Old Aug 28, 2012, 03:58 PM
w2hef is offline
Find More Posts by w2hef
All who wander are not lost
w2hef's Avatar
United States, NY, Buffalo
Joined May 2011
Originally Posted by robone View Post
Cant help. I think I must get my iPhone setup.
But then maybe I won't. After the recent court ruling I think I am going to throw my iPhone away and stick to Android products
I was thinking the same thing!
w2hef is offline Find More Posts by w2hef
Old Aug 29, 2012, 02:18 AM
fish3man is offline
Find More Posts by fish3man
Joined Aug 2012
setup nightmare
so I have beentrying to get my octocopter goingfor the lastmonth with the ys x6 no luck i tried to maiden a few weeks ago and when I got to the field the router would not connect and my coputer would not connect get home the router was back to default settings have no idea how so found out it was an easy setup router not so good for manual setup so I exchanged it for a d link router now i believe i have the network built up and still no walking on the gcs blue light is on with the wi fi so i gotta figure this out or sell it it is a 15 way point version any takers? worst part is i flew my octo on a kk board over the weekend worked great well ok but i could set it up and flyanyway .byfar the most frustrating thing i have ever tried to setup
fish3man is offline Find More Posts by fish3man
Old Aug 29, 2012, 03:08 AM
Mr_westie is offline
Find More Posts by Mr_westie
Down under under
New Zealand, Auckland
Joined Nov 2007
fish3man, drop me a pm and I can try and help you on skype
Mr_westie is offline Find More Posts by Mr_westie
Old Aug 29, 2012, 03:50 AM
jab is online now
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
Hi Russ
If the declination is negative (West) you must enter a positive value and if it is positive (East) you must enter a negative.
The manual reads correctly if you re-read it.
Rob
A much simpler solution is to live smack in the middle of 0 degree declination as I do.
jab is online now Find More Posts by jab
Old Aug 29, 2012, 04:19 AM
ise2012 is offline
Find More Posts by ise2012
ZeroUAV
ise2012's Avatar
Australia, SA, Tarcoola
Joined Jul 2012
about iphone app
Use the Resolution Center to correspond with App Review until all issues with your app version have been resolved.
ise2012 is offline Find More Posts by ise2012
Site Sponsor
Old Aug 29, 2012, 06:30 AM
rwijnhov is offline
Find More Posts by rwijnhov
Netherlands
Joined Feb 2009
Ok test flew today for the first time with my heavy lift y6. I have a bit of a strange issue. The first min it will fly stable, then it will start to lean to one side and eventualy gets verry verry wobly. Any ideas anyone? I am using balanced xoar 14x5 props. Motors are tigermotors 2814.
rwijnhov is offline Find More Posts by rwijnhov
Old Aug 29, 2012, 08:09 AM
w2hef is offline
w2hef's Avatar
Joined May 2011
I'm having a heck of a time trying to figure out my RX/TX setup on the YS.... when i plug in the ESC's they just roar at half speed.
Am I missing some settings.... I used the user manual settings and set the dec to 10.
Can't get past this last step.
I have a Spektrum DX8 with AR8000.......
Any help with this would be appreciated... i.e. How did you get your TX/RX setup..?
Old Aug 29, 2012, 09:46 AM
w2hef is offline
w2hef's Avatar
Joined May 2011
How do I get the GCS software to NOT default to Beijing?
Old Aug 29, 2012, 10:00 AM
tazmoe is offline
Find More Posts by tazmoe
Joined Aug 2012
I had the same problem
First I downloaded the android software from the Zerouav.net site (the version I had gotten from the gethelorc site was older). After installing it I Hit the Init button on the Settings page. I then held the RC/Tx control sticks in the inverted V postion (throttle down and left, aileron down and to the right). This stopped the motors. I then set up the proper ESC type and aircraft type and compass declination angle. Then to arm the motors use this inverted V position for a couple of seconds. After you can start the motors by giving a little throttle. And then check if they are respoding properly. If you cut the throttle to zero for more than 5 - 10 seconds you will have to use the inverted V position to re arm them.
Robert
tazmoe is offline Find More Posts by tazmoe
Old Aug 29, 2012, 10:07 AM
tazmoe is offline
Joined Aug 2012
The GCS software is going to the plane location
If you go to the Map page and use the show my postion it should show your GPS location of your GCS device if you have GPS enabled on it. If you have the GPS hooked up on the plane and it is powered up then use show plane position and it should show the plane in the right position and not in China.
Robert
Old Aug 29, 2012, 10:20 AM
w2hef is offline
w2hef's Avatar
Joined May 2011
awesome... i will try it tonight.. tks.
Robert
Old Aug 29, 2012, 10:24 AM
w2hef is offline
w2hef's Avatar
Joined May 2011
Robert
Yes... i've done that.. but everytime i start the GCS the google map reverts back to china... not a big deal, but i was wondering if it could just revert to last position.
Old Aug 29, 2012, 05:40 PM
rampa202 is offline
Find More Posts by rampa202
United States, MD, Annapolis
Joined Jun 2011
Why should Apple care about this? I guess the AR Drone is ok because it is not autonomous? I supposed Apple's ultimate concern would be liability in case someone was injured. But that is definitely not a risk limited to autonomous craft.
So you won't be able to get the iPhone GCS at the app store - who cares!
rampa202 is offline Find More Posts by rampa202
Old Aug 29, 2012, 07:45 PM
w2hef is offline
w2hef's Avatar
Joined May 2011
ok... I'M DONE! I've put forth quite an effort trying to get this YS-X6 working and i'm finished.. I have the YS system on my XA650 V4... i have top of the line Spektrum DX8 with the AR8000 RX... went through the Install Guide Icon in the Iphone Software... can't stop those motors...
Can't stop the motors from spinning... I'm just plan confused... Shouldn't be this hard. I need someone's time (talking) or skyping whatever... before i sent the whole kit back. I'm that frustrated.
Old Aug 29, 2012, 08:07 PM
Down under under
Joined Nov 2007
w2hef, pm me your skype
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2426 Today 07:14 AM
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20265 Jan 01, 2016 09:39 PM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 07:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 05:35 AM
