Old Jul 22, 2012, 07:29 PM
David Canfield is offline
Find More Posts by David Canfield
Toledo, OHIO
Joined May 2007
Here is the second crash, could have been radio loss but i was not that far out.
Naza GPS crash (3 min 46 sec)
Just for giggles here is a video of the radio when flying my compass 7hv. If i had drifting problems in my pots i would have major problems with the beast x flybarless system because it reacts to trim as an input. Meaning you can not use trim or subtrim or you will have major issues.
compass7hv (8 min 19 sec)
David Canfield is offline Find More Posts by David Canfield
Old Jul 22, 2012, 07:55 PM
Chris Moon is offline
Find More Posts by Chris Moon
Fort Worth, Texas
David,
That looks identical to the problem with one of my Naza's. I just put together a hex with a naza, and it is perfect... for now... Hopefully it stays that way.
Chris Moon is offline Find More Posts by Chris Moon
Old Jul 22, 2012, 08:26 PM
blade strike is offline
Find More Posts by blade strike
DJI Testing / US Support
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
http://youtu.be/CFs9YDHjjuU
https://www.youtube.com/watch?v=T1-64sM0wMM
Yeah man I would be at a loss also... what I would do, is recreate the issue and then plug her in. Let's see what the software is seeing.. right now we are all shooting in the drak!
blade strike is offline Find More Posts by blade strike
Site Sponsor
Latest blog entry: Dji m600
Old Jul 23, 2012, 02:42 AM
The Recursion is offline
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
I also get GPS problems frequently at random. Works perfectly, then at times takes off in a random direction and keeps attempting to fly that way. Switching to ATT or Manual stops the drift, but switching back causes it to fly away again.
Not confirmed, but I'm pretty sure this happens when I go from full signal to 'less' of a signal on GPS when flying outdoors, but this does not occure every time this has happend. For now, I use the GPS, but don't rely on it.
The Recursion is offline Find More Posts by The Recursion
Old Jul 23, 2012, 05:35 AM
Fort Worth, Texas
Maybe we can compare serial numbers to see if maybe that has some relation to the problematic nazas?
At least the first 6 or 7 numbers...
Old Jul 23, 2012, 08:01 AM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
Possibly the GPS is lossing sats in flight but without the means to see the actual count real time there is no way to know. It is very possible to have a high count on the ground but lose them once the aircraft is in motion because the movement makes it harder to maintain contact. It is also possible to have sats aquired but with weak signals that are fragile. I've flown FPV from the beginning with OSD's that display GPS data and have experienced the sat loss myself. My problems were caused by RF interference from other on-board electric devices.
There is a free PC software that shows the strength of the individual sats, which is helpful during ground testing when you can disconnect other components one by one to see the affect. It does however require special cabling to splice into the GPS signal.
Gary Evans is offline Find More Posts by Gary Evans
Old Jul 23, 2012, 08:48 AM
R Hudson is offline
Find More Posts by R Hudson
R Hudson's Avatar
United States, CO, Denver
Joined Dec 2002
I noticed last night that when hovering in place I would have the consistent single green flash in GPS mode but when I would move around via pitch or roll I would get quick double or triple flashes of red followed by one green which indicates partial loss of gps signal. It does that any time I pitch or roll while in GPS mode so that would indicate to me that there may be elctrical interference going on. Does anyone concur with that theory?
R Hudson is offline Find More Posts by R Hudson
Old Jul 23, 2012, 09:26 AM
Joined Jan 2006
That just means the controller is receiving stick input .. So that is also a way to tell if trim is enabled or something is feeding the fc a stick input!
Site Sponsor
Old Jul 23, 2012, 10:01 AM
R Hudson is offline
R Hudson's Avatar
Joined Dec 2002
Thanks for the info. Hmmm.......interesting. One thing for sure, I've been into airplanes and helis for years. So far multis have involved the most massive amount of information so far. I do mean this as a good thing though
Joined May 2012
Doesn't 'two green' flashes indicate the stick input not being centred? Tripple red would mean the GPS signal is lost, which is the same symptoms I seem to be seeing some of the time.
Old Jul 23, 2012, 10:24 AM
Mesa, Arizona
Joined Nov 2006
Triple red means it has less than 5 sats so it could be 0-4. Manual P38.
Old Jul 23, 2012, 10:28 AM
Joined May 2012
Right. I'm just pointing out the red flashes has nothing to do with the stick inputs.
Old Jul 23, 2012, 11:25 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Battery specs? Age? Balanced every charge?
Could be a brownout...
MCrites is offline Find More Posts by MCrites
Old Jul 23, 2012, 02:21 PM
Toledo, OHIO
Joined May 2007
My batteries are less than two months old, I fly once a week and always balance charge every time.
My receivers on all three crash had solid lights indicating no loss of receiver power.
Old Jul 23, 2012, 03:34 PM
Joined Jan 2006
re-reading his post he did say red flashes with green.
Yes red flashes are loss of gps lock... But double green is gps with some kind of stick input..That will give you an idea about radio drift or anything else.
Site Sponsor
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20274 May 20, 2016 12:54 PM
Build Log Build/How-To Report: DJI Flame Wheel F550 feat. Wookong M + NAZA PitchBitch.EU Multirotor Talk 1 Apr 19, 2012 05:27 AM
