Old Jul 23, 2012, 11:16 AM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Contest
Another throwing blade question.
I followed Tom's recommendation in the thread I started the other day. That worked great, Tom. Thanks!
Now, the blade came out of my Fr3aK yesterday. It just came loose and slipped right out of the hole. Here is the question: Should I grind off the old CF patch around the blade hole and install new or am I OK to just epoxy the peg back in the same hole? It seems to me, I'd want a new patch with a new fillet of CF and epoxy but I want a back up of that opinion before I go to that much effort.
TIA,
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Jul 23, 2012, 11:34 AM
ROOSWH is offline
Find More Posts by ROOSWH
Walter Roos
ROOSWH's Avatar
Canton, Ga.
Joined Aug 2004
Don't know if this is the kind of answer you are looking for but,
Usually after flying awhile the epoxy on my blade will break free and I expect that to happen. A bit of Regular CA around the peg is then applied and that fix ,more often than not, is permanent. Seems the CA sticks to the blade better than the 15 minute Epoxy Splooge mixture.
If your new blade is similar to the size of the old one, I would just epoxy/splooge it in with a tiny bit of a fillet on the top and bottom, then expect it to break loose at some time, then CA it in for the final fix.
works for me.,
walt
ROOSWH is offline Find More Posts by ROOSWH
Old Jul 23, 2012, 11:43 AM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
OK Walt. I'll try just glueing it back in. Nothing really broke except the bond.
Old Jul 23, 2012, 01:39 PM
Wazmo is offline
Find More Posts by Wazmo
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
I have one of Oleg's blades in mine, and it kept loosening when it was just glued in with a carbon patch. I had removed some of the foam between the skins around the blade hole, and filled with epoxy and milled glass fibers. Several times it would break loose after a couple days flying, and I had to CA in place again. I ended up adding a fillet of epoxy thickened with glass fibers and cabosil, on the top and bottom. I think I used the end of a popsicle stick to shape the fillet, and carefully remove the excess from the carbon patch with a paper towel. Since then, the blade's been solid.
Wazmo is offline Find More Posts by Wazmo
Old Jul 23, 2012, 11:11 PM
Buddy Roos is offline
Find More Posts by Buddy Roos
It's a mere flesh wound!
Buddy Roos's Avatar
Woodstock,Ga.
Joined Jun 2004
Be sure to sand the peg where the glue is going to go. They almost always have a little mold release left on them.
For that matter, I always sand anything made of carbon fiber before I glue it. The one exception being carbon fiber cloth!
Buddy
Buddy Roos is offline Find More Posts by Buddy Roos
Old Jul 24, 2012, 08:52 AM
ROOSWH is offline
Walter Roos
ROOSWH's Avatar
Canton, Ga.
Joined Aug 2004
btw :
I assume that you put a hard point in the tip for the Blade.
And if so, you can use regular thin CA. If there is no hard point, and you have a regular foam wing, then Regular CA will eat up the tip foam, but a hard point keeps the CA away from any foam.
Good luck with your repair,
walt
Old Jul 24, 2012, 08:56 AM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
I just sanded up the blade and epoxied it back into the hole where it was. It feels as strong as the original if not better. I think the original installation was done with CA. That's the way it looked. I used Pacer Z-Poxy laminating resin and FWIW, it was a still a tight fit in the hole.
Old Jul 24, 2012, 01:32 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
I don't know if this applies to Z-Poxy, but some laminating epoxies don't stick as hard to well cured composites as some adhesive type epoxies do. Not sure if this is the best solution, but lately I've been smearing a bit of the adhesive type onto old laminates before putting glop made with laminating epoxy on top of it.
lincoln is offline Find More Posts by lincoln
Old Jul 24, 2012, 01:33 PM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
If it works loose again I'll use some JB Weld.
Old Jul 24, 2012, 01:48 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Rubberized CA is great for this too.
I second the "sand it in the area you bond it" discussion, but with throwing pegs always use lighter grit paper and sand lengthwise. Heavy sandpaper or crossing the unicarbon "grain" can lead to failure of the blade.
tom43004 is offline Find More Posts by tom43004
Old Jul 24, 2012, 05:21 PM
lincoln is offline
Joined Dec 2001
It's probably a really good idea at some point to use isopropyl alcohol to thoroughly clean off the peg and the inside of the hole. Maybe use pipe cleaners or yarn for the hole? Not just because of mold release. It seems likely that a mixture of sunscreen and sweat has seeped in as well.
I once laminated some precured carbon onto some wood spars using a good quality laminating resin. (Custom mix from a boat builder I know.) They peeled off quite easily, and the epoxy mostly came off of the carbon. I did a sample with 30 minute epoxy and they stuck tenaciously. For the really picky, 3M makes some high quality epoxy that comes in a double tube for electronics purposes. I'm going to try that next. Shelf life isn't the greatest, though, as I recall.
Old Jul 24, 2012, 09:26 PM
zbytekfr is offline
Find More Posts by zbytekfr
The Lone Sloper
USA, NY, Orchard Park
Joined Apr 2007
I use 5 min JB weld, solid as rock.
zbytekfr is offline Find More Posts by zbytekfr
Old Jul 24, 2012, 11:17 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
Lincoln,
Two of the three mold releases I use regularly are not soluble in alcohol. One is soluble in water. Depending on who / how the peg was made, very light wet sanding may be the only way to positively remove it.
Old Jul 26, 2012, 07:28 PM
lincoln is offline
Joined Dec 2001
Hmm.. I usually think of mold release as PVA, but I guess that makes me a Luddite. Those other two don't come off with paint thinner or something? Goo Gone? Nothing wrong with wet sanding, of course.
Discussion My fingers hurt! Advice on a different throwing thing (peg/blade) JoeR Hand Launch 16 Jul 28, 2012 03:41 PM
Help! CF Patch for Throwing Blade Mr. Wiz Hand Launch 7 Jul 21, 2012 09:41 PM
Discussion Nitromodels Yak 54 Throw question dragonsm Fuel Plane Talk 4 Apr 03, 2012 07:58 AM
Question anyone switch from throwing with one hand to another- forever... jswain Hand Launch 8 Feb 25, 2012 10:45 PM
Help! questions about throwing blade Allan_A Hand Launch 5 Apr 09, 2008 02:53 PM
