Old Nov 06, 2012, 04:50 PM
Russ40 is online now
Find More Posts by Russ40
Fort Smith Ar
Joined Oct 2005
Thanks Vance. Glad you liked them.
Aus...No. I just like the way it handles on the ground with the step a bit farther forward.
Russ40 is online now Find More Posts by Russ40
Old Nov 07, 2012, 03:09 AM
Tomahawk is offline
Find More Posts by Tomahawk
Tomahawk's Avatar
Southern Ontario, Canada
Joined Nov 2001
Changing the step? Why? Are we talking grass takeoffs or water?
On the water at high speed my Mako just skips along the surface without any elevator input. Pull back on the stick, it lifts off. On grass you need a little back stick on the elevator or up elevator, to overcome the drag of the floats in the grass but a non issue.
Chris
Tomahawk is offline Find More Posts by Tomahawk
Old Nov 07, 2012, 06:45 AM
baddb1 is online now
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Chris
Agree 100%. No need for changing the step! Add something slick on the bottom of the floats like Jetta Man said (the kit already comes with it) and a little up elevator and she jumps right off of the grass in15' or so.
baddb1 is online now Find More Posts by baddb1
Old Nov 07, 2012, 11:09 AM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Mine does rog and row very well bone stock.
rcrich is offline Find More Posts by rcrich
Old Nov 07, 2012, 03:49 PM
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
Originally Posted by rcrich View Post
http://www.youtube.com/watch?v=2SeuzUabVuo
a small lake near warwick ny that I tried as well.
Is that the lake right off the airport ,if so ive flown my polaris there
THESANDMAN is offline Find More Posts by THESANDMAN
Old Nov 07, 2012, 04:11 PM
rcrich is offline
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Its called glenmere lake and is close to that airport but not the lake at the airport.
If your going to any of the lakes in that area let me know and I will join you!
Old Nov 07, 2012, 06:20 PM
Vance1 is offline
Find More Posts by Vance1
United States, FL, Leesburg
Joined Aug 2010
Flying off grass Tomahawk. She would tip up on the nose and run and finally take off. Since I move the step back she pops up in 10' +/-. A wild thing this morning as I was flying touch and goes it acted like the battery shifted to the back. Some of my touch and goes are in the nature of bounce and recover. Brought it in to check. When I picked up the Mako it was cover in ice on the booms.
Vance1 is offline Find More Posts by Vance1
Old Nov 07, 2012, 06:45 PM
THESANDMAN's Avatar
Joined Oct 2010
sure thing ,but it wont be till next spring. i usually hang up the flying once it gets cold .i may pull out a plane once in a while and its usually the polaris to fly off the snow ,but other than that . its not happening .
Old Nov 07, 2012, 07:00 PM
Fort Smith Ar
Joined Oct 2005
Tomahawk...I am not saying the original design doesn't work fine. I fly off grass most of the time and I put a strip of plastic file folder on the floats. I just like it to slide with out much up elevator.
Vance...That is kinda crazy. Icing on the back will really mess with the c/g.
Old Nov 07, 2012, 07:39 PM
Vance1 is offline
Joined Aug 2010
I am a newbie so maybe I should not enter the discussion but everything I have understood about pontoons and seaplanes the CG is matched with the step. I love my Mako thanks guys for the plans.
Old Nov 07, 2012, 08:04 PM
aircontrol is offline
Find More Posts by aircontrol
Keep it simple, Keep it light!
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
That is what these discussions are for, to work out problems with the planes and with the pilots learning to fly. so dont hold back. Everyone has a differant experiance and view. the trick is using this information to make a better plane.
John.
aircontrol is offline Find More Posts by aircontrol
Old Nov 08, 2012, 01:33 AM
Aus is offline
Aus
Find More Posts by Aus
Aus
ʎןɟ inverted ɹǝpunuʍop
Aus's Avatar
Australia, ACT, Amaroo
Joined Jul 2011
Originally Posted by aircontrol View Post
I dont think you have done anything wrong. The Polaris has a longer more gradual float bottom, the Mako is shorter and has more angle on the float bottom to help it on the water, this makes the Mako more prone to tip forward when taxing. The Polaris also has this problem and have had problems taking off becuse there is so much drag. I have not really had much problem with the Mako, I give up elevator or down depending if I want to take off or turn. I will talk to Greg and Mike and will look at changing the step.
John.
Good points. Are Greg and Mike the designers of the Mako? If so, I would be very keen to hear their opinion on the step before I start to cut some depron. No rush though, it is a while off making it to the build bench.
Aus is offline Find More Posts by Aus
Old Nov 08, 2012, 02:46 AM
Tomahawk is offline
Tomahawk's Avatar
Joined Nov 2001
I guess if you guys only fly off grass then you might want changes.
Do post your changes. When I built my Mako I really changed the build from the recommend layout.
My Mako is mostly for water and grass a very distant second.
For water operations the Mako is setup perfect with the step and cg.
Chris
Old Nov 08, 2012, 02:49 AM
Tomahawk is offline
Tomahawk's Avatar
Joined Nov 2001
Do enter the discussions, that is how we all learn.
To the reading I have done, the step should be slightly aft of the planes CG.
Chris
Old Nov 08, 2012, 05:03 AM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
I designed the Mako last winter with many prototypes and differant float and wing designs so finding cg and the placement of the step has long history. Moving the step is not going to make a huge differance, it will just tip back a little easyer when setting on flat ground. If you want it to ride level on the ground, then you should put wheels on it
John
New Product West Michigan Park Flyers EPP McFoamy Plus the Free Simulator Download WMParkFlyer 3D Foamies 2944 Feb 01, 2016 05:29 PM
New Product NEW! West Michigan Park Flyers 3mm Depron McFoamy to be released!! jdracing3 3D Foamies 9 May 06, 2012 01:59 PM
