly.
We substituted a servo in place to check.
The next thing we were going to try was to use a non 2.4ghz RX.
Mr_westie is online now Find More Posts by Mr_westie
Old Aug 31, 2012, 01:11 AM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
if you can't see the stick movments in the gcs then how do you know something is not reversed?
I think you really need the gcs working....
sorry to hear your troubles it can be very frusterating...
Keep at it! or maybe... take a break for a few days.
Steve
saabguyspg is offline Find More Posts by saabguyspg
Old Aug 31, 2012, 08:26 AM
w2hef is offline
Find More Posts by w2hef
All who wander are not lost
w2hef's Avatar
United States, NY, Buffalo
Joined May 2011
I did manage to get the radio to work and move the sticks... It must be that they are either mixed or some reversed.... i know the throttle was reversed as I changed it along with the rudder and ailerons... OK i can understand throttle up...
is elevator to push down for down? ailerons i can understand left right
and rudder left right .....maybe my elevator is the problem... i'm used to pushing down for up in RC... what should it be... could there also be some mixing going on... i will check the dx8.
break for today... i'll take it up saturday... I really appreciate everyone's help.... it got to be around midnight last night with UAV and i had to sleep.
is the software that intelligent that it won't let me change the setting for MOTOR ARM because i have the channels reversed?
w2hef is offline Find More Posts by w2hef
Old Aug 31, 2012, 09:26 AM
Salocin is offline
Find More Posts by Salocin
Salocin's Avatar
Joined Aug 2012
Page 8 in the manual. Treat the spectrum as a JR.
Salocin is offline Find More Posts by Salocin
Old Aug 31, 2012, 09:36 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
When you push the elevator it away from you it must show "push" and when you pull it towards you it shows "pull"
I would say that is what your problem is. I would have responded sooner but no internet access where I am. Andre had exactly the same problem.
Rob
robone is offline Find More Posts by robone
Old Aug 31, 2012, 10:14 AM
tazmoe is offline
Find More Posts by tazmoe
Joined Aug 2012
I think this will fix your problem w2hef
Setting the XA ESC type (2 min 1 sec)
Robert
tazmoe is offline Find More Posts by tazmoe
Old Aug 31, 2012, 10:42 AM
w2hef is offline
w2hef's Avatar
Joined May 2011
Originally Posted by tazmoe View Post
I'm using the iphone software or ipad or PC..
What android device are you using?
Old Aug 31, 2012, 11:05 AM
rampa202 is offline
Find More Posts by rampa202
United States, MD, Annapolis
Joined Jun 2011
Originally Posted by rampa202 View Post
Someone else probably asked this before, but are you sure you haven't selected ultraPWM (XAESC 500Hz) for your esc?
Russ
I thought w2hef wasn't using XAircraft ESC's.
w2hef - if you decide that you want to use android and tether an android phone to that router via USB, (so that the router has internet access via your phone), there is another firmware for the router you must install - its on the Zoom site. If you want to tether the iphone I don't think you need another firmware version. If your android is just a wireless client you don't need to change the firmware.
I've had the Google Nexus 7 tablet which is a direct competitor and same price as the Kindle Fire - $199. There really is no debate that the Nexus is far superior to the Kindle, however the Kindle Fire 2 is about to be released, which will have the same processor as the Nexus. The Kindle does not have its own GPS, so the "follow me" function of the YS-X6 wouldn't work.
Russ
rampa202 is offline Find More Posts by rampa202
Old Aug 31, 2012, 11:56 AM
tazmoe is offline
Joined Aug 2012
Has anyone been able to bypass the wifi router?
I'm using a data link on the copter and a data link connected to the wifi for the ground connection. I have a Nexus 7 Google tablet and a Galaxy S3 phone. I also have a USB Tenda wifi router. It seems to me that I should be able to setup the S3 as WiFi hotspot with the same info as the wifi router and then connect the Nexus7 and the wifi link to the phone through the hotspot. Since I'm using the data links I want to eliminate the wifi router so there is one less thing to worry about. I think this can only be done by rooting the S3 phone which I'm reluctant to do, I have rooted the Tablet though there doesn't seem to be a way to turn a non-phone device into a wifi hotspot/router.
