Old Jul 22, 2012, 06:55 PM
WMParkFlyer is offline
Find More Posts by WMParkFlyer
WMParkFlyer's Avatar
Jenison
Joined Nov 2009
West Michigan Park Flyers New Mako Sea Plane
Standard Mako Sea Plane
West Michigan Park Flyers LLC
Brings you the new Mako Sea Plane
Mako intro movie.mp4 (17 min 45 sec)
Click here to Order Yours Today
Full size Mako
Depron 6mm:
-Wing sheet 1 and 2
-Float Sheet 1 and 2
-2 narrow part sheets #1 and #2
Carbon Fiber 4 X 3 Tube 3 pcs. 39 inches long, cut to the following sizes.
-#1) 30 inches
-#2) 15 inches, 15 inches, 9 inches
-#3) 24 inches, 15 inches
Carbon Fiber 1.5 solid 2 pcs. 39 inches long, cut to the following sizes.
#1) 18, 5,5,8
#2) 16-1/2, 6-3/4, 6-3/4
Mako Wooden control horn and parts set.
Piano wire ( 3 ) 90 degree ( 5 ) Z-bends and 2 straights.
Dubro E-Z connects ( 2 )
Dubro Micro E/Z Link ( 3 )
Heat Shrink 6 pcs
Fiberglass Adhesive Sheet 2) two inch strips 13in. long.
3/8 X 1/16 Hatch Magnet ( 1 )
10-24 Flat head Machine screw ( 1 ) for hatch pull
We will be offering decal sets for this plane in the near future.
We are beginning production on this airframe and are going to run 20 kits this week. Kits will begin shipping out on 7/30/12
Plane Specifications:
- Wing span 32
- Length 35
- Weight - (without battery) 13.5 oz (with battery) 18 to 22 oz
- Motor: 2212 1900 KV or 2212-2200 KV
- Prop: 6X4E or 6X5E
- Battery: 1500 mah to 2500 mah 11.1 V (2200mah is a good size with a 9min flight time)
- Speed Control: 30 or 40 Amp
Additional Items Needed to complete kit:
- Glue Foam Tac or Gorilla Glue
- Velcro
- 4 - 5 gram servos
- 1900 KV 2200 KV motor
- 6 x 5 6 x 4 electric prop
- 30 Amp 40 Amp ESC
- 10 12 servo wire extensions
- Blenderm Tape for hinges
- 11.1v 1500 mah 2500 mah battery
- Paint or decals
- Screws to mount motor to plywood
- Corrosion X (water proofing for motor, esc, receiver).
Suggested Throws & Expo
Elevator low rate, 40% Expo and 1/2" throw both ways.
Elevator high rate, 60% Expo and 1-1/4" throw both ways ( this is needed for a hand stand)
Aileron low rate, 30% Expo and 3/8" throw each way.
Aileron high rate, 50% Expo and 3/4" throw each way.
Rudder, 60% Expo and 1-1/4" or more! throw each way.
Plans & Build instruction down load links listed Below:
Ordering information:
Full size Mako
Order Now at http://www.wmparkflyers.com/Pages/MakoSeaPlane.aspx
WMParkFlyer is offline Find More Posts by WMParkFlyer
Old Jul 22, 2012, 06:56 PM
Jenison
Joined Nov 2009
42 Inch Mako XLThe Mako XL is just like the original, only larger! Available at wmparkflyers.com
See #1 Post for Mako and Mako XL build instructions
Specifications:
- Wing span – 42”
- Length – 46”
- Weight - (without battery) – 26 oz (with battery) – 37 to 42oz
- Center of gravity is 16 1/2” from tip of floats
- Motor: Suppo A2814/6 - 1400 KV (3s) or A2814/8 - 1100 KV (4s)
- Prop: 8X6E or 9X5E
- Battery: 3300 mah (4s) to 4000 mah (3s) (min of 330g battery weight needed to balance plane)
- Speed Control: 60 Amp
- 9 gram servos, 2 Aileron Servos
- 11 gram Goteck GS-9025MG Micro Analog 11g Metal-Gear Servo (STRONG) for rudder and elevator
- Servo Extensions Same as original mako. 300mm or 12inches. Longer will work to, but not shorter.
Motor-prop recommendations:
4s - Suppo A2814/8 - 1100 KV with 9x5e prop.
14.8v 3300mah battery (need 330g weight to balance plane)
60 amp esc
4s - Exceed RC rocket motor 3015 - 1300kv with 9x4.5e prop.
60 amp esc
4s - SunnySky X2814 KV1250 with 9x4.5e prop.
60 amp esc
3s - Suppo A2814/6 - 1400 KV with 9x6e prop.
11.1v 4000mah battery (need 330g weight to balance plane)
60 amp esc
See http://www.rcgroups.com/forums/showp...postcount=1471 for pics and more information.
42 inch Mako XL Takes flight on the water
42 inch Mako XL Water Maiden in the Wind and Rain
42 INCH MAKO WATER MAIDEN IN THE RAIN (12 min 11 sec)
Jenison
Joined Nov 2009
Mini Mako
Product Details
The Mini Mako is a EPP foam parkflyer, designed to fly indoors during winter months, but it also flys very well outside. With its low center of gravity and light weight it makes a good beginner plane. It slides on hardwood floors, concrete, and black top. Sorry it does not fly off of water, grass, or snow.
Specifications:
- Wing span – 25”
- Length – 27”
- Center of gravity is 10" from tip of floats
- Motor for light indoor flight: C2403 - 2100KV (2s 800mah battery)(7oz auw)
http://www.hobbyking.com/hobbyking/s...dproduct=12681
- Prop: 8x4DD cut down to 7" or 7x5sf prop
- Speed Control: 10 Amp
- 5 gram servos, 3 total
Material EPP 9mm: All parts laser cut w / spar grooves.
