Old Jul 23, 2012, 04:46 PM
stew2a is offline
Find More Posts by stew2a
Joined Jul 2012
Help!
Fox 2.3m powered glider motor board replacement
I have crashed this plane so many times, I need to reconstruct the front end. Original motor board placement busted up. I am thinking about cutting off the nose right at the point where the original motor board was mounted and using a piece of luan plywood as a new motorboard. Does anyone know if this will work or will this ruin the aerodynamics of the plane.
stew2a is offline Find More Posts by stew2a
Old Jul 23, 2012, 10:17 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Sure, go ahead. You can make a new nose from a foam coffee cup to replace what you cut off.
hoppy is offline Find More Posts by hoppy
Old Jul 24, 2012, 09:59 AM
stew2a is offline
Joined Jul 2012
thanks for the idea, I was actually going to try an use a plastic 3 liter coke bottle to sort of make a cowling.
Old Jul 24, 2012, 04:51 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
After landing in a Lacrosse net and putting some new angles in the wings my FOX never flew right again. It was prone to fall out of the sky.
New wings and body from Nitroplanes made everything right again. http://www.nitroplanes.com/93a2501-2...r-rtf-24g.html
Never mind, I see they are out of stock.
Old Jul 31, 2012, 03:46 PM
stew2a is offline
Joined Jul 2012
Thanks for that info. My problem exactly, plane falls out of the sky. I figured I would try to fly this plane one more time with repairs before I purchased new wings and fuselage.
For Sale HK Ventus 2.3M Swiss painted Powered Glider in ATLANTA dannyk426 Aircraft - Electric - Airplanes (FS/W) 2 Jun 11, 2012 05:09 PM
Cool AXN & FOX Glider 2.3m FPV with one of them crash! seedo FPV Talk 0 Dec 30, 2011 11:15 PM
Sold HK Fox 2.32 M Power Glider PNP glolectric Aircraft - Sailplanes (FS/W) 2 Nov 03, 2011 10:38 PM
Discussion A look inside the HK Fox EPO 2.3M Glider topforce Electric Sailplanes 6 Feb 13, 2011 08:41 AM
