Old Jul 22, 2012, 12:37 AM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Help needed for mixing twin engines to rudder- Futaba
I am using the Futaba 10C, and am having a hard time putting my electric motors on separate channels.
I slaved the Aux to the throttle channel and plugged motor two into Aux and motor one into Thro.
the slaved channel (Aux) dos not start the motor until past 50% throttle.
Ideally I want to mix the motors to the rudder channel- but I am getting very frustrated with this programming...
Any guidance is much appreciated.
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Dayum Fine Custom Pilot
Old Jul 23, 2012, 01:40 PM
USA, GA, Atlanta
Joined Nov 2008
I would greatly appreciate it if another member might be able to step up and help me out with some tips...
Old Jul 23, 2012, 02:10 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I can only offer general advice, as I'm not familiar with your specific transmitter, but maybe someone else who is will step in.
First general advice. Never experiment with motor settings and mixes with the model plugged in! Do all your setup work using the transmitter's display screen. It will tell you everything you need to know without the risk of motors starting!
Second, the issue with the slaved second throttle channel only starting at mid throttle is a matter of mix settings. Maybe you only set the mix for the up side of trhe curve (there are normally two numbers that must be set, like +100% and -100%). If that doesn't do it, there should be an offset number. Try -100%. Look at the results on the display screen, which is far more informative than whether the motor starts!
Third, once you've got the two throttle channels working in unison, which should be very easy, you will need to look at the steering mix. The first thing to recognize is that the mixes you want are from rudder to the two throttles, not throttle to rudder as you describe it.
The following may give you some ideas as to how the various mixes are set up in general terms. It's not about Futaba but the principles are the same.
http://www.rcgroups.com/forums/showp...postcount=2483
Note that the key term for searching is "differential throttle".
Hope this helps.
EDIT: Here's what Futaba says:
http://www.futaba-rc.com/faq/faq-10c-2_4ghz-q1168.html
Daedalus66 is offline Find More Posts by Daedalus66
Old Jul 23, 2012, 03:15 PM
USA, GA, Atlanta
Joined Nov 2008
You are a Rockstar!!! Thanks a ton, despite your not being familiar with my radio, I think you got it but I need to check when I get home.
I had the up and downside set at +100/-100, and was having the problem, but I will play with the offset number and see if that does it.
Thanks also for correcting the order of the mix- rud to throttles
You made a happy guy! I will read up on differential thrust; thank you so much!
Old Jul 23, 2012, 04:23 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Don't get too enthusiastic. I'm not sure about how my advice applies to a Futaba.On my JR 9303, all I have to do to get the two channels working in unison is to select INH for AUX 2 to make sure it doesn't respond to a switch or lever. Then I go to one of the programmable mixes and set it to THRO --> AUX2. Bingo, both channels show up on the monitor as moving together.
In retrospect, it may be that all you have to do is to inhibit the channel you are using for THRO2. You may be seeing the effect of a still functioning switch, on top of which the throttle mix input is superimposed.
Discussion Twin Engine Rudder Mixing Screw Electric Plane Talk 7 Jun 13, 2012 04:24 PM
Help! Older Futaba heli radio question...need to mix for elevons Jimmy JFlyer Radios 2 Mar 06, 2012 08:11 AM
Help! Futaba 9cap twin engine throttle/rudder mixing. kawika1kalina Radios 5 Jan 22, 2010 05:34 PM
Multiplex Cockpit -- Rudder throttle mixing for twin? Nowell York Radios 7 May 06, 2003 07:33 AM
Futaba T6XA Super: Twin motor, throttle-rudder mixing Zeuser Radios 4 Jan 21, 2003 09:35 PM
