Old Jul 21, 2012, 03:58 PM
my c210 is offline
Find More Posts by my c210
Resident giant scale guru
my c210's Avatar
Picayune, MS
Joined Oct 2007
1/2a Micro Telemaster is done!
I kit bashed a micro telemaster to accept a norvel .061 AME on a tank mount. I had to move the firewall back almost to the first bulkhead to get it to fit, but if does! The landing gear I bashed, making it a piper cub style gear, with faux airfoiled bungee covers. I still have some electronics to install but the basic build is done. I really want to send this model in to Model Aviation's "Focal Point".
my c210 is offline Find More Posts by my c210
Old Jul 21, 2012, 04:41 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Looking good, will be an excellent flyer!
coriolan is online now Find More Posts by coriolan
Old Jul 21, 2012, 07:39 PM
Gnu4FF is offline
Find More Posts by Gnu4FF
United States, TX, Spring
Joined Jul 2010
Might put a thin aluminum heat shield (pop can material) behind the exhaust outlet.
Gnu4FF is offline Find More Posts by Gnu4FF
Old Jul 21, 2012, 08:01 PM
my c210 is offline
my c210's Avatar
Picayune, MS
Joined Oct 2007
I'm way ahead of ya! Exhaust exits through brass tubing out the bottom of the fuse.
Yes I know... The firewall and cheeks are getting fuel proofed tonight.
Old Jul 24, 2012, 03:28 PM
Vince77 is offline
Find More Posts by Vince77
Registered Misuser
Vince77's Avatar
United States, CA, Tehachapi
Joined Jan 2004
Awesome. Plane and simple. Last Telemaster I saw was a giant putting overhead at a swapmeet...
Vince77 is offline Find More Posts by Vince77
Old Jul 26, 2012, 10:02 AM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
Very nice indeed mate... might I ask if there are plans available for the Mini Tele? Wouldn't mind having a crack at it at all, and I do have a .061 hanging around!
I've got a set of plans for the 'Mini Tyro' but would much rather a Telemaster.
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Aug 24, 2012, 08:49 PM
Alexandre Cruz is offline
Find More Posts by Alexandre Cruz
Joined Nov 2004
I am interested too. I have a ton of 0.49 hanging here needing a plane
Alexandre Cruz is offline Find More Posts by Alexandre Cruz
Old Aug 27, 2012, 10:39 PM
RknRusty is offline
Find More Posts by RknRusty
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
It's gonna be a fast little sucker. I hope you'll take your video cam when you fly it. Great work.
RknRusty is offline Find More Posts by RknRusty
Old Aug 27, 2012, 11:29 PM
William Gomes is offline
Find More Posts by William Gomes
Brazil
Joined Feb 2007
Very Nice !
Very Nice Telemaster ;
always a lovely plane .
Any chance to post a plan ? I have a small electric setup ready to install on it .
I got a mini tyro plans from RCME magazine some months ago , but ,,, you know a telemaster have much more presence .
Thanks in advance to anyone .
William Gomes is offline Find More Posts by William Gomes
Old Aug 28, 2012, 02:36 PM
hlsat is offline
Find More Posts by hlsat
hlsat's Avatar
Ελλάδα, Ανατολική Μακεδονία Θράκη, Βιστωνίδα
Joined Jul 2006
Here the plans in Zip file with inside Pdf and Dxf file for the plane Telemaster 400.
36.5in. wingspan.
Engine Electric.
Good building.
Elijah Greece.
hlsat is offline Find More Posts by hlsat
Old Aug 28, 2012, 04:07 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
It's great to see that Telemaster 400 drawing still passing around. I drew that based on the 40 size plans in '99 or so. Actually, the DXF says 1/29/99.
I need to build one for a Norvel.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Aug 29, 2012, 02:25 PM
Brazil
Joined Feb 2007
Thank You
Thanks a lot for the plans ,
now I will to tile print it , select the balsa and star to cut in a few days .
I order these itens in hobbyking , what do you think ? Is a good choice ? Any advice about the gear ?
Old Aug 29, 2012, 03:09 PM
coriolan's Avatar
Canada
Joined Sep 2006
Good motor choice William:
http://www.hobbyking.com/hobbyking/s...Outrunner.html
Will be almost the same weight as an 1/2A power with more power and the advantage of speed control! The recomended 8X4 prop for two cell pack is more efficient than the small prop used with a .049<.10 glow engine.
Old Aug 29, 2012, 08:03 PM
boingk is offline
boingk's Avatar
NSW, Australia
Joined Feb 2011
Hi there Will, good to see you getting keen on building the little Tele!
I've a few tips on the gear:
1: Get the slightly larger 4.3g servos in that series if you can... they're only a half gram heavier (actual weight) but have a good amount more torque. I find that they are generally a nicer servo than the tiny 3.7g's and at only a very minor penalty in size and weight.
2: The motor seems fine as long as its in the 1500~2000kv range. I would personally fit a Hextronik 24g 1700kv motor and run an MAS 7x5 prop on an 800~1000mAh 3-cell pack. They are good motors that are cheap and run extremely well. Use an 18A ESC and expect good sport performance once you get used to her.
With the gear I listed above you'd easily get 10 minute flight times or more, shortening to 8 minutes if you like a lot of throttle for speed or vertical maneuvers. Thats based on me flying a 15oz / 40" highwing parkflier with the same system.
Any questions just ask, hope that helps!
Cheers - boingk
EDIT:
Link for motor: http://www.hobbyking.com/hobbyking/s...idProduct=5208
Link for prop: http://www.hobbyking.com/hobbyking/s...idProduct=8012
Link for servo: http://www.hobbyking.com/hobbyking/s...idProduct=5458
Old Sep 03, 2012, 05:16 PM
Brazil
Joined Feb 2007
Thanks for the suport .
Thanks everybody for the valuable suport , I need one more help ... I think will be the last , sorry for all trouble .
How I up scale and tile print these plans in my home print ? Any software to make it ?
Thank again .
Discussion Vintage 1/2A engine problems - I need advice ezryder Vintage & Old-Timer Designs 24 Jul 04, 2012 03:53 PM
Discussion Good Control Line for 1/2A Plastic RTF's? Ah Clem Control Line 12 Jul 02, 2012 08:02 PM
Sold 1/2a Stealth Sport Plans jim1970 Aircraft - General - Miscellaneous (FS/W) 0 Jun 30, 2012 09:31 AM
Discussion Has anyone done a 1/2A conversion on a StevensAero kit? DoonRaker 1/2A Planes 11 Nov 20, 2009 04:50 PM
Lainer 1/2A "Shrikeski"...almost done mopar_man Sport Planes 6 Jun 04, 2002 11:31 AM
