This thread is privately moderated by SkylineFlyer, who may elect to delete unwanted replies.
Old Jul 21, 2012, 11:06 PM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
Gallery
FlyFly 90mm BAE Hawk w/ CS12 90mm fan
Not much to say on this, but just wanted to share a couple photos as I built this plane. This was a easy and fun build. If anyone has any questions, just ask.
CS-12 90mm FlyFly BAE Hawk (4 min 5 sec)
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Jul 22, 2012, 10:11 PM
Hawk Fanatic
Joined Jul 2008
Here are some more pics of this plane in flight. I've got 6 flights on it now in two days. It flys amazingly!
Old Jul 27, 2012, 08:22 AM
nortrop is offline
Find More Posts by nortrop
Italy(Rome)
Joined May 2006
Hello Sky..
I'm Nortrop from Italy. Just some opinions about, building, foam qualities and CS 12. I just bought one HTG Hawk and really negative impressed by the different material from the others i've got( MB 339 and L-39) These lasts was mauch better than HAWK. In any case, I'm sure it will give big satisfations...for all the rest.
My setup will be:
CS 12
Het 600-42 1400 KV
Superbrain 100 REG
8S 4000 40C Lipo
I'm not sure about retractable landings, in case wich one???(suggestion)
Let me even know, if you can, the RTF Heavy
Any other suggetion will be appreciate
Tk bye
g
nortrop is offline Find More Posts by nortrop
Old Jul 27, 2012, 06:17 PM
Hawk Fanatic
Joined Jul 2008
Originally Posted by nortrop View Post
Hello Sky..
My setup will be:
CS 12
Het 600-42 1400 KV
Superbrain 100 REG
8S 4000 40C Lipo
Tk bye
g
Hi Nortrop, if you aren't familiar with HTG (FlyFly) older stuff, then yes, the foam (EPS foam) on the Hawk will leave you feeling a little unimpressed. The FlyFly F-86 was of the same foam, so expect to feel the same with it. As for the MB339 and L-39, yes, those are very nice planes. They are made of a different foam. EPO to be exact.
The retracts I'm using are these... I'm also using the nose strut. But I ditched the Mains as they are to short. I then order some new Main struts (next link below)
http://www.hobbyking.com/hobbyking/s..._45_L_59_.html
http://www.hobbyking.com/hobbyking/s...dProduct=23884
You have to order two Main Struts though. Only 1 comes with each order.
I then use the same wheels that came with Retracts above.
Old Jul 27, 2012, 06:28 PM
Hawk Fanatic
Joined Jul 2008
FlyFly BAE Hawk 90mm ChangeSun 12 Blade Fan (4 min 54 sec)
Old Jul 30, 2012, 02:07 AM
nortrop is offline
Italy(Rome)
Joined May 2006
Tk for your replay,
yes! The EPS it' s the worst surprise at all. My heavy hands will not appreciate the building time.
Anyway, I just end my HTG L-39(picture) and will start building HAWK when temperatures will go down. Here too hot now for EDF.
Do you know a good link for building log?
Old Aug 28, 2012, 07:06 AM
jetspeeds is offline
Find More Posts by jetspeeds
Sunshine Coast
Joined Apr 2010
Hi Sky. Can you please tell me what you are using for fan, motor, esc. Battery size>>??
jetspeeds is offline Find More Posts by jetspeeds
Old Aug 28, 2012, 08:45 AM
Hawk Fanatic
Joined Jul 2008
Sure thing. I'm using a CS12 Blade 90mm fan, CC ICE 100A ESC, HK3025-1500kv motor, and a 6s5000mAh lipo.
Question Flyfly/Topgun Bae Hawk 90mm CG and throws? flemsus Foamy EDFs 2 Apr 10, 2012 06:02 AM
Sold NIB E-Flite BAe Hawk w/Fan, motor & ESC 1stplaceaviator Aircraft - Electric - Jets (FS/W) 1 Mar 26, 2012 07:02 PM
Discussion BAE Hawk motor question w/Midi fan....edit: anyone using 90mm Midi fan??? CSI Foamy EDFs 25 Mar 15, 2010 10:01 PM