Robert
Old Aug 31, 2012, 12:00 PM
w2hef is offline
w2hef's Avatar
Joined May 2011
I have a kindle fire....
Russ
Old Aug 31, 2012, 12:22 PM
rampa202 is offline
Joined Jun 2011
Robert
I have the same combo Nexus 7 and Samsung S3 (neither rooted), but no data link. I didn't see a way to change the IP address on my S3, so I decided to go with a router - also for the greater range.
But for you, the range of the router is not needed and I can see why you want to eliminate the router. My brother uses a 3rd party wifi hotspot program he got from Market I believe. He didn't have to root his phone to use it. I can find out what it is if you are interested.
Russ
Old Aug 31, 2012, 02:45 PM
tazmoe is offline
Joined Aug 2012
Compass Calibration.
This is using the Android software. The copter YS-X6 has to be communicating with the Android software.
1) Go to the Settings page.
2) Select the Magnetic Compass button.
3) Select Horizontal Alignment button.
4) Select the Ok button.
5) The gray bar below the Enable RC, Disable RC, and Follow Me buttons will read something like “Horizontal Calibration Mode”.
6) If the copter is sitting on a flat surface the LED should be solid blue.
7) Pick up the copter and keeping it as level as possible horizontally, then rotate in a counter- clockwise direction (the LED will remain solid blue if you keep it stable, if it goes out just stop moving and get it to turn blue again by adjusting the copter position).
8) Try to rotate 3 times with the LED staying solid blue most of the time. It seems to be ok if it blinks a few times during the rotations.
9) Set the copter down and reselect the Magnetic Compass button.
10) Select the Vertical Alignment button.
11) Select the Ok button.
12) The gray bar below the Enable RC, Disable RC, and Follow Me buttons will read something like “Vertical Calibration Mode”.
13) Pick up the copter and holding it with the GPS antenna facing away from you and the forward direction of the copter facing toward the ground. If you have the forward direction of the copter facing the sky the LED will not turn blue at all (solid or blinking).
14) Adjust the position until the LED turns solid blue, rotate in a counter- clockwise direction (the LED will remain solid blue if you keep it stable, if it goes out just stop moving and get it to turn blue again by adjusting the copter position).
15) Try to rotate 3 times with the LED staying solid blue most of the time. It seems to be ok if it blinks a few times during the rotations.
16) Select the Magnetic Compass button.
17) Select the Save Adjustment button.
18) Select the OK button.
19) After hitting the Ok button the screen should switch to the Control screen and you will see the red x,y = changing values.
20) After it finishes it should display the red and blue circles on top of each other.
21) Switch back to the Settings page.
22) The gray bar below the Enable RC, Disable RC, and Follow Me buttons will read something like “Save adjustment values or Saved Compass Calibration”.
That’s it. If it doesn’t display both the red and blue circles do it again, otherwise your copter will spin in circles like mine did. Next time I calibrate the compass I’ll write down the exact prompts and edit this.
Robert
Old Aug 31, 2012, 03:04 PM
w2hef is offline
w2hef's Avatar
Joined May 2011
If i get a nexus 7? which one and do you HAVE to jailbreak or root it to take the android software...
I currently have a kindle fire and access to a B&N NOOK tablet... willl they work or do they have to be rooted?
Old Aug 31, 2012, 05:06 PM
tazmoe is offline
Joined Aug 2012
You don't have to root your tablet
You should not have to root the device. Look in your Settings either under Security or Developer Options for "Unknown Sources" turn this on. This allows you to install software form places other than the App Store.Then load the android software YS-X6-Android-EnglishGCS-20120802.apk from ZeroUAV onto your tablet (I downloaded the apk from ZeroAUV on my windows PC then moved it to my tablet). If you don't have a file browser app on your tablet download "Astro" or some other file browser app from the App Store. In the file browser app go find the YS-X6-Android-EnglishGCS-20120802.apk file and select it. You should then get the Install option. Below are the software versions I downloaded from the ZeroUAV.net site that finally allowed me to set the ESC type to XA ESC.
Robert
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2426 Yesterday 07:14 AM
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20265 Jan 01, 2016 09:39 PM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 07:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 05:35 AM
