Old Jul 22, 2012, 04:30 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Hollow inrunner motor shaft
Hi guys,A question for you.Would it be possible to fit an in runner motor with a tube shaft.What I am looking to do is fit a nut to the tube to drive a 2or3mm threaded rod which would pass through the motor.
I must stress that my knowledge of motor construction is zero;I have no figures as to the power needed for the application,which is a possible design for a swing wing mechanism.
Any advice would be greatly appreciated.
Best regards,Stuart
Stuart A is offline Find More Posts by Stuart A
Old Jul 22, 2012, 07:52 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
When inrunners are manufactured the magnets are bonded to the shaft with a glue (epoxy normally I think) and. in some cases, even wrapped with Kevlar to keep the magnets from breaking or coming off at high RPM. So getting a shaft out and replacing it with another is not easy to do.
If no one sells inrunners with hollow shafts I'd think you would have to get the hollow shaft and move your magnets to it and fit it to your motor. A pretty ambitious undertaking...
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jul 22, 2012, 08:18 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Jack
Thanks for the info Jack.Back to plan A,fitting a screw rod extension to the shaft.
Regards Stuart
Old Jul 22, 2012, 08:20 AM
modisc is offline
Find More Posts by modisc
Inspiration
modisc's Avatar
United States, MI, Ann Arbor
Joined Aug 2011
Best regards,Stuart
As Jack said, probably you will not find any inrunners in the market, with a hollow shaft. Changing the shaft of an inrunner is hardly possible, but for out runners, it is much easier. You might be able to find a steel tube matching your needs for an outrunner.
modisc is offline Find More Posts by modisc
Old Jul 22, 2012, 08:29 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Just found an eflite Park 370 with a 4mm hollow shaft which could do the job.Thanks to all
Regards Stuart
Old Jul 22, 2012, 12:06 PM
Jack
USA, ME, Ellsworth
Joined May 2008
I knew of that, and it did not cross my mind.
That motor is part # EFLM1210HS, 1.6 oz./45 gram and a 1200 Kv.
The shaft is, at least in theory, available as a repair part:
http://www.horizonhobby.com/products...aft-EFLM1210HS
The motor is listed as 24mm long so the shaft might be 2" or a little more in length.
Jack
Wanted Looking for brushless inrunner motor 2 maybe 3mm shaft eaglescry24 Boats (FS/W) 5 Aug 21, 2012 10:40 AM
Discussion Removing Hollow shaft from Lama 400D Krazydy Coaxial Helicopters 4 Jun 02, 2012 08:02 PM
Sold Park 370 out runner with hollow shaft and Park 370 inrunner NIB Steve H. Aircraft - Electric - Power Systems (FS/W) 2 Nov 10, 2009 09:54 PM
Sold 25/17 Hollow Shaft Brushless Motors - CHEAP punkindrublik Aircraft - Electric - Airplanes (FS/W) 5 Oct 11, 2005 08:27 PM
Sold 25/17 Hollow Shaft Brushless Motors - CHEAP punkindrublik Aircraft - Electric - Airplanes (FS/W) 3 Oct 07, 2005 02:14 AM
