Old Aug 12, 2012, 10:56 PM
zerouav is offline
Find More Posts by zerouav
Joined Mar 2012
Originally Posted by Jdmagoo View Post
So if your flying with only the radio and no GCS, is carefree still possible?
No, GCS is necessary.
zerouav is offline Find More Posts by zerouav
Old Aug 13, 2012, 03:08 AM
eladberger is offline
Find More Posts by eladberger
Joined Aug 2012
subscribed
eladberger is offline Find More Posts by eladberger
Old Aug 13, 2012, 03:17 AM
hemanthtguru is offline
Find More Posts by hemanthtguru
MULTIROTOR FREAK
India, KA, Bangalore
Joined Aug 2011
Where is the button to enable the orientation control on the apple GCS
hemanthtguru is offline Find More Posts by hemanthtguru
Old Aug 13, 2012, 12:43 PM
rampa202 is offline
Find More Posts by rampa202
United States, MD, Annapolis
Joined Jun 2011
I'm not getting the 3 red blinks pattern since I upgraded to firmware 1.1. On connecting the power, the LED turns solid red for a second or so, then goes solid green. I have triple checked all my connections. My receiver is not connected. Any ideas?
Russ
rampa202 is offline Find More Posts by rampa202
Old Aug 13, 2012, 02:54 PM
rampa202 is offline
Joined Jun 2011
I answered my own question - I didn't have battery cell count setup.
I've also noticed that getting and setting parameters only works for me on Android - Wifi. My PC GUI shows the realtime IMU and stick settings, but nothing but zeros in the parameters. Do the advanced parameters (motor setup) change from zero after you select aircraft type, or are they supposed to be all zeros unless you have some kind of custom setup?
Russ
Old Aug 13, 2012, 10:48 PM
zerouav is offline
Joined Mar 2012
[QUOTE=rampa202;22435678]I answered my own question - I didn't have battery cell count setup.
As the picture below, click on "Get" button, then the parameters will display.
Description:
Old Aug 14, 2012, 12:30 AM
laverre is offline
Find More Posts by laverre
Multirotoriste
France, IdF, Montesson
Joined Aug 2012
Hello
I meet two concerns problem for:
upper the last one firmware nothing crosses(spends) it apré the etape 3 (Restart AP drank what is AP?)
And for use the soft in my phone, i can't send new info in my YS-X6 for modify the frecence of my servo grimbal.
Sorry for my english .
THX
laverre is offline Find More Posts by laverre
Old Aug 14, 2012, 12:41 PM
rampa202 is offline
Joined Jun 2011
[QUOTE=zerouav;22439902]
Attachment 5081662
In the PC software when I click "get" - nothing happens. I know that I'm connected because I see the IMU data. I tried running the program as administrator, and it makes no difference. I am using the USB to serial converter that GotHeliRC sent me with the YS-X6.
Android app works fine - I can see the parameters in android.
Russ
Old Aug 15, 2012, 02:01 AM
ise2012 is offline
Find More Posts by ise2012
ZeroUAV
ise2012's Avatar
Australia, SA, Tarcoola
Joined Jul 2012
[QUOTE=rampa202;22444500]
Russ
hi , my friend , your problem is : in pc GCS , when you click ""get'' , there is nothing happens, did you use the lasted PC GCS SOFTWARE.
i have taken a video for it , you can see it .
test1 (1 min 40 sec)
ise2012 is offline Find More Posts by ise2012
Site Sponsor
Old Aug 15, 2012, 02:32 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
As I understand it there are later versions of the software for the following and they are on the Zero UAV site:
PC dated 20120802
Android dated 20120802
Firmware dated 20120810
Can Zero UAV confirm that these must be used and if so, can the 1st post be updated.
Rob
robone is offline Find More Posts by robone
Old Aug 15, 2012, 03:31 AM
jab is online now
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
Resist the urge to update to the latest new thing just for the sport of it. That is unless there is a valid reason to do so. I have already been burned, crashing my copter while retuning a new firmware (my fault, but still). And in my case there was no performance to be gained from the new firmware, since I could not care less about using the Android tilt function for flying.
So personally I'm holding of any more updates until better PTZ control is implemented. Which for me would be a valid reason to update.
jab is online now Find More Posts by jab
Old Aug 15, 2012, 04:54 AM
ise2012 is offline
ZeroUAV
ise2012's Avatar
Joined Jul 2012
PC dated 20120802
Rob
yes , those we all tested , it can be used , and from my video , the gcs date is 20110802.
thank you for your suggestion .
Site Sponsor
Old Aug 15, 2012, 06:19 AM
robone is offline
Joined Sep 2010
I agree, I normally hold off too, but I needed to test the carefree and just as I was about to upgrade, I saw that a newer FW, Android and PC SW had been released.
Rob
Old Aug 15, 2012, 12:50 PM
rampa202 is offline
Joined Jun 2011
ise2012 - thanks for the video. What operating system and how may bits is your version? I got the 20120802 version of the GCS. I am using Windows7 64 bit OS. I have now tried it on two different computers - both running win7 64bit, and the "get" function does not work on either computer. I've also tried two different USB to serial converters and it works with neither. It does work in android so I don't think it is a faulty FC. I've also tried it with the receiver connected and the throttle at zero - still nothing. Here's a video showing the problem. It shows that I have a connection to the FC because the IMU data works, but the "get" function shows nothing at all. Also my "Init Setup" button doesn't seem to do anything.
Russ
capture 1 (1 min 39 sec)
Old Aug 15, 2012, 02:50 PM
rampa202 is offline
Joined Jun 2011
When I select "get" in the android app, this is what I see. So there is data in the FC parameters, but get doesn't work on the pc's I tried. Since I got the same results with two different computers it has to a conflict with
1) both of my usb to serial adapters - seems unlikely
2) conflict with windows 7 64bit - more likely
The two computers I tested this on are a desktop and a notebook. They are completely different in hardware and installed software except for the operating system - both win7 64bit.
Can anyone here running windows 7 64bit verify that the "get" function works on their pc?
Russ
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20279 Aug 21, 2016 06:18 AM
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2428 Mar 23, 2016 02:52 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 04:35 AM
