Old Jul 22, 2012, 04:31 PM
garrcass is offline
Find More Posts by garrcass
bucket of prop wash
garrcass's Avatar
reddinng CA
Joined Nov 2007
Help!
Push button Servo controller for digital servo ?
I am looking for a way to controll a servo with a push button.. 12v and be able to set the travel with it.. I would need to make it semi water proof.. I basicly need a push on release off switch with one way of travel and a nutral when button is in the off position.. any ideas would be great
garrcass is offline Find More Posts by garrcass
Old Jul 23, 2012, 04:04 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
I'm not quite sure what you are asking for and how it is supposed to operate, but from your general description it sounds like you may want to look into using a stepper motor rather than a servo.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Jul 27, 2012, 10:58 PM
garrcass is offline
bucket of prop wash
garrcass's Avatar
reddinng CA
Joined Nov 2007
I need it to be instantanious and quick with a lot of power.. I was going to use a large digital servo but I have 12v at my disposal and I need some way to control the servo..
Old Jul 28, 2012, 04:49 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I think 'high voltage servos' are limited to about 7.4v, though just how much more volts they would take before destruction........., it will also depend on the servo load.
If you are into making or modifying your own electronics, it could be done with a PIC chip and some programming, or even with a simple servo tester.
A servo tester generally uses a pot to control the angular position, so you could modified one by replacing the pot with fixed resistors via push button switches.
It may be simpler to ask in the - DIY Electronics forum - but do specify exactly what you want it to do, they are the 'wizz kids', but guessing what you need or are experimenting with wont help.
eflightray is online now Find More Posts by eflightray
Sold Align RCE-B6X voltage regulator with push button glow - $18 shipped kayvannouri Aircraft - Electric - Helis (FS/W) 2 Jul 02, 2012 10:27 AM
Help! Looking for tiny push button switch for my Tx trim gtfreeflyer DIY Electronics 16 Nov 26, 2009 12:35 PM
Discussion Can a servo be too small to push a shutter button? Dan_K Aerial Photography 14 Nov 01, 2008 06:35 AM
