Old Nov 23, 2012, 10:05 AM
WMParkFlyer is offline
Find More Posts by WMParkFlyer
WMParkFlyer's Avatar
Jenison
Joined Nov 2009
Originally Posted by atari7up View Post
After waiting for the motor , esc,servo arrived ....just finish my Mako today....with the 3 cells 2200 mah 35c the AUW is 22,9 oz , i seal the float using glass fiber cloth and finish cure epoxy , that make it waterproof and hard for rogging ......are that ok for the weight?
Will Maiden at this Sunday.....
Should fly OK ... a little on the heavy side. The fiberglass on the bottom is not necessary for water proofing. The lighter the plane the softer the landing. This plane will virtually land itself if it is built light ... I have seen pilots trim up the elevator and throttle down then set the transmitter on the ground and walk away.
GM
WMParkFlyer is offline Find More Posts by WMParkFlyer
Old Nov 23, 2012, 10:45 AM
aircontrol is online now
Find More Posts by aircontrol
Keep it simple, Keep it light!
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
*Happy Thanks giving to all our American friends
AWESOME Mako! Atari7up.
Hope you can share a video of that thing with us. Your weight is a little on the heavy side but should still fly good with unlimited vertical climb.
John.
aircontrol is online now Find More Posts by aircontrol
Old Nov 23, 2012, 11:50 AM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
Originally Posted by TMAC4123 View Post
We should have a speed contest with a mako and see how fast we can get one going =)
My 42" mako,(which I should be building soon if Greg finds time to cut the foam) will have a 1300kv motor on 4s with a 8x6 prop. It should reach speeds of 80+ mph.
John.
Old Nov 23, 2012, 11:55 AM
Jenison
Joined Nov 2009
Mini Mako Plans are up They are not quite as professional as the ones that Ken did for me but I am learning ...
See Post #3
And Merry early Christmas !!!
GM
Old Nov 23, 2012, 01:05 PM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
The plans look great. I can see a mini Mako in my future. Thank you for the plans.
Tom
carr52 is offline Find More Posts by carr52
Old Nov 23, 2012, 02:22 PM
jrsflyer is offline
Find More Posts by jrsflyer
United States, NM, Corrales
Joined Jun 2007
Thought I would share another way to connect the rudders. I like to use 1.8 mm Carbon fiber tube for my control rods. A .032", .036", or .040" wire can be glued in the end of the tube without the bulky wire wrap. I score the wire that will be in the tube with a Dremel cutting disk for better retention and cement it with epoxy.
For our rudder connections we used micro Dubro ball connectors. I cemented one of the ball connectors in the tube on one side and let it dry. I then hooked the other ball connector to the rudder and glued it in the tube so I could align the rudders before the glue dried and not have to make any adjustments later. Turned out fine and was easy to do.
My friend made these cloths pin things to hold the control surfaces parallel while you are working. They work great.
Just thought I would share.
Rick
jrsflyer is offline Find More Posts by jrsflyer
Old Nov 23, 2012, 02:33 PM
jrsflyer is offline
Joined Jun 2007
All the pictures would not fit in one blog.
Here is a close up of the ball connector end.
The tube is available from RC Foam.
rick
Old Nov 23, 2012, 08:01 PM
atari7up is offline
Find More Posts by atari7up
atari7up's Avatar
Medan , Indonesia
Joined Jul 2009
@ GM & Jhon ,
Thanks for Reply....i will try to get the video at maiden and share it here...hope the weather in this sunday is good...
Atari,
atari7up is offline Find More Posts by atari7up
Old Nov 24, 2012, 08:49 PM
boof69 is offline
Find More Posts by boof69
Joined Nov 2010
Can anyone tell me what the top speed is for the Mako?
boof69 is offline Find More Posts by boof69
Old Nov 24, 2012, 08:58 PM
jeffpn is offline
Find More Posts by jeffpn
Joined Mar 2011
Wow, Boof, I just asked the same question!!
jeffpn is offline Find More Posts by jeffpn
Old Nov 24, 2012, 08:59 PM
boof69 is offline
Joined Nov 2010
I was trying to help. Greg is online here.
Old Nov 24, 2012, 09:45 PM
Jenison
Joined Nov 2009
I just bought a new motor from Microdan I have yet to put it on a Mako ... I will be soon. The old one still needs some more repair. At some point we will reach terminal velocity and come apart. I am not sure what the aerodynamics will be like at the higher speeds but my RPM will be 23,700 at 39 oz. of thrust ... its gona be fast ... at least for a minute.
We might have to set up a couple flagmen at the field and have someone run the stop watch to see how fast the stock motor setup will push the Mako. then compare it to my new motor.
motor link: http://www.gobrushless.com/shop/inde...ef=MD2505-2900
Greg M
WMParkFlyers.com
Old Nov 24, 2012, 10:00 PM
carr52 is offline
carr52's Avatar
Joined Mar 2012
I'd be willing to bet that motor will be a screamer on a Mako. I have a 2212/6 on mine and its pretty fast. The same motor as on the Polaris.
Tom
Old Nov 25, 2012, 03:36 AM
atari7up is offline
atari7up's Avatar
Medan , Indonesia
Joined Jul 2009
Maiden my mako today...it's nice and awsome plane...the CG as perplan....the best thing from mako is the glide...realy glide nice.
like WMparkflyer & Aircontrol said weight is a little on the heavy side but should still fly good with unlimited vertical climb...a lot off fun...like so much this bird...can't wait for next week will try the performance at water spot...
Here the Maiden video that i take used HD Wing Camera...sorry if the poor quality video and can't zoom it..hope you enjoy..
Mako Seaplane (West Michigan Park Flyers New Mako Sea Plane).avi (4 min 39 sec)
Old Nov 25, 2012, 06:16 AM
mikejo_au is offline
Find More Posts by mikejo_au
mikejo_au's Avatar
Australia, VIC, Mulgrave
Joined Feb 2012
Good weather down under
Sharing another photo of the Mako, getting wet this time. The nice shot of the taxi back after a flight, was taken by flying buddy Aus, early one morning.
Enjoying getting to know the aircraft, however not yet feeling 100% comfortable with some of the Mako tricks. High speed on water will generate skipping, cured by reducing throttle, and holding a touch of up. The twin hulls seem to have a fair bit of drag, and quickly wash off speed, especially at landing. Probably just normal behavior to adapt to. Already flipped once, (attempting a crosswind take-off). No damage, just an ESC that didn't work again till dried out. Really like the glide also, and amazed at the verticals with a fresh 45c, 1650mah battery pack. Still haven't done much high alpha at lower level, need to practice slow speed handling first.
This airplane can be a demon or a clown, either way it generates smiles.
mikejo_au is offline Find More Posts by mikejo_au
New Product West Michigan Park Flyers EPP McFoamy Plus the Free Simulator Download WMParkFlyer 3D Foamies 2949 Jun 25, 2016 05:18 PM
New Product NEW! West Michigan Park Flyers 3mm Depron McFoamy to be released!! jdracing3 3D Foamies 9 May 06, 2012 12:59 PM
