Old Nov 13, 2012, 04:58 AM
nickchud is offline
Find More Posts by nickchud
What could possibly go wrong?
nickchud's Avatar
Market Harborough
Joined Apr 2006
Subscribed!
Thanks for the link to Dave on the K-Fm thread.
Sorry Dave, if it looks as though I'm following you about - you just have too many good things to recommend!
nickchud is offline Find More Posts by nickchud
Old Nov 13, 2012, 06:09 AM
suhaimi_aldi is offline
Find More Posts by suhaimi_aldi
Joined Nov 2012
Originally Posted by atari7up View Post
hii Guys...just build my mako seaplane , thanks before for the awsome plan.
be hung up until the esc and motor arrived from hk ,
my setup will be turnigy 2826-6 2200kv , turnigy plush 40A , 6 x 4E prop , 3 cells 2200mah 35C....is that ok for mako?
Bravo Mr.Atari
Nice Mako. waiting esc, brushless, etc?
waiting maiden flight you're mako, don't forget to share in this forum. OK
suhaimi_aldi is offline Find More Posts by suhaimi_aldi
Old Nov 13, 2012, 06:29 AM
baddb1 is offline
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Originally Posted by carr52 View Post
Nice flying but man that was a bit spooky. I was begaining to wonder if you were going to be able to get the plane back to you. Thanks for the video. I still haven't got to fly mine since I put the 3 axis stabilizer on it.
Tom
Thanks, yeah right after I started to fly that wind really kicked up and started to blow it backwards as I was trying to hover! You'll love the way it handles in the wind with the 3-axis stabilizer! FYI - Don't have the gain set too high on the stabilizer or your roll rate will decrease and become sort of robotic.
baddb1 is offline Find More Posts by baddb1
Old Nov 13, 2012, 07:07 AM
davereap is online now
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
question what is the correct downthrust angle, I am going with a nylon tube mount system
davereap is online now Find More Posts by davereap
Old Nov 13, 2012, 07:21 AM
nickchud is offline
nickchud's Avatar
Market Harborough
Joined Apr 2006
Great work Dave!
Are your KF steps all 6mm?
Cheers
Nick
Old Nov 13, 2012, 09:13 AM
davereap's Avatar
Joined Feb 2005
yes 6mm steps ..and all direct laminations to keep it easy... I did think of building this exactly as plan... but I just like KFm sections , it does away with the wing spars and makes the model easier to handle , just grab it anywhere on the thicker part of the wing.. and its just as easy to make it a KF as it is to fit the wing CF spars..
anyone know if WD40 will do instead of corosion X
Old Nov 13, 2012, 12:19 PM
nickchud is offline
nickchud's Avatar
Market Harborough
Joined Apr 2006
The wingtip... With steps of 6mm, the thickest point of the wing will be 18mm, That's fine while the chord is at least 180mm.
I'm interested to see what you're going to do about the wingtips. I'm sure you've got a plan!
Watching and learning!
Nick
Old Nov 13, 2012, 03:57 PM
aircontrol is offline
Find More Posts by aircontrol
Keep it simple, Keep it light!
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
6 deg down thrust angle on the motor mount. And I would not trust WD-40 for waterproofing. CorrosionX is way better!!
John.
aircontrol is offline Find More Posts by aircontrol
Old Nov 14, 2012, 12:49 AM
Tomahawk is offline
Find More Posts by Tomahawk
Tomahawk's Avatar
Southern Ontario, Canada
Joined Nov 2001
Nick
I didn't do anything special to the wingtips on my KFm4 Mako. Flat plates to the tips.
The Mako won't tipstall as it is a delta wing based platform. When it stalls, it stalls straight forward.
Chris
Tomahawk is offline Find More Posts by Tomahawk
Old Nov 14, 2012, 02:49 AM
davereap's Avatar
Joined Feb 2005
There is no need to do anything with the tips... I would worry if the %age (20%) was that high along the whole wing or a large length of it, but after two inches the numbers are more acceptable and much closer to the 10% target we aim at for our sections..
I have made quite a few deltas and propjets where the wings are similar and I have never noticed any degradation in their flight
You've got to go a lot higher with those %age numbers before you will find the wing is noticeably not performing well, and it also needs to be higher over a longer part of the wing..On deltas the numbers also drop to very low %ages down at the root.. again it doesn't matter, low numbers are fine, I never build up the step to compensate for that sort of drop..
keep it simple , 3mm deep or 6mm deep steps (preferred) are fine for this sized model..on bigger models I have gone up to as much as 12mm for the step,but now find instead that two 6mm steps across the chord do a better job and 4x 3mm would do even better..
You have to build to suit your foam, so your options depend mostly on what you've got
Thanks John 6% down it is...
The decor is all 2" tape (staples packing tape).. and the whole of the model will be covered, at the moment I am doing the clear tape where it will be staying white.. On the top there will be another white band , then the rear of the wing will get more yellow.. and the tailplain will be orange...Below it is going to be a simple blue and white design, but first Ive got to get some more blue tape..
I knocked out a couple of suitable logos..laser printed and all covered and fixed with clear tape while I was at it...
Old Nov 15, 2012, 05:39 AM
davereap's Avatar
Joined Feb 2005
decor done...the whole model is taped over...clear tape is used over the white areas
The tape added 1 3/8oz ..38gms to the model.... its now at 11.25oz including the 4x 9gm servos...so it looks like mine will be about the 21oz when done when using a 2200 battery
Below is a sketchup trace over that might help if anyone wants to make a different sized Mako..
I like sketchup for scaling models and printing...however a very good and easy to use alternative is the ScaleAndTile3 program from bill segraves
edit....its all done ...with a 2212-06 and a 6x4 prop... draw is 24A static ...AUW a bit high to the spec , at 25oz with a heavy 2200 30C lipo..The radio is set is all programmed with the recommended travels and expo, all sorted nice...
Old Nov 15, 2012, 08:16 AM
nickchud is offline
nickchud's Avatar
Market Harborough
Joined Apr 2006
Inspiring Dave!
As always.
Old Nov 17, 2012, 12:21 PM
jeffpn is offline
Find More Posts by jeffpn
Joined Mar 2011
For the RealFlight 6 build, I'd like to get a couple of pics for an area I'm having problems with. Click here for details. Feel free to post pics either in this thread, or the one I linked. I'll find them either way. Thanks.
jeffpn is offline Find More Posts by jeffpn
Old Nov 17, 2012, 02:51 PM
davereap's Avatar
Joined Feb 2005
All done with a 25oz AUW.... what are your weights?...
New Product West Michigan Park Flyers EPP McFoamy Plus the Free Simulator Download WMParkFlyer 3D Foamies 2949 Jun 25, 2016 05:18 PM
New Product NEW! West Michigan Park Flyers 3mm Depron McFoamy to be released!! jdracing3 3D Foamies 9 May 06, 2012 12:59 PM
