Old Jul 22, 2012, 11:07 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Multirotor Arms: Round vs Square?
I have a question.
Do you prefer round or square arms?
What have your experience been with either? Advantages and disadvantages of both?
My experience has lead been that round arms have a tendency to twist and hard to level. Carbon fiber is strong for arms and wont bend at the ends like square arms can.
TheFernMan is offline Find More Posts by TheFernMan
Old Jul 22, 2012, 11:47 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
Round:
Pro:
Easy to source
Easy to add thrust angle to improve yaw performance on static yawing rigs
Boom Clamps are more durable
They will allow the motor mount to rotate in a crash absorbing some of the impact
Light Weight
Con:
Harder to keep motor thrust angle perfect
Bend fairly easily
Square
Pro:
Motor mount is 90 degrees on top and wont rotate
very sturdy and dont usually bend
can be easy to source in Al
Con
Boom clamps can be more prone to failure at the 90 degree joint
harder to find in CF
Snap rather then bending
Heavier
I have flown and built 3 rigs with round and 2 with square....
I dont know if i have a preference
Adidas4275 is offline Find More Posts by Adidas4275
Old Jul 23, 2012, 10:21 AM
vineet_p is offline
Find More Posts by vineet_p
vineet_p's Avatar
India, Telangana, Hyderabad
Joined Aug 2011
That's a good analysis, I used only square twice and was happy, now I am using U-shaped dual-channel aluminium that's ultra-strong. They're usually used as rails in sliding glass panes in olden-style showcases.
vineet_p is offline Find More Posts by vineet_p
Old Jul 23, 2012, 11:53 AM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
Square arms are strong (I can prove it...) and easy to install.
Mortimer is offline Find More Posts by Mortimer
Old Jul 23, 2012, 12:21 PM
recep is offline
Find More Posts by recep
recep
recep's Avatar
Ankara, TURKEY
Joined Sep 2005
Boom clamps add weight. On my carbon boom y6 they add 120 grams in case of a hexa this number goes up to 240. 40 grams per arm. I dont even count the landing skids. With a square aluminum you just mount them.
recep is offline Find More Posts by recep
Old Jul 23, 2012, 05:21 PM
TheKnightFerrin is online now
Find More Posts by TheKnightFerrin
TheKnightFerrin's Avatar
Oregon
Joined Jan 2011
What kind of material are your center plates composed of?
TheKnightFerrin is online now Find More Posts by TheKnightFerrin
Old Jul 25, 2012, 08:41 PM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
Square arms are better for a simpler build. If youre out of the frequent crashing stage i would recommend using 10mm x 750mm carbon square tube and you can strengthen them by inserting 8mm carbon rods. You can get this cheap from HK. Surprisingly strong.
Stunt Double is offline Find More Posts by Stunt Double
Old Jul 25, 2012, 09:10 PM
TheFernMan's Avatar
Joined Jul 2012
I found the square tube. It says 750x10.5. I don't see the carbon rod
http://www.hobbyking.com/hobbyking/s...idProduct=9012
Is that the correct one in the link?
Old Jul 25, 2012, 10:57 PM
Joined Oct 2007
Yes thats the correct link for the carbon tube. Here is the link for the 8mm rod:
http://www.hobbyking.com/hobbyking/s...w_8x750mm.html
Ive been using this setup for tricopters and so far its worked really well. I was a bit concerned about it being too weak but no. The carbon tube can split in a crash but you can fix it up easy with CA. Compared to the wood ive used in the past this stuff is much more rigid and lighter and also you can hide your motor wires inside the tubes too.
Old Jul 26, 2012, 04:17 AM
TheFernMan's Avatar
Joined Jul 2012
Thanks for the link, I've add it to my wish list
Old Jul 26, 2012, 05:26 AM
vineet_p is offline
vineet_p's Avatar
Joined Aug 2011
I don't know aht it exactly is, but it's a sort of thermosetting fiber. I cut it out of a student's examination board/pad.
Vineet
Old Jul 26, 2012, 08:19 AM
mamba max1 is offline
Find More Posts by mamba max1
mamba max1's Avatar
United States, NC, Durham
Joined Jun 2010
How's the torsional strength for the carbon set up? I'm finally out of the frequent crashing stage.
mamba max1 is offline Find More Posts by mamba max1
Old Oct 28, 2012, 02:53 PM
TheFernMan's Avatar
Joined Jul 2012
I'm revisiting this.
Most of the higher end multirotors use round carbon tubes.
Anyone know why versus using some square aluminum tubes?
Old Oct 28, 2012, 03:16 PM
malcr001 is offline
Find More Posts by malcr001
malcr001's Avatar
United Kingdom, England, Gt Lon
Joined Nov 2007
This thread got me wondering, why arent we using square carbon fibre tubing?
I can agree that getting motors level with round tubing is a pain. Especially with the motor mounts I have. The way its designed means that as you tighten it, it slowly rotates around the arm. This makes it harder to level the more you tighten it.
malcr001 is offline Find More Posts by malcr001
Old Oct 28, 2012, 03:25 PM
TheFernMan's Avatar
Joined Jul 2012
i have a Talon V2 frame and thats where this started. After i ordered replacement motor mounts, i installed them yesterday and i saw something i didn't see the first time around a few months ago.
when using a bubble level on the motor mount itself and laying the arm with the bracket flat on the floor, i could turn the motor mount till it was level. seem easy but it took a few minutes each arm. something that i didn't have to worry about with square arms.
you could use square carbon fiber arms, but i assume you'll still need arm blocks to mount to center plate and mount the motors.
Discussion Brass vs Copper stock/round for ballast Twyl Slope 7 May 25, 2012 10:29 PM
Discussion Square vs. round carbon tubes? Also, how much does brand matter? Cheesehead Composites Fabrication 8 Jan 04, 2012 02:50 PM
Discussion Round Vs Square Fuselage ? RWCLOUD Sailplane Talk 22 Oct 19, 2011 04:56 PM
Discussion Multirotor Construction Question - Arm Attachment Method... bob4432 Multirotor Talk 6 Jul 20, 2010 09:31 AM
Discussion Round vs. Square section JCaste Modeling Science 2 Aug 25, 2006 01:47 AM
