Old Jul 23, 2012, 12:50 PM
DeeCee 57 is offline
Find More Posts by DeeCee 57
Life's short - Enjoy!
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
Help!
T-Rex 450 3GX FBL and T8FG, settings anyone?
Hi guys,
just bought the Rex second hand and this is my first FBL...
Anyone out there using the same set-up (R617FS receiver) and willing to share his (hers ) channels use and radio settings?
Thanx a billion
DeeCee 57 is offline Find More Posts by DeeCee 57
Old Jul 23, 2012, 04:13 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
I don't have the exact setup, but I do run a couple Align helis with 3GX and Futaba radio. They are pretty similar:
Use HR-3 swash type.
1: AIL, reversed, right front servo
2: ELE, reversed, rear center servo
3: THR, reversed
4: RUD, reversed
5: GYRO normal
6: PIT, normal, left front servo
Swash mixing:
AIL: +39%
ELE: +39%
PIT: +37%
ps. I was at Zurich this past April, lots of beautiful grass flying fields there! You are lucky to be there.
Steph280 is offline Find More Posts by Steph280
Old Jul 24, 2012, 12:48 AM
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
Thanks a bunch Steph
Will apply all these and enjoy the flying.
As for the area, yes it is still nice, unfortunately getting crowded which means noise sensitive people all around... forget any noisy or turbine powered flying on our field...
Old Jul 24, 2012, 10:32 AM
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
Hi again Steph
Applied your settings and it works (though I had to use AIL -39, ELE +39 to get the lateral cyclic in the correct direction).
The only problem left is that when applying collective only the elevator servo moves up, e.g. the aileron and pitch stay level...
Anyone a clue on that?
Old Jul 24, 2012, 10:56 AM
wlee1017 is offline
Find More Posts by wlee1017
wlee1017's Avatar
Joined Jul 2011
3: THR, reversed
4: RUD, reversed
5: GYRO normal
Swash mixing:
AIL: +39%
ELE: +39%
PIT: +37%
Originally Posted by DeeCee 57 View Post
Hi again Steph
If you setup align 3gx fbl, you must disable (turn off) swash mixing. All swash mixing is done by 3gx. c.f. your Trex-450 3gx manual p25. Also, you need to go thru 3gx setup procedure from manual.
wlee1017 is offline Find More Posts by wlee1017
Old Jul 24, 2012, 01:19 PM
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
also thanx to you wlee
And I finally solved the problem, all set and ready to whirl
For reference, it seems there is more than one way to set-up the whole system... finally having all the correct deflections I have the following (fine adjustments will be done later):
Model Type:
HELICOPTER/HR3/OFF
Function:
1 AIL
2 ELE
3 THR
4 RUD
6 PIT
Reverse:
1 AIL REV
2 ELE NORM
3 THR REV
4 RUD REV
5 GYRO NORM
6 PIT NORM
Swash/AFR:
AIL -39%
ELE -39%
PIT -37%
R617FS receiver:
Channel 1 Red
Channel 2 Amber
Channel 3 Purple
Channel 4 Green
Channel 5 Blue
Channel 6 Yellow
Channel 7 tri Black/Red/White
Old Jul 24, 2012, 01:40 PM
wlee1017 is offline
wlee1017's Avatar
Joined Jul 2011
Dee, good you got it. do you go through 3gx setup procedure as stated in manual. Are you still get cyclic pitch +/- 9 deg and collective pitch +/- 12 deg. keep us post your maiden flight.
I am glad and learn new things everyday. I should try this setup on my Dx8 /w swash mix ON and test..........
Old Jul 24, 2012, 01:53 PM
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
yeah, though this one has already flown and been set-up, it was another brand of radio (...), so I will redo the 3GX set-up. And I still have to program the curves.
Actually what had happened is that I copied my sold Flasher 450 for the "new" bird, and that was not a good idea. Better would have been to start from fresh
As for the "maiden", it is set for in about 2 weeks as I'm going abroad (no, no vacations yet)
Good luck with that, don't check anything, just go direct into idle-up 3 for fun
Sold T-rex 450 3GX Flybarless set up. garryk Aircraft - Electric - Helis (FS/W) 0 Jul 05, 2012 11:38 AM
Sold NIB T-REX 450 PRO V2 FBL 3GX KX015080AT Kit New Low $$$ DanBo3D Aircraft - Electric - Helis (FS/W) 5 Apr 28, 2012 03:24 AM
Discussion Which FBL for a newish pilot, Blade 450 X or T-REX 3GX Herky-Bird Beginner Training Area (Heli-Electric) 5 Apr 22, 2012 03:04 AM
Sold NIB T-REX 450 PRO V2 FBL 3GX Super Combo Kit New Low $$$ DanBo3D Aircraft - Electric - Helis (FS/W) 1 Mar 29, 2012 11:29 PM
For Sale T-Rex 600EFBL Pro (3GX) & 550 FBL (3GX) rapyd Aircraft - Electric - Helis (FS/W) 1 Jun 24, 2011 04:34 PM
