Old Dec 17, 2012, 02:29 PM
ak68 is offline
Find More Posts by ak68
ak68's Avatar
Nederland, ZH
Joined Dec 2011
Poor visibility for flying: Doing a handstand instead.
mako handstand (0 min 0 sec)
ak68 is offline Find More Posts by ak68
Old Dec 17, 2012, 03:57 PM
ak68 is offline
ak68's Avatar
Nederland, ZH
Joined Dec 2011
And here is the flight before: Flight between two showers. Grey and overcast, just before darkness. Still figuring out proper COG/elevator. Nose up tendency when throttling down as can be seen when slowing down for doing slow passes. Nose down tendency when accellerating after glide or slow pass. Hints anyone?
Mako evening flight (8 min 54 sec)
AK68
Old Dec 17, 2012, 05:12 PM
aircontrol is offline
Find More Posts by aircontrol
Keep it simple, Keep it light!
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
https://vimeo.com/55797389
AK68
Hey AK68, Looks like a nice place to fly. On the nose down tendency when accellerating, make sure the motor mount has at least a 6 deg forward angle. This helps offset the thrust from the motor being above the wing. It might also be just a little tail heavy.
John.
aircontrol is offline Find More Posts by aircontrol
Old Dec 17, 2012, 09:52 PM
Nikolei Zinsli is offline
Find More Posts by Nikolei Zinsli
If it's R/C, I LIKE IT!
United States, NC, Raleigh
Joined Jun 2005
Ok I'm up to putting the outer float pieces on, but I notice with a dry fit that its a good 1/4" too tall. Will all this be trimmed off flush? Also whats the best way to pre-bend it? And finally, is the tip of the float meant to bend down a bit to meet the outer float? Doesn't seem like it'll get a tight fit a t the tip w/o doing that.
Nikolei Zinsli is offline Find More Posts by Nikolei Zinsli
Latest blog entry: 93" AJ Laser 230z
Old Dec 18, 2012, 04:14 AM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
Yes, the extra will need to be trimmed off flush. Keep corners sharp and square for better tracking in the water. Prebending can be done with a pipe or some thing round, it does not need to be heated, just apply presure and roll against the pipe. The tip of the float does not bend down, it remains parallel to the wing. Make sure you bevel the edges of the float side with a knife or sanding block.
John.
Old Dec 18, 2012, 06:18 AM
jeffpn is offline
Find More Posts by jeffpn
Joined Mar 2011
That got me, too. And I was building a virtual model for Real Flight! Of course it's alot easier to pre-bend computer generated sytrofoam than real. When I put it where I wanted it, it stayed!
jeffpn is offline Find More Posts by jeffpn
Old Dec 18, 2012, 07:39 AM
Joined Jun 2005
Thanks. Also, is there a reason that the forward vertical support doesnt come out far enough so the side touches it? Seems like it should.
What grit sandpaper works best for depron?
Old Dec 18, 2012, 01:19 PM
ak68 is offline
ak68's Avatar
Nederland, ZH
Joined Dec 2011
John.
Hello John . You are right on the tail heavyness. I did 3 more flights tonight with some extra weight shift forward and backward for testing. Backwards was worse. (Have I been drinking?) Forward was better. Given the onboard cam results i need to balance the prop incl motor. Furthermore Mako flies great. Glides excellent. Perfect dead stick landings. Funny handstand! Unlimited vertical. Next is high alfa and hover. Thanks for ideas and support.
Old Dec 19, 2012, 02:46 AM
Theodoor is offline
Find More Posts by Theodoor
Australia, VIC, Mornington
Joined Nov 2012
Have asked this question previously without any reply.
Is there a decal sheet in .pdf format so you can have a sign company produce the decals?
Recall original forum refers to decal sheet being available in the future but nothing found.
Theodoor is offline Find More Posts by Theodoor
Old Dec 19, 2012, 04:10 AM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
Sorry no decals yet, but we are getting close. We want to make sure they fit and stick good before selling them. I am building a new Mako for WMPF and testing the new coast guard decals that Rasterize designed.
John.
Old Dec 19, 2012, 06:09 PM
Theodoor is offline
Joined Nov 2012
Thanks John,
Presume we will be able to purchase a set/sheet on their own and they would be available for mailing to Australia?
Cheers
Old Dec 19, 2012, 06:29 PM
WMParkFlyer is offline
Find More Posts by WMParkFlyer
WMParkFlyer's Avatar
Jenison
Joined Nov 2009
Thanks John,
Cheers
Yes you will be able to buy the decals separate by themselves or with a plane, when they come available. We will be able to ship them world wide.
Greg M
wmparkflyers.com
WMParkFlyer is offline Find More Posts by WMParkFlyer
Old Dec 20, 2012, 08:30 PM
dabrandt22 is offline
Find More Posts by dabrandt22
Yakkity Yak IMAC is back
dabrandt22's Avatar
Rockton, IL
Joined Nov 2009
Got Mini?
Maidened the Mini Mako yesterday , which worked out well due to the first snow & blizzard here in Northern Illinois today.
Super easy build WMPF, thanks Greg & Barb!
dabrandt22 is offline Find More Posts by dabrandt22
Old Dec 21, 2012, 04:22 AM
knirps is offline
Find More Posts by knirps
United States, PA, Sharon
Joined Nov 2006
Coast Guard templates wanted
I have my Mako completed and am ready to paint or decal. I have been trying to find the Coast Guard pattern but am having no luck. The only thing that I find are pictures that when I blow them up the edges get fuzzy. Are there any graphics for these patterns out there that is available. I have a friend that owns a print shop and he gave me some film that is used for car emblems. Boy does that stuff stick. So does anyone have any links for me. Any help would be appreciated.
knirps is offline Find More Posts by knirps
Old Dec 21, 2012, 06:28 AM
TMAC4123 is offline
Find More Posts by TMAC4123
God is Good
TMAC4123's Avatar
United States, MI, Grand Rapids
Joined Jan 2011
I can't wait to fly my mako in 2 feet of snow next week!!!
TMAC4123 is offline Find More Posts by TMAC4123
New Product West Michigan Park Flyers EPP McFoamy Plus the Free Simulator Download WMParkFlyer 3D Foamies 2944 Feb 01, 2016 04:29 PM
New Product NEW! West Michigan Park Flyers 3mm Depron McFoamy to be released!! jdracing3 3D Foamies 9 May 06, 2012 12:59 PM
