Old Aug 18, 2012, 01:02 PM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Originally Posted by RCI View Post
The new function:
*Surveying and mapping function
That is exactly?
The function that allows the change of altitude in the waypoints? and other functions relaccionadas with waypoints? as the waiting time at waypoints ...
cheers
Jose
Hi Jose
Have you used it yet and how does it work well?
Cheers
Rob
robone is offline Find More Posts by robone
Old Aug 19, 2012, 04:24 AM
pepere is offline
Find More Posts by pepere
Joined Oct 2011
Originally Posted by pepere View Post
What the restrictions in altitude ? 100m or more ?
Nobody know ????
pepere is offline Find More Posts by pepere
Old Aug 19, 2012, 04:42 AM
laverre is offline
Find More Posts by laverre
Multirotoriste
France, IdF, Montesson
Joined Aug 2012
Originally Posted by jab View Post
Stupid question, but have you set any PTZ gains? If they are 0 then the gimbal won't move.
I have test with PTZ gain at 20, 100, or -20.
laverre is offline Find More Posts by laverre
Old Aug 19, 2012, 10:22 AM
Owen X is offline
Find More Posts by Owen X
Joined Jul 2012
Nobody know ????
I think YS-X6 is no restrictions in altitude .
Owen X is offline Find More Posts by Owen X
Old Aug 19, 2012, 01:37 PM
xrotor_rg686 is offline
Find More Posts by xrotor_rg686
Joined Mar 2012
Originally Posted by laverre View Post
Yes good, i have tested with bec and that's ok
But the servo doesn't want to move, if i move the multirotor it's blocked.
If i make init, the gimbal comes on the middle ( good position) but if i stop init the gimbal goes on the corner.
i don't understand what happens
Did you connect the ch7 and ch8 of Ys-x6 to your receiver? I think you need it for the gimbal to work.
xrotor_rg686 is offline Find More Posts by xrotor_rg686
Old Aug 19, 2012, 11:25 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
so I bought a serial to usb cable... but now I can't find the cable that came with the X6
so I guess I have to make a cable... can anhone tell me the three pinouts used on the serial cable and which goes where on the X6?
Thanks!
saabguyspg is offline Find More Posts by saabguyspg
Old Aug 21, 2012, 03:30 AM
Frank.T is offline
Find More Posts by Frank.T
Frank.T's Avatar
Netherlands, ZH, Rotterdam
Joined Jul 2010
Thanks!
Servo > DB9
Black > 3
Red > 5
White > 2
//Frank
Frank.T is offline Find More Posts by Frank.T
Old Aug 21, 2012, 04:48 AM
Mr_westie is offline
Find More Posts by Mr_westie
Down under under
New Zealand, Auckland
Joined Nov 2007
Originally Posted by Zero UAV View Post
The newest YS-X6 firmware version and Iphone/Ipad GCS have released, please download YS-X6 firmware V1.2 and YS-X6 Iphone/Ipad GCS V1.1 on Zero official website or on the first page of this thread and upgrade your YS-X6 online.
What is new?
Firmware
*Surveying & Mapping function.
*The comfort level of handfeel has been improved.
Iphone/Ipad GCS
* Carefree button " Enable course lock" is added
Some more info would be good
Mr_westie is offline Find More Posts by Mr_westie
Old Aug 21, 2012, 01:49 PM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
thanks Frank!
I will dig up the DB9 diagram and get working!
Steve
Originally Posted by Frank.T View Post
Servo > DB9
Black > 3
Red > 5
White > 2
//Frank
Old Aug 21, 2012, 05:07 PM
Reginak is offline
Find More Posts by Reginak
Reginak's Avatar
Joined Jul 2011
Found the answer! Sorry
Reginak is offline Find More Posts by Reginak
Old Aug 21, 2012, 05:13 PM
w2hef is offline
Find More Posts by w2hef
All who wander are not lost
w2hef's Avatar
United States, NY, Buffalo
Joined May 2011
Will there be a HD version for the iPad 3 soon.?
w2hef is offline Find More Posts by w2hef
Old Aug 21, 2012, 05:47 PM
earlmact is offline
Find More Posts by earlmact
earlmact's Avatar
United States, AZ, Goodyear
Joined Mar 2011
Id be happy for now with a version for IOS that did not require Jailbreaking and hopefully compatible with upcoming IOS 6 as well. A iPad 3 version would be nice but I would not expect that any time soon.
earlmact is offline Find More Posts by earlmact
Old Aug 21, 2012, 07:21 PM
jdreitman is offline
Find More Posts by jdreitman
Joined Feb 2010
Ok guys, so I have an interesting problem. I'm trying to get this gimbal to work with the YS-X6 frame, and here is what's happening. For the roll, I'm using an S3156 Futaba servo. For the pitch I'm using a Hitec HS-65MG servo. To power the servos, I'm using a standard 4-5amp UBEC and sending the signal wire of both servos directly into the FC.
The Futaba servo works fine. If I plug it into either the roll or pitch cable, the servo functions as it should. The problem is with the Hitec servo. When it's plugged in, it makes a noise as if it's at one extreme of the it's endpoint (it's not however, as it's completely centered). The motion of the servo is not smooth at all, although it does move in either direction using an aux dial on the Tx. If I plug the servo directly in the Rx, it works perfectly fine! It almost seems like the YS-X6 has some sort of issue communicating with Hitec servos?
What do you guys think?
jdreitman is offline Find More Posts by jdreitman
Old Aug 22, 2012, 01:21 AM
Parift is offline
Find More Posts by Parift
Joined Aug 2012
Parift is offline Find More Posts by Parift
Site Sponsor
Old Aug 22, 2012, 01:24 AM
zerouav is offline
Find More Posts by zerouav
Joined Mar 2012
Hello to All,
ZERO-Steadi470 will be released in two or three weeks. ZERO-Steadi470 is an excellent Aerial Photography System which creats the greatest possibility to make the most stable aerial photography videos. Look forward your attention.
zerouav is offline Find More Posts by zerouav
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20278 Jul 17, 2016 12:38 AM
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2428 Mar 23, 2016 02:52 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 04:35 AM
