Old Nov 09, 2012, 12:33 PM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
Originally Posted by davereap View Post
Hi Ive only just found this design, which appeals to my taste in models, and Ive not read through the thread,,
but has anyone made this with a KFm4 section and left out the CF spars... KF'ing the wing will make for a cheaper build and make a good strong wing..
And being a KF fanatic with winter snows coming. I have just put this at the top of my building list...KF'd of course..
Howdy Dave. Welcome to the addiction of Mako. Its a really fun plane. Not to mention just plain cool.
Tom
carr52 is offline Find More Posts by carr52
Old Nov 09, 2012, 12:50 PM
Vance1 is offline
Find More Posts by Vance1
United States, FL, Leesburg
Joined Aug 2010
I followed Tomahawk's lead and built a KFm4. I am a newbie and it makes me look good when I fly it. Using a 2200KV, 3cell, 2200amp and a 7x6 prop.
Vance1 is offline Find More Posts by Vance1
Old Nov 09, 2012, 12:53 PM
Raften is offline
Find More Posts by Raften
NorCal
Joined Dec 2009
2200 amp?
Raften is offline Find More Posts by Raften
Old Nov 09, 2012, 02:27 PM
aircontrol is offline
Find More Posts by aircontrol
Keep it simple, Keep it light!
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
What motor are you using? A 7x6 prop is too big for the average 50 gram 2200kv motor.
John.
aircontrol is offline Find More Posts by aircontrol
Old Nov 09, 2012, 02:38 PM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
Something to consider if you are having trouble with taxing, is the auw of your plane and your cg. Your plane will be harder to taxi and take off if your plane is nose heavy and is over 21oz.
John.
Old Nov 09, 2012, 03:32 PM
Vance1 is offline
Joined Aug 2010
OOOPsss running a 2200Mah battery. I take it easy with the 7x6 prop until I get a 6x3. The 6x3 I was originally running had a nick in the blade and with the high KV I didn't think it should be used. I build heavy and with the KFM4 wing the weight is 29oz. It taxied and flew good with the 6x3.
Old Nov 10, 2012, 12:30 AM
Tomahawk is offline
Find More Posts by Tomahawk
Tomahawk's Avatar
Southern Ontario, Canada
Joined Nov 2001
I guess that would be me. I posted my build in pictures. Posts #299 to #302
I left out the two front CF spars but kept the rear third one. I moved that rear CF tube under the wooden motor mount. Still there is a lot of CF tube and rod required. Do read the whole thread as there are some good ideas from other posters that I wish I had seen before I constructed mine. To save you searching for it, here is the video of my KFm4 MAKO flying off water and grass.
Chris
MAKO Water and Wind (4 min 33 sec)
Tomahawk is offline Find More Posts by Tomahawk
Old Nov 10, 2012, 09:57 PM
Rasterize is offline
Find More Posts by Rasterize
The world in foam & tissue
Rasterize's Avatar
United States, NY, Rochester
Joined May 2010
Coast Guard Mako Update
After a couple of weeks on the road for business I finally have been able to get the time I needed to produce a Coast Guard Mako Decal Kit.
There are two parts to the kit. I produced part of the kit at home on my wife's vinyl cutter and had a few pieces printed and cut by a local shop. I was not going to apply the decals to this Mako but couldn't resist! Looks Like I'll be putting electronics in this one and flying this winter.
Rasterize is offline Find More Posts by Rasterize
Last edited by Rasterize; Nov 11, 2012 at 02:16 PM. Reason: Never post when your tired...
Old Nov 11, 2012, 05:31 AM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
There where two parts to the kit. I produced part of the kit at home on my wife's vinyl cutter and had a few pieces printed and cut by a local shop. I was not going to apply the decals to this Mako but couldn't resist! Looks Like I'll be putting electronics in this one and flying this winter.
Rasterize, those decals look awesome!!!!!! you do nice work.
Old Nov 11, 2012, 07:35 AM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Great job buddy. That is amazing!
rcrich is offline Find More Posts by rcrich
Old Nov 11, 2012, 09:15 AM
davereap is online now
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Work is progressing..plans were printed A4 tiled and joined...both span and length came out slightly wrong.. off by -1" on the span, similarly the length is down as well..so I must have got a wrong setting in the print box... not enough to worry about...but still my first mod was to widen both the wing and the fuzz by 20mm ..I wanted plenty of room in the fuzz and I wanted to get back some of the span ..
The fuzz decking and some of the other bits of course had to be widened to suit..
Next I drew most of the parts out onto the 2 depron sheets.. and by splitting the outer KF layers into sections I have managed to fit all parts still onto the 2 sheets..
There are just a few small depron parts to draw then I can start cutting my kit..
davereap is online now Find More Posts by davereap
Old Nov 11, 2012, 09:44 AM
GLM is offline
GLM
Find More Posts by GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Hi Raster,
Those are beautiful!
I may have to build another just to put them on
Cheers!
Gary
GLM is offline Find More Posts by GLM
Old Nov 11, 2012, 07:12 PM
Theodoor is offline
Find More Posts by Theodoor
Australia, VIC, Mornington
Joined Nov 2012
Hi Mako flyers,
Not sure how to start a New Thread so apologies if this is not the correct place.
I was wondering if those with suitable skills are abe to produce the Mako as a model to fly on the Real Flight 6.0 simulator? Seems that would be an alternative to poor weather and long nights.
Theodoor is offline Find More Posts by Theodoor
Old Nov 11, 2012, 07:19 PM
WMParkFlyer is offline
Find More Posts by WMParkFlyer
WMParkFlyer's Avatar
Jenison
Joined Nov 2009
Originally Posted by Theodoor View Post
Hi Mako flyers,
I know some that design for realflight I will see if they are willing to take on the task.
GM
WMParkFlyers.com
WMParkFlyer is offline Find More Posts by WMParkFlyer
Old Nov 11, 2012, 07:37 PM
Smoke7 is offline
Find More Posts by Smoke7
Smoke7's Avatar
Springboro
Joined Sep 2004
Just finished mine, to bad it is cold now I may try to fly next week. I do have one question. I have never build any see plane and wondering how you guys protect electronics from water. I heart some people using the balloon is that correct?
Smoke7 is offline Find More Posts by Smoke7
New Product West Michigan Park Flyers EPP McFoamy Plus the Free Simulator Download WMParkFlyer 3D Foamies 2949 Jun 25, 2016 05:18 PM
New Product NEW! West Michigan Park Flyers 3mm Depron McFoamy to be released!! jdracing3 3D Foamies 9 May 06, 2012 12:59 PM