  • Carbon Fiber 3mm X 2mm Tube 2 pcs. cut to the following lengths.
    #1) 21 inches 11 inches
    #2) 10 inches 10 inches and 7 inches
  • Carbon Fiber 1.5mm solid 1 pcs. cut to the following lengths.
    10 in. 10 in. (aileron) 17 in. (rudder) 6 in, Rudder connector
    Note: The 6 in. rudder connector is not in the PDF listed below. We need to correct this error as soon as I can get back to the Cad.
  • Carbon Fiber 1.2mm solid 2 pcs. each of the following lengths for trussing. (working from the front of the plane to the back)
    2-1/2 , 3-3/8 , 4.0 , 4-1/8 , 4-3/4 , 3-3/4
  • Carbon Fiber 1.2mm solid 2 pcs. 4.0 in long tail struts.
  • Mini Mako Wooden control horn and parts set.
  • Piano wire – ( 5 ) Z-bends and 4 straights.
  • Dubro E-Z connects ( 5)
  • Heat Shrink 6 pcs
Can be ordered in unpainted or painted 9mm EPP
Order Now at http://www.wmparkflyers.com/Pages/MiniMako.aspx
Old Jul 22, 2012, 06:58 PM
aircontrol is offline
Find More Posts by aircontrol
Keep it simple, Keep it light!
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
Hi everyone,
The Mako is a depron foam parkflyer, designed to fly off of water, snow, and grass. It is fun to fly and easy to land. It flys well both fast and slow. I am very excited to see the Mako going into production, Greg does a wonderfull job on these kits, the plywood servo trays allow easy installation and removal of the servos, and the control horns fit nicely into the laser cut slots. Here are some pictures and videos of the Mako, hope you all enjoy it as much as we do.
New fresh water shark (3 min 8 sec)
Mako from boat (5 min 12 sec)
MY VIDEO (4 min 38 sec)
Fiberglass hinge tutorial (3 min 51 sec)
Flite Test | Waterproofing Electronics (18 min 20 sec)
Some of my build pics.
aircontrol is offline Find More Posts by aircontrol
Old Jul 22, 2012, 06:59 PM
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
New Mini Mako
Suggested Throws & Expo for Mini Mako
Elevator low rate, 30% Expo and 3/4" throw both ways.
Elevator high rate, 50% Expo and 1-1/4" throw both ways ( this is needed for a hand stand)
Rudder, 50% Expo and 1-1/4" or more! throw each way.
Some of my build pics!
aircontrol's Avatar
Jenison Michigan
Joined Apr 2008
Show us your MAKO!
One of the neat things about these threads is seeing other peoples designs and paint schemes, so if you have a Mako, please post some pictures.
Old Jul 22, 2012, 07:04 PM
r/cdawg is offline
Find More Posts by r/cdawg
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
You guys are going to love how this flies. Greg will be posting some video shortly which really shows what it is capable of.
r/cdawg is offline Find More Posts by r/cdawg
Old Jul 22, 2012, 07:05 PM
r/cdawg is offline
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
I'll be doing some build pics and such in this post. I plan to start building my second one tomorrow.
r/cdawg is offline
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
I'm going to be renting a cottage on Lake Michigan in a couple weeks so I plan to post pics and videos in this post. Stand by, it's going to be fun. The Mako is a sweet plane.
Old Jul 22, 2012, 08:16 PM
TMAC4123 is offline
Find More Posts by TMAC4123
God is Good
TMAC4123's Avatar
United States, MI, Grand Rapids
Joined Jan 2011
This is a great flying airplane! Easy to build and fly! For those who are 3D junkies, it will pop-top and and do rolling harries! Check out these video's out I have recorded! Here is one-
Tristen flying west Michigan park flyers Mako (3 min 43 sec)
TMAC4123 is offline Find More Posts by TMAC4123
Old Jul 22, 2012, 08:20 PM
TMAC4123 is offline
God is Good
TMAC4123's Avatar
Joined Jan 2011
Here is another one
West Michigan Park Flyers Mako (4 min 39 sec)
Old Jul 23, 2012, 07:32 AM
Russ40 is offline
Find More Posts by Russ40
Fort Smith Ar
Joined Oct 2005
Very cool guys. I want one. When will the kit be ready for purchase?
Russ40 is offline Find More Posts by Russ40
Old Jul 23, 2012, 11:53 AM
r/cdawg is offline
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
Hi Russ,
Yes the Mako is very cool. I think Greg is ready to ship these but he'll be on here shortly to confirm.
dawg
Old Jul 23, 2012, 06:08 PM
Russ40 is offline
Fort Smith Ar
Joined Oct 2005
Cool thanks dawg. I was in your neck of the woods last week. My sister lives in Wayland. I was up there for a visit.
Old Jul 23, 2012, 07:55 PM
Jenison
Joined Nov 2009
You were in Wayland and you didn't stop by? You could have saved your self some shipping. I had 5 kits in the car left over from a show mid week.
I will have the buy now button up tonight and kits will begin shipping one week from today.
GM
New Product West Michigan Park Flyers EPP McFoamy Plus the Free Simulator Download WMParkFlyer 3D Foamies 2949 Jun 25, 2016 05:18 PM
New Product NEW! West Michigan Park Flyers 3mm Depron McFoamy to be released!! jdracing3 3D Foamies 9 May 06, 2012 12:59 PM
